incoming call appearing twice number in cisco 7811
immu_91700
this is hotel side each room we have two  two phones but when we call from one room to another room in display we  are receiving number and name twice kindly need your support to fix this issue.
rare receiving name twice Kindly find the images belowWhatsApp Image 2019-07-22 at 4.41.36 PM.jpegWhatsApp Image 2019-07-22 at 5.04.40 PM.jpegWhatsApp Image 2019-07-22 at 5.09.31 PM.jpeg
Kindly anyone can suggest me which are option to be check and unchecked
Prassha
Check the alerting name set for the phone line, I am suspecting it is set so,  that's why it displays twice?
> I believe you are facing this issue for internal calls only? not external, let me know if external calls are also affected?
If it is correct? then let me know :
> CUCM version?
> Is it a new setup?
> What is phone firmware?
> Have you tried reset the phone or factory reset? if so what was the outcome?
PRASSHA3
Rate if you find this helpful
Prassha3
Rate if you find this helpful or Mark Solutions as Accepted
hi Parashaa,
thank you for your response kindly find the below answer
> CUCM version? 11.5
> Is it a new setup? yes
> Have you tried reset the phone or factory reset? if so what was the outcome? all the phones showing same i have 378 phones in hotel
Hello Immu
Did you Check the alerting name set for the phone line?
Have you tried reset the phone ?
Prassha3
