09-24-2016 04:50 AM - edited 03-17-2019 08:10 AM
Hi All,
I have been trying to upgrade Cisco 7960G phone from SCCP to SIP for some time now without luck.
First of all, I cannot find an "unlock phone" option on my 7960G phone so I can't erase the existing configuration.
There is no password set up. When I go to Settings, there are only 6 sections - last one is Security Config. CTL is not installed
I reboot SCCP phone, keep # pressed, go through 12345.... sequence, choose No.
The phone is not picking up new firmware from TFTP/CME
SIP P0S3-8-12-00
SCCP P0030801SR02- currently installed on the phone
Do I need to do a staged upgrade to this version of SIP?
Ping works between CME and IP phone.
Hope that somebody an help !
My lab set-up:
CME: version 8.1
192.168.100.254 VLAN 100
acts as TFTP/DHCP server
PoE Switch 3560
acts as router/gateway
192.168.100.253 VLAN 100
192.168.10.253 VLAN 10
Voice VLAN 10
192.168.10.0/24
Switch show run
Current configuration : 1622 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW-3560
ip subnet-zero
ip routing
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 100descr CME RTR
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport mode access
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport voice vlan 10
spanning-tree portfastdescr phone-1-sccp
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.253 255.255.255.0
ip helper-address 192.168.100.254
interface Vlan100
ip address 192.168.100.253 255.255.255.0
ip classless
ip http server
CME Router "show run"
Current configuration : 1966 bytes
! Last configuration change at 11:20:08 E Sat Sep 24 2016
version 15.1
hostname RTR-VOICE2
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
no aaa new-model
clock timezone E 0 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.10.250 192.168.10.254
ip dhcp pool VOIP-POOL
network 192.168.10.0 255.255.255.0
option 150 ip 192.168.100.254
default-router 192.168.10.253
no ip domain lookup
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
sip
registrar server expires max 600 min 60
voice register global
mode cme
source-address 192.168.100.254 port 5060
max-dn 20
max-pool 2
load 7960-7940 P0S3-8-12-00
tftp-path flash:
create profile sync 0001596893951857
voice register dn 1
number 2001
voice register pool 1
id mac 0021.5502.9014
type 7960
number 1 dn 1
description problemPhone
codec g711ulaw
voice-card 0
license udi pid CISCO2811 sn FCZ15047EUR
license accept end user agreement
redundancy
interface FastEthernet0/0
ip address 192.168.100.254 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.10.0 255.255.255.0 192.168.100.253
logging esm config
tftp-server flash:P0S3-8-12-00.loads
tftp-server flash:P0S3-8-12-00.sbn
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
ntp master
ntp server 192.168.100.254
end
CME show voice register tftp-bind
RTR-VOICE2#show voice register tftp-bind
tftp-server syncinfo.xml url flash:/syncinfo.xml
tftp-server SIPDefault.cnf url flash:/SIPDefault.cnf
tftp-server softkeyDefault_kpml.xml url flash:/softkeyDefault_kpml.xml
tftp-server softkeyDefault.xml url flash:/softkeyDefault.xml
tftp-server SIP002155029014.cnf url flash:/SIP002155029014.cnf
09-24-2016 11:20 AM
To unlock the phone you need to press the settings button and then press **#.
Aseem
09-24-2016 11:40 PM
Hi Aseem,
Nothing happened. I tried that already!
I managed to sort it yesterday by configuring CUCM VM and the phone has picked up correct firmware almost instantly.
Thanks for your help
09-24-2016 11:23 AM
You may refer to the link below:
http://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/unified-ip-phone-7900-series/5455-handset-to-sip.html#sccptosip2
Aseem
