Cisco 7960/7940G IP phone Firmwire upgrade & Extension number change
pradeep01111
In our office there are some Cisco 7960/7940G IP phones . Please let me know
1.How I can find current Firmware version?
2.How to upgrade the Firmware?
3.How to change extension number and user names?
Thanks for your support in advance
Hi Pradeep01111,
Do you have a smartnet contract with the phone?
Hi Ferdinand,
No contract.
We are using Utility Express Administration V8.6.4 and CISCO UNIFIED COMMUNICATION MANAGER EXPRESS  (CME) SYSTEM ADMINISTRATION   1998-2007
I want to find out the current version and later need to upgrade. But through the interface I can't find both option.
Please let me know how I can find these options through these utility administration or call manager
Thank you
Hi pradeep01111,
Boot up your phone
After this go to Settings and check on Firmware versions
Under application Load ID would be your firmware version.
please send me an email so I can look if you can download the update or if you need Smart Net with it. please send me an email at fguasque@cisco.com
Hope this helps!
Ferdinand Guasque
Hi Ferdinand ,
Thanks for your reply. I will email you the details.
