Cisco 3945 IOS upgrade
Hi ,
I need to upgrade a Cisco 3945 router .
Current the router has boot marker:
boot-start-marker
boot system flash c3900-universalk9-mz.SPA.156-3.M1.bin
boot system flash c3900-universalk9-mz.SPA.155-3.M3.bin
boot-end-marker
The c3900-universalk9-mz.SPA.155-3.M3.bin IOS has been deleted .
I have copied c3900-universalk9-mz.SPA.157-3.M1.bin version in the flash .
Please suggest how to change the boot marker to :
boot system flash c3900-universalk9-mz.SPA.157-3.M1.bin
Leo Laohoo
conf t
no boot system flash flash:c3900-universalk9-mz.SPA.155-3.M3.bin
boot system flash flash:c3900-universalk9-mz.SPA.157-3.M1.bin
boot system flash flash:c3900-universalk9-mz.SPA.156-3.M1.bin
end
7 Replies 7
Leo Laohoo
conf t
end
and once rebooted rip the old IOS out. by deleting it from flash. but only once you successfully boot up on the new IOS
Please remember to rate useful posts, by clicking on the stars below.
Hi After reboot the latest version should be displayed under show version.
conf t
end
 _________________________________________________________
do I have to use flash twice or just
boot system  flash0 :c3900-universalk9-mz.SPA.157-3.M1.bin
Just do it one time.
"boot system  flash0 :c3900-universalk9-mz.SPA.157-3.M1.bin" is not stated between your boot-start-marker & boot-end-marker.
More info can be found here:
https://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/command/reference/ffun_r/frf010.html#wp1017705
Yassine
Yassine
Junior Network Engineer
Hi ,
Does the boot system flash command instantly reboot the router after using the command.
Nope.
