Cisco 7911g - group listen feature
kern.jerome
I have a problem with a 7911g phone. I cannot use the group listen feature (european style)with my ccme 4.0. (It doesn't work, or I didn't find the right command...)
I tried with a CCM5, and everything worked fine.
So the phone is working, but I have to make it work with a ccme 4.0. Is there a special command to make it work?
Jerome
9 Replies 9
paolo bevilacqua
Hi Kern,
What is group listen (european style)? Do you mean group paging?
I want to be able to use the group listen feature (European-style speakerphone using the handset and the chassis speaker together).
No, with CME the "monitor" softkey just toggles between handset and speaker. It would be a nice to have feature.
Is Group Listen Supported on CUCM Business Edition?
Hi Charalambos,
This has been available in CCM since 4.1(3) :)
Using the Group Listen Feature on the
Cisco Unified IP Phone 7906G and
7911G
You must add these Softkeys and Delete the Monitor Softkey;
GListen softkey
GLOff softkey
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7906g_7911g/4_1_3/english/group/listen/0611GL.pdf
Hope this helps!
Rob
CME's PMs, take note :)
Hello Guys,
Another quick question.
Is this feature supported on 7931 phones? or just for 7906/11?
Thanks.
On the 7931, you don't really need that. The full-duplex speakerphone is good enough to enable anyone in the same room to participate in a conversation.
I run into this feature fairly often on legacy systems. Customers use a 'listen-in' feature that allows them keep the handset active, while setting the speakerphone to 1 way monitor. This allows other people in the room to 'listen-in' on the phone conversation. On the CM it's the group listen function, but only supported on a couple of phones. Any ideas to have the same function on a higher end phone with a full duplex speaker phone?
