03-26-2013 02:21 AM - edited 03-16-2019 04:27 PM
Hi, I have a 7912 ip phone with firmwere SIP, SCCP and I have to update. If I connect it to the phone automatically takes Callmanager network parameters, but does not update SCCP. The phone seems to be stuck.
How can I solve this problem?
THANKS TO ALL
03-26-2013 02:30 AM
Did u try factory reset for the phone and then,try upgrading?
Secondly,what is the call manager version & SCCP firmware u are tryong to upgrade?
regds,
aman
03-26-2013 02:57 AM
hello, I have done the factory reset but does not update.
reading in the forum, there was talk of a file gk
I await news
03-26-2013 03:05 AM
Did u follow thefactroy reset procedure mentioned in below link?
http://kb.nexmatrix.net/index.php/article/reset-your-cisco-7912-to-factory-defaults
Can u post the forum you are mentioning?
regds,
aman
03-26-2013 03:33 AM
03-26-2013 03:49 AM
I think u are using call manager version 6.1 and SCCP version which u are trying to upload in call manager is cmterm-7912-8.0.4-sccp.cop.sgn
Please confirm.
If yes,please refer the URL which says that u need to upload the firmware first in call manager server
regds,
aman
03-26-2013 04:12 AM
I use CUCM 7.0.1. the phone automatically takes the network parameters but does not update.
03-26-2013 05:10 AM
Dear friend
Kindly go to Cisco call manager , device -device setting - device default configuration - Cisco 7912 load information assign sccp firmware . After that restart the phone using hardware .
thank you
please rate if this will help
03-26-2013 05:23 AM
Hi Letizia,
I have checked in call manager 7.1.5 and found the firmware for 7912 as CP7912080003SCCP070409A loaded .
Please look into this forum.It would help u.
https://supportforums.cisco.com/thread/280681
Please rate the post if found to be useful.
regds,
aman
03-26-2013 05:43 AM
hello, follow these steps to upgrade??
