Global E.164 DialPlan
jparlasiii
I have read quite a few comments on the this discussion board and so far everyone has sort of mentioned Global E.164 format on the lines themselves.  So my question is, for those that have implemented Global E.164, did you apply the full number on all phone lines, and if so, how did your bridge the issues of MWI via Unity Connection and SAF/CCD support on CME gateways?
ronpatel
Level 8
Level 8
What is your CUC version
Cisco Unity Connection 9.x supports the primary extension of an end user account (user with a voice mailbox), in the E.164 format.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/release/notes/901cucrn.html#wp1562242
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
islam.kamal
Level 10
Level 10
Dear
Kindly be informed that the only CUC v9 as Eng.ronak mentioned. Please also find the below which will be so helpfull
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/vmessage.html
https://supportforums.cisco.com/docs/DOC-12054
https://supportforums.cisco.com/message/3244083#3244083
https://supportforums.cisco.com/message/3031579#3031579
Thank you
please rate if this will help
