01-13-2015 02:14 PM - edited 03-17-2019 01:34 AM
Hi guys,
We have a few users requesting CFA from their 2nd line on 8941 phone (running latest firmware), however the softkey never show up. From Cisco 8945 doc , it says :
Call Forward All allows you to forward calls from any line on your phone to another number.
I also find out for 99XX model, CFA from 2nd line works fine.
I know that user can login webpage user option to do it , but prefer to have a softkey for them.
Anyone know is this a bug or defect ?
Thanks in advance
Yang
Solved! Go to Solution.
01-13-2015 06:06 PM
Hi - As far as I know you can do call forward all for the primary line only from the CFwdAll softkey. For the secondary line it has to be done from either CCM User page or an admin can do that.
This has been the case from very early versions of the CUCM 3.X onwards. There has been an enhancement\feature request with Cisco on this and I believe it's not yet sorted and not available on public domain as far as I know. The BUG ID is
CSCdr03425 (registered customers only) —AVVID: Allow additional line appearances to be forwarded from phone.
Its mentioned at the bottom of below page:
There's also a document published on the Cisco web site about this which still holds true:
Came across this post as well from Rob mentioning a third party product that's available for this purpose in case there are pressing need to achieve this.
https://supportforums.cisco.com/discussion/11581356/call-forwarding-shared-line-scenario
Hope that helps.
-Terry
Please rate all helpful post and mark the thread as answered if you have no more queries.
01-13-2015 05:06 PM
do you select your second line first? after that check on your phone's display which softkeys are available.
01-13-2015 06:17 PM
Hi Dennis ,
Thanks for your reply , I have tested with selecting primary first then switch to 2nd and 2nd first then primary. Every time under primary line, CFA softkey does come up, but never does the 2nd line.
01-13-2015 09:18 PM
[+5] to Terry and Dennis for providing info and troubleshooting tips.
Hi Yang,
you can look into the bug which says
01-13-2015 06:06 PM
Hope that helps.
-Terry
01-13-2015 06:23 PM
Hello Terry ,
Thanks for your information , I believe this happens to most of Cisco IP Phones (69xx 79xx 89xx)except 99XX.
BTW, like you mentioned , our workaround used to be adding a Spectralink Wireless phone to share both number and call forward from there.
If this is starting from CUCM 3, I won't expect Cisco can fix it :)
Yang
01-13-2015 06:27 PM
Not sure why the developers would take that long to add that in it the code.
Anyways if you have no more questions please mark the thread an answered and please do rate helpful posts.
-Terry
