CUBE E164 call back
stephen.green
Does anyone know how to remove the + from the incoming From header, or a way for using translation patterns to enable call back from the call history
Aug  6 10:38:18.738: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:442038199165@10.50.134.250;user=phone SIP/2.0
Max-Forwards: 68
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: <sip:442038199XXX@10.50.134.250;user=phone>
P-Asserted-Identity: <sip:+447803231XXX@10.100.41.9;user=phone>
Call-ID: 221062448-3647846341-132486@LNHC-SBC-01.mydomain.com
CSeq: 1 INVITE
Allow: PUBLISH,MESSAGE,UPDATE,PRACK,SUBSCRIBE,REFER,INFO,NOTIFY,REGISTER,OPTIONS,BYE,INVITE,ACK,CANCEL
Via: SIP/2.0/UDP 10.100.41.9:5060;branch=z9hG4bKe4b231344173009572da002043544d9c
Contact: <sip:+447803231XXX@10.100.41.9:5060>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 217
There are many ways of doing it. Can you please clarify your topology? Is your CUBE connected to CUCM?
The best option will be stripping '+' sign on CUCM and prefix '0' as access code instead using translation pattern. This will allow users to dial from history.
Nadeem Ahmed
Are you looking to strip the(+) sign for specific number or you want all number coming with (+) sign in from Header to be stripped with Plus sign.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
you can try this and let me know if this works
This is to remove Plus sign from from header for all calls coming in having (+)sign in FROM  header.
voice class sip-profiles XX
request ANY sip-header From modify "ip:\+1" "ip:"
This need to applied on the dial-peer which is hitting
