11-18-2016 06:53 PM - edited 03-17-2019 08:43 AM
I have scoured the documentation for the different types of cards and as many datasheets as I could possibly find. I cannot locate a specific place that dictates exactly how many individual serial circuits are able to be used on a 4431 router. Technically, I could install 3x NIM-8MFT-T1/E1 cards with the appropriate PVDMs but how many of them could I actually use? Surely the router would recognize a maximum number of configurable PRIs.
I have found this link about the PVDMs and am a little confused about the support of PVDMs on the 4431 platform.
PVDM4 Platform Availability and Performance
I've clicked on (and read) nearly every link here:
http://www.cisco.com/c/en/us/support/routers/4441-x-integrated-services-router-isr/model.html
I *thought* the solution might have been here:
Does anyone have a document of any sort in which Cisco tells you how many NIM cards you can expect to use for PRI circuits?
Solved! Go to Solution.
11-19-2016 09:49 AM
Hi there,
Check out the doc below, it shows that 720 channels (24x30 for E1 and 24x24 for PRI) would be the supported maximum on the 4431 as you thought;
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
Cheers!
Rob
11-19-2016 09:49 AM
Hi there,
Cheers!
Rob
