Cisco 3825 and PVDM.
My client has a Cisco 3825 Router. The same is the IOS 12.4 (11) test router has 2 PVDMs64 on the motherboard. He also has a module with 2 PVDM NM-HDV2-2T1/E1.
I wonder if the router that I bear PVDMs put 2 more on the motherboard and two more in the module.
The router would then 8 PVDMs.
I wonder also if it is possible to configure the conference and transcode PVDM module pair using all router interfaces. My client has a Cisco 3825 Router. The same is the IOS 12.4 (11) test router has 2 PVDMs64 on the motherboard. He also has a module with 2 PVDM NM-HDV2-2T1/E1.
Harmit Singh
Hi Marcelo,
There are 4 PVDM slots on the 3825 motherboard and there are 4 PVDM slots on the NM-HDV2 module:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008039c333.shtml
So, to answer your question, yes, you can add 2 more PVDMs on the motherboard and NM-HDV2 to make the total of 8 PVDMs on the router. Also, yes, you can configure conferencing and transcoding using all these PVDMs as long as you configure the following under the 2 voice-cards on your router:
voice-card 0                         (this is for the motherboard)
dspfarm
dsp services dspfarm
voice-card 1                         (if NM-HDV2 is in slot 1 of the router)
dspfarm
HTH.
Harmit.
Harmit Singh
Hi Marcelo,
dspfarm
dspfarm
HTH.
Harmit.
Thanks for your reply!!
Glad I could help! :-)
Harmit.
