Cisco 2901 router can i use Ethernet Switch rather then Ethernet Routed-Port for ITSP SIP Connectivity
anilkumar.cisco
Level 4
Level 4
Hello Team,
I have existing 2901 router.. where both gig interface of the router has been consumed.. Now customer is looking for upgrading there existing E1 PRI connection to SIP.. but we don't have spare interface.. but in stock i have EHWIC-4ESG ( as per data sheet it is Ethernet switch).. not ethernet router port...
My question is whether i can use it or not for ITSP connection.. if yes.. then how?
19 Replies 19
I'm asking the most basic question: How does the SIP server contact the SIP provider?
So far, I haven't receive any sign that there is a route from the inside to the outside.
The SIP provider will give an IP address to us of /30 subnet, which we need to assign on our routable Ethernet port of the router and an SBC IP address.. we need to point SIP traffic on SBC destination via static route source from our L3 interface..
Do u have any other idea for SIP connectivity or any other alternative as per my scenario
Hello Leo,
As per my colleague.. the following scenario work.
keep 2901 as it is.
insert Ethernet module and assign interface vlan/30 interace with ip address given by ITSP SIP provider..
give an static route in router for reaching SIP Server via new Vlan interface..
return traffic will be given by ITSP Sip server provider on new interface vlan .
Kindly advise..
Hello Team,
Today I tried to simulate the scenario..
Customer L3 switch (3560 v2 as L3 switch , IP routing enable)-->>vlan 144 (port F0/2) -- Gig0/0-->> Cisco Voice Gateway (2951)-->> ETHWIC Card installed ( Int vlan 175)- Connected to -- ITSP SIP provider router (Dummy ) with 10.50.175.62/30 IP address.
From the customer network connected to L3 Switch.. is able to ping only 10.50.175.62 but not 10.50.175.61 (ITSP IP address).. Same is from Switch interface as well.. but from the Customer router.. he is able to ping ITSP IP address i.e. 10.50.175.62 .. All routing and static routing is configure..
Just want to reconfirm.. that this is happening because EHWIC card is LAN based.. thus router is not able to do routing on this interface..
below is the device configuration..
Customer L3 switch..
Switch#sh run
Building configuration...
Current configuration : 2363 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip routing
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 142
switchport mode access
interface FastEthernet0/2
switchport access vlan 144
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
shutdown
interface Vlan142
ip address 10.10.10.142 255.255.255.0
interface Vlan144
ip address 14.82.144.31 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 14.82.144.30
ip http server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
Switch#
Switch#sh ip int bri
Vlan1 unassigned YES unset administratively down down
Vlan142 10.10.10.142 YES manual up up
Vlan144 14.82.144.31 YES manual up up
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset down down
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
FastEthernet0/9 unassigned YES unset down down
FastEthernet0/10 unassigned YES unset down down
FastEthernet0/11 unassigned YES unset down down
FastEthernet0/12 unassigned YES unset down down
FastEthernet0/13 unassigned YES unset down down
FastEthernet0/14 unassigned YES unset down down
FastEthernet0/15 unassigned YES unset down down
FastEthernet0/16 unassigned YES unset down down
FastEthernet0/17 unassigned YES unset down down
FastEthernet0/18 unassigned YES unset down down
FastEthernet0/19 unassigned YES unset down down
FastEthernet0/20 unassigned YES unset down down
FastEthernet0/21 unassigned YES unset down down
FastEthernet0/22 unassigned YES unset down down
FastEthernet0/23 unassigned YES unset down down
FastEthernet0/24 unassigned YES unset down down
FastEthernet0/25 unassigned YES unset down down
FastEthernet0/26 unassigned YES unset down down
FastEthernet0/27 unassigned YES unset down down
FastEthernet0/28 unassigned YES unset down down
FastEthernet0/29 unassigned YES unset down down
FastEthernet0/30 unassigned YES unset down down
FastEthernet0/31 unassigned YES unset down down
FastEthernet0/32 unassigned YES unset down down
FastEthernet0/33 unassigned YES unset down down
FastEthernet0/34 unassigned YES unset down down
FastEthernet0/35 unassigned YES unset down down
FastEthernet0/36 unassigned YES unset down down
FastEthernet0/37 unassigned YES unset down down
FastEthernet0/38 unassigned YES unset down down
FastEthernet0/39 unassigned YES unset down down
FastEthernet0/40 unassigned YES unset down down
FastEthernet0/41 unassigned YES unset down down
FastEthernet0/42 unassigned YES unset down down
FastEthernet0/43 unassigned YES unset down down
FastEthernet0/44 unassigned YES unset down down
FastEthernet0/45 unassigned YES unset down down
FastEthernet0/46 unassigned YES unset down down
FastEthernet0/47 unassigned YES unset down down
FastEthernet0/48 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
GigabitEthernet0/3 unassigned YES unset down down
GigabitEthernet0/4 unassigned YES unset down down
Switch#
Switch#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 05:33 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02A00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(53r)SEY4, RELEASE SOFTWARE (fc1)
Switch uptime is 2 hours, 12 minutes
System image file is "flash:c3560-ipbase-mz.122-53.SE2.bin"
cisco WS-C3560V2-48TS (PowerPC405) processor (revision P0) with 131072K bytes of memory.
