Cisco 2911 voice gateway
rapalu2011
Hello to all, i hoepe you can help me, i have a Cisco 2911 that i want to use as a voice gateway connected to a Call Manager, i have the following inventory:
Router#show inventory
NAME: "CISCO2911/K9 chassis", DESCR: "CISCO2911/K9 chassis"
PID: CISCO2911/K9      , VID: V02 , SN: FHK1442F0NV
NAME: "1 port channelized and PRI T1/E1 HWIC on Slot 0 SubSlot 0", DESCR: "1 por
t channelized and PRI T1/E1 HWIC"
PID: HWIC-1CE1T1-PRI   , VID: V01 , SN: FOC14280LXF
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP D
IMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC13524CSG
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Ada
pter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC14040NDL
NAME: "Unknown on Slot 1", DESCR: "Unknown"
PID: EVM-HD-8FXS/DID   , VID: V03 , SN: FOC10203FN7
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V01 , SN: AZS143617CZ
What IOS should i have in the router? i hope someone can help me with this issue, thank's.
Jaime Valencia
ISR G2s no longer have many IOS images, there is just 1 image which includes everything (that doesn't mean you can use it).
The features you're going to use need to be unlocked by buying the right licenses and installing them on the ISR G2.
Latest IOS available is 15.1.4M
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
