10-01-2018 03:34 PM - edited 03-18-2019 12:32 PM
I am trying to learn VOIP functionality on a cisco 2911. I hope someone on here can help me with this.
I have a VOIP provider called VOIP.MS
I have a Fiber ONT connection going into a Palo Alto Firewall which handles all my routing and DHCP addressing.
The NAT for the internet is located on this firewall.
I've created a VLAN for this voice traffic. VLAN101 / Subnet 192.168.101.0/24
I have placed a Cisco 2911 device on the network running firmware c2900-universalk9-mz.SPA.157-3.M3.bin
interface Gi0/0 is getting a DHCP address of 192.168.101.2
I've setup a route using the command: ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
I'm trying to follow https://wiki.voip.ms/article/Cisco_IOS but I dont have enough understanding to know what is going wrong.
Here is my config for the relevant areas. Let me know if you need other sections.
voice service:
voice service voip ip address trusted list ipv4 162.213.157.82 ip address trusted call-block cause not-in-cug gcid clid substitute name allow-connections sip to sip no supplementary-service sip moved-temporarily no supplementary-service sip refer fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none sip session refresh e911 transport switch udp tcp asserted-id ppi localhost dns:vancouver.voip.ms midcall-signaling passthru no call service stop
sip-ua (changed the passwords to a fake number)
sip-ua credentials username 226468_cisco01 password 7 13240981231823 realm vancouver.voip.ms authentication username 226468_cisco01 password 7 13240981231823 realm vancouver.voip.ms registrar 1 dns:vancouver.voip.ms expires 300 sip-server dns:vancouver.voip.ms host-registrar
dial-peer (changed did to fake number)
dial-peer voice 1 voip huntstop destination-pattern 5551236541 session protocol sipv2 session target sip-server dtmf-relay cisco-rtp rtp-nte codec g711ulaw no vad
I am unsure how this device is suppose to register with my voip provider.
I am not seeing any traffic on my firewall to indicate that this device is attempting registration.
I enabled the debug ccsip but I dont see any console messages at all.
Maybe I misunderstand how this works.
I thank you for the help in advance.
10-01-2018 04:19 PM
10-02-2018 10:10 AM
Hello Leo,
I understand that I can use Asterix to connect to my voip service but I thought I would learn the voice aspect of Cisco IOS.
Am I misunderstanding how the Cisco 2911 works? Should it not be able to make a connection to my VOIP provider directly?
I envision this connection flow but I could be way off.
Cisco 7945 IP Phone -> Cisco 2911 -> Palo Alto FW Internet -> VOIP Provider
This is a test lab. I only have the one 7945 IP Phone.
10-02-2018 10:13 AM
Sorry I replied using the wrong account.
That was my reply above.
10-24-2023 05:26 AM
Hello there,
Have you figured this out? I have the same set up but with a UDM router instead of Palo Alto.
10-02-2018 11:17 AM
10-02-2018 12:31 PM - edited 10-02-2018 12:33 PM
Here is the output of that command:
HL-C2911-01#sho dial-peer voice summary dial-peer hunt 0 AD PRE PASS SESS-SER-GRP\ OUT TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF 1 voip up up 7806665194 0 syst sip-server NA For server-grp details please execute command:show voice classserver-group <tag_id> To see complete session target for ipv6 use 'sh running config | section dial-peer <tag>
Please note that I have not connected / configured the 7945 yet.
Also note that when I look at my VOIP provided the account shows as not registered.
Also I don't see any traffic leaving this router except for DNS queries.
10-24-2023 05:28 AM
Hello there,
Cisco IP phone 8851 --> Cisco Switch --> cisco isr 4321 --> UDM --> SIP Provider
10-24-2023 06:12 AM
Maybe you open a new question and describe in more detail, what is not working.
And I would advise you to attach the config and logs of the CUBE. Otherwise it will be "glass ball reading".
10-24-2023 06:52 AM
Ok. Thanks I will do that.