Processor board ID FDO1702Y0N6
Last reset from power-on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B4:E9:B0:25:B2:80
Motherboard assembly number : 73-12632-01
Power supply part number : 341-0328-02
Motherboard serial number : FDO170206KH
Power supply serial number : DCA1652M17P
Model revision number : P0
Motherboard revision number : F0
Model number : WS-C3560V2-48TS-S
System serial number : FDO1702Y0N6
Top Assembly Part Number : 800-33165-03
Top Assembly Revision Number : B0
Version ID : V08
CLEI Code Number : CMMEJ00BRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560V2-48TS 12.2(53)SE2 C3560-IPBASE-M
Configuration register is 0xF
Switch#
Customer voice gateway where ITSP link need to be terminated..
Router#sh run
Current configuration : 2138 bytes
! Last configuration change at 08:48:34 UTC Mon Mar 23 2020
version 15.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO2951/K9 sn FGL181312G8
license boot module c2951 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 14.82.144.30 255.255.255.0
duplex auto
speed auto
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0/0
switchport access vlan 175
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/2/0
no ip address
interface GigabitEthernet0/2/1
no ip address
interface GigabitEthernet0/2/2
no ip address
interface GigabitEthernet0/2/3
no ip address
interface GigabitEthernet0/3/0
no ip address
interface GigabitEthernet0/3/1
no ip address
interface GigabitEthernet0/3/2
no ip address
interface GigabitEthernet0/3/3
no ip address
interface Vlan1
no ip address
interface Vlan175
ip address 10.50.175.62 255.255.255.252
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 14.82.144.31
ip route 10.50.175.0 255.255.255.0 10.50.175.61
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#sh ip int bri
Embedded-Service-Engine0/0 unassigned YES unset administratively down down
GigabitEthernet0/0 14.82.144.30 YES manual up up
GigabitEthernet0/1 14.82.144.30 YES manual administratively down down
GigabitEthernet0/2 unassigned YES unset administratively down down
GigabitEthernet0/0/0 unassigned YES unset up up
GigabitEthernet0/0/1 unassigned YES unset down down
GigabitEthernet0/0/2 unassigned YES unset down down
GigabitEthernet0/0/3 unassigned YES unset down down
GigabitEthernet0/1/0 unassigned YES unset down down
GigabitEthernet0/1/1 unassigned YES unset down down
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
GigabitEthernet0/2/0 unassigned YES unset down down
GigabitEthernet0/2/1 unassigned YES unset down down
GigabitEthernet0/2/2 unassigned YES unset down down
GigabitEthernet0/2/3 unassigned YES unset down down
GigabitEthernet0/3/0 unassigned YES unset down down
GigabitEthernet0/3/1 unassigned YES unset down down
GigabitEthernet0/3/2 unassigned YES unset down down
GigabitEthernet0/3/3 unassigned YES unset down down
Vlan1 unassigned YES unset down down
Vlan175 10.50.175.62 YES manual up up
Router#
Router#sh ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.3(3)M5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 04-Feb-15 09:19 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 4 hours, 26 minutes
System image file is "flash0:c2951-universalk9-mz.SPA.153-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 479232K/45056K bytes of memory.
Processor board ID FGL181312G8
19 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2951/K9 FGL181312G8
Technology Package License Information for Module:'c2951'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 RightToUse datak9
NtwkEss None None None
CollabPro None None None
Router#
ITSP router configuration
Router#sh run
Current configuration : 1387 bytes
! Last configuration change at 06:07:22 UTC Mon Mar 23 2020
version 15.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO2951/K9 sn FGL18421127
hw-module usb disable
redundancy
no ip address
shutdown
ip address 10.50.175.61 255.255.255.252
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
transport input all
end
Router#
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 10.50.175.61 YES manual up up
GigabitEthernet0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/0 unassigned YES unset down down
Router#
Router#sh ver
Router uptime is 3 hours, 55 minutes
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 485376K/38912K bytes of memory.
Processor board ID FGL18421127
7 Gigabit Ethernet interfaces
1 terminal line
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2951/K9 FGL18421127
uc None None None
Router#
thanks friends..
Best Regards
Anil Singh
It is working now, as reverse route was missing ITSP (router 2) router..
Only challenge is that.. if we are creating Multiple SVI’s on EHWIC-4ESG.. then only on SVI line protocol is up rest are down.. because it is LAN based module.
But I am able to meet my desired result
