01-13-2015 01:43 PM - edited 03-17-2019 01:34 AM
We are currently running CUCM 8.6 and we are trying to integrate 7841 phones in to our system.
I have installed devicepack8.6.2.26154-1 and 78xx-10-2-1-12SR1-4.
I added the phone and it is able to register, how ever it keeps un-registering and registering again.
I have let the phone for a week and still no staying registered.
I plug a 6941 in the same port and every thing works fine.
Thanks in advance.
Solved! Go to Solution.
01-13-2015 01:57 PM
After you installed the device pack and the firmware, did you do a cluster wide reboot?
I had skipped that step once before and had similar results to what your describing.
01-13-2015 01:57 PM
01-14-2015 08:08 AM
I did a cluster wide restart, from the OS Administration page. However after your post and reading a few others I decided to do it from the CLI with "utils system restart", publisher first then each subscriber and TFTP servers one at a time. This did resolve my issue.
Thank you.
01-14-2015 05:37 AM
Could be the firmware. The public 78xx firmware quality isn't as good as some of the other Cisco handsets. I've got an ES version of the 78xx firmware (78XX_10-2-1ES3) and that's got a lot of bugs fixed in it. (I believe there's an even later one that has even more bugs fixed)
GTG
