03-06-2018 03:21 AM - edited 03-17-2019 12:21 PM
Hello, I am trying to register 7811 IP Phone to CME but when I connect the phone to the switch It trying to register and takes an IP address from the pool on the core and continue registration but after few seconds it shows an error ( xml 4 parse error ) and stuck in registering process with no action and doesn't retain IP address
Here is the configuration of DHCP pool
ip dhcp pool CME_Phones
network 10.73.1.0 255.255.255.0
option 150 ip 10.100.5.17
default-router 10.73.1.252
option 42 ip 192.168.0.1
Here is the configuration of CME
Solved! Go to Solution.
03-13-2018 05:53 AM
I don't think so.
please show me what you have on your flash:its
On your SW core you can ping 10.100.5.17 with source-add 10.73.1.252
Thks
03-13-2018 05:46 AM
03-13-2018 06:08 AM
I can ping normally from core sw and vice versa
The IP 10.73.1.252 is an IP of int vlan on core SW
I don't know really what is the problem ?
03-13-2018 06:28 AM
Can you help me with this problem sir @R0g22
03-13-2018 06:44 AM
03-13-2018 06:58 AM
There are nothing appears when I wrote the debug commands
Here are the configuration @R0g22
03-13-2018 07:10 AM
03-13-2018 07:23 AM
I made that but nothing appears in the debug but logs changed @R0g22
CME#show log
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 40 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: disabled
Log Buffer (5000000 bytes):
*Mar 13 14:10:14.715: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (5000000)
*Mar 13 14:10:14.731: %SYS-5-LOG_CONFIG_CHANGE: Console logging disabled
*Mar 13 14:10:14.751: %SYS-5-LOG_CONFIG_CHANGE: Monitor logging disabled
*Mar 13 14:10:53.999: %SYS-5-CONFIG_I: Configured from console by beboo on vty0 (192.168.240.224)
*Mar 13 14:13:08.495: TFTP: Looking for CTLSEP00279024A85B.tlv
*Mar 13 14:13:09.371: TFTP: Looking for ITLSEP00279024A85B.tlv
*Mar 13 14:13:10.243: TFTP: Looking for ITLFile.tlv
*Mar 13 14:13:11.155: TFTP: Looking for SEP00279024A85B.cnf.xml
*Mar 13 14:13:12.147: TFTP: Looking for XMLDefault.cnf.xml
*Mar 13 14:13:12.287: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 10, size 3757 for process 118
*Mar 13 14:13:12.295: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 118
*Mar 13 14:13:12.871: TFTP: Looking for CTLSEP00279024A9E7.tlv
*Mar 13 14:13:13.767: TFTP: Looking for ITLSEP00279024A9E7.tlv
*Mar 13 14:13:14.643: TFTP: Looking for ITLFile.tlv
*Mar 13 14:13:15.659: TFTP: Looking for SEP00279024A9E7.cnf.xml
*Mar 13 14:13:15.663: TFTP: Opened flash:/its/SEP00279024A9E7.cnf.xml, fd 10, size 3906 for process 118
*Mar 13 14:13:15.671: TFTP: Finished flash:/its/SEP00279024A9E7.cnf.xml, time 00:00:00 for process 118
*Mar 13 14:13:21.839: TFTP: Looking for SIP_English_United_States/sp-sip.jar
*Mar 13 14:13:23.111: TFTP: Looking for United_States/g3-tones.xml
*Mar 13 14:13:24.379: TFTP: Looking for softkeyDefault_kpml.xml
*Mar 13 14:13:24.379: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 10, size 4748 for process 118
*Mar 13 14:13:24.391: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 118
*Mar 13 14:13:59.955: TFTP: Looking for CTLSEP00279024A9E7.tlv
*Mar 13 14:14:00.835: TFTP: Looking for ITLSEP00279024A9E7.tlv
*Mar 13 14:14:01.723: TFTP: Looking for ITLFile.tlv
*Mar 13 14:14:02.707: TFTP: Looking for SEP00279024A9E7.cnf.xml
*Mar 13 14:14:02.707: TFTP: Opened flash:/its/SEP00279024A9E7.cnf.xml, fd 10, size 3906 for process 118
*Mar 13 14:14:02.719: TFTP: Finished flash:/its/SEP00279024A9E7.cnf.xml, time 00:00:00 for process 118
*Mar 13 14:14:07.311: TFTP: Looking for SIP_English_United_States/sp-sip.jar
*Mar 13 14:14:08.339: TFTP: Looking for United_States/g3-tones.xml
*Mar 13 14:14:10.199: TFTP: Looking for softkeyDefault_kpml.xml
*Mar 13 14:14:10.203: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 10, size 4748 for process 118
*Mar 13 14:14:10.215: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 118
*Mar 13 14:16:04.555: TFTP: Looking for CTLSEP00279024A85B.tlv
*Mar 13 14:16:05.431: TFTP: Looking for ITLSEP00279024A85B.tlv
*Mar 13 14:16:06.311: TFTP: Looking for ITLFile.tlv
*Mar 13 14:16:07.223: TFTP: Looking for SEP00279024A85B.cnf.xml
*Mar 13 14:16:08.211: TFTP: Looking for XMLDefault.cnf.xml
*Mar 13 14:16:08.211: TFTP: Opened system:/its/vrf1/XMLDefault.cnf.xml, fd 10, size 3757 for process 118
*Mar 13 14:16:08.219: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 118
CME#
CME#debug voice register events
voice-register events debugging is on
CME#debug voice register error
voice-register error debugging is on
CME#debug ccsip error
SIP Call error tracing is enabled
CME#debug ccsip message
SIP Call messages tracing is enabled
CME#debug ccsip non-call
SIP Out-of-Dialog tracing is enabled
CME#debug tftp event
TFTP Event debugging is on
03-13-2018 07:12 AM
@Ahmed habib, why are you configured ephone-type 7811....it's for SCCP command no?
Have you got the type 7811 on the CME database? Or is it a mistake because you need to create a template not with ephone-type but voice register pool-type 7811
Best regards.
If this helps, please rate,
Ben
03-13-2018 07:14 AM
03-13-2018 07:25 AM
Ok,
on your dhcp the option 42 is for NTP?
Then on your voice register global modify the ntp-server command with the good IP address.
We need the log @R0g22 ask for.
Best regards,
If this helps, plsease rate.
Ben
03-13-2018 07:30 AM
03-13-2018 07:33 AM
03-13-2018 07:36 AM - edited 03-13-2018 07:57 AM
0027.9024.A9E7
but another phone have the problem too 0027.9024.A85B
I have many phones of this model
03-13-2018 08:28 AM
