Cisco 3945 hardware & license requirement for SIP setup.
ciscoproxy
Hi All,
We are planning to move from PRI to SIP link due to cost-saving plan. We are planning to buy Cisco 3945 router for this particular setup. I am not sure about the hardware & license requirement for CUBE. Hoping for inputs from experts here.
Is HWIC-1CE1T1-PRI module and UC license required for this setup?
balaji.bandi
i believe you should not require PRI License here, you need CUBE License
here is the ordering guide :
https://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/ordering_guide_c07_557736.html
BB
Jaime Valencia
ISR 39XX are EOS, I suggest you reach out to a local Cisco partner with UC specialization to get assistance with currently shipping options, either ISRs or vCUBE
java
if this helps, please rate
