Cisco 7811 IP Phone Licenses issue
immu_91700
Dear Support,
Hope this email find you in good health,
  1. We have 96 rooms which has two phones with one EXT Number (for example 101 )and as per my understanding it should take Enhanced plus/ CUWL standard licenses. So it will cover 192 phones as each rooms has two phones and each two phone will take one license either enhance plus or CUWL.
  2. It not clear why this 96 room phones are taking basic licensing where this room extensions should take either one enhance plus or one CUWL license.
  3. Will it be possible that if we create one user and bind this room two phones to user then it will take enhance plus or CUWL license for two phones. kindly need your support to fix this issue.
                  Sample of each Floor
S/No
No of Phones in each room
No of Rooms  in each Floor
Total Quantity
1 Phone 48 bedrooms = 48 Phones
2 Phones 96 Bedrooms = 192 Phones
3 Phones 24 Rooms Total = 72 Phones
4 phones 4 Rooms total  =16 Phones
We have below quantity with us
           No of 7811 Phones 393
           No of 8811 Phones 10
           No of 8845 Phones 10
           No of SPA301-G3 Phones 168
Kindly find the details below for licenses usages
Jaime Valencia
These are USER licenses, not really device licenses, suggest you read this:
https://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-licensing/C45_523902_11_9_licensing_aag_v5a_1.pdf
java
if this helps, please rate
i would like to know Cisco 7811 IP Phones support the enhance and enhance Plus licenses or not
Immu,
As Jaime replied the licensing model works based on user association with device model. You can go through the Cisco licencing doc for better understanding.
https://www.cisco.com/c/dam/en/us/products/collateral/unified-communications/unified-communications-licensin /C45_523902_11_9_licensing_aag_v5a_1.pdf
PRASSHA3
Rate if you find this helpful
Prassha3
Rate if you find this helpful or Mark Solutions as Accepted
