CISCO 7912 SIP TO SCCP
alessio.letizia
Hi, I have a 7912 ip phone with firmwere SIP, SCCP and I have to update. If I connect it to the phone automatically takes Callmanager network parameters, but does not update SCCP. The phone seems to be stuck.
How can I solve this problem?
THANKS TO ALL
9 Replies 9
Aman Soi
Did u try factory reset for the phone and then,try upgrading?
Secondly,what is the call manager version & SCCP firmware u are tryong to upgrade?
regds,
aman
hello, I have done the factory reset but does not update.
reading in the forum, there was talk of a file gk of the phone.
I await news
Did u follow thefactroy reset  procedure mentioned in below link?
http://kb.nexmatrix.net/index.php/article/reset-your-cisco-7912-to-factory-defaults
Can u post the forum you are mentioning?
regds,
aman
I think u are using call manager version 6.1 and SCCP version which u are trying to upload in call manager is cmterm-7912-8.0.4-sccp.cop.sgn
Please confirm.
If yes,please refer the URL which says that u need to upload the firmware first in call manager server
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7905g_7912g/firmware/8_0_4/english/release/notes/7912_804MR.html
regds,
aman
I use CUCM 7.0.1. the phone automatically takes the network parameters but does not update.
Dear friend
Kindly go to Cisco call manager , device -device setting - device default configuration - Cisco 7912  load information assign sccp firmware .   After that restart the phone using hardware .
thank you
please rate if this will help
Hi Letizia,
I have checked in call manager 7.1.5 and found the firmware for 7912 as CP7912080003SCCP070409A loaded .
Please look into this forum.It would help u.
https://supportforums.cisco.com/thread/280681
Please rate the post if found to be useful.
regds,
aman
hello, follow these steps to upgrade??
