08-06-2015 07:12 AM - edited 03-17-2019 03:54 AM
Hello Yall,
a client of ours has a Cisco voice router 3800. We attached an external MoH player to this router. When our technician arrived on site, he did not have the right cable with RCA-to-RJ11 ends, so he spliced the RCA cable at one end and put an RJ11 end on it, then used electric tape around the splice. The client is complaining about a "Humming" noise from time to time. and he would have to try to reposition the audio cord to eliminate the noise (the 3800 is on a rack with a bunch of other electronic equipment close by). The client is demanding we provide him with a pre-manufactured cord...One that has not been spliced! I am having a hard time finding a shielded RCA-to-RJ11 audio cord! My questions are:
1- Is that the correct cable for the 3800 Router?
2- Does anyone know where I can order such cable?
3- Does anyone have a part # for such cable?
Note:
I work for Spectrio, which is one of the largest Message on Hold companies in the US. We usually contract technicians to install our MoH equipment worldwide!
Thank you
Ollie
08-06-2015 09:25 AM
Hi Ollie,
You can buy that cable in almost every electronic store or online.For example:
http://www.omnicronelectronics.com/digital/mod-sc.htm
If you want to make it your own follow these instruction:
The live-feed feature is typically used to connect to a CD jukebox player. To configure MOH from a live feed, you establish a voice port and dial peer for the call and also create a “dummy” ephone-dn. The ephone-dn must have a phone or extension number assigned to it so that it can make and receive calls, but the number is never assigned to a physical phone. Only one live MOH feed is supported per system.
Using an analog E&M port as the live-feed MOH interface requires the minimum number of external components. You connect a line-level audio feed (standard audio jack) directly to pins 3 and 6 of an E&M RJ-45 connector. The E&M voice interface card (VIC) has a built-in audio transformer that provides appropriate electrical isolation for the external audio source. An audio connection on an E&M port does not require loop-current. The signal immediate andauto-cut-through commands disable E&M signaling on this voice port. A G.711 audio packet stream is generated by a digital signal processor (DSP) on the E&M port.
08-06-2015 09:54 AM
Thank you so much Leo, I really appreciate all the good info...I'll run with it, and I'l post back to confirm whether this issue has been resolved
Another Question:
Does Cisco provide a reference guide (a list), for all the Voice routers and what type of connectors they use for the MoH ports? I know some have RJ11, RJ45, USB...etc! it would be nice to have a reference guide on hand instead of digging for individual ones every time we have an MoH installation.
I appreciate the info
Ollie
