Cisco 7961 IP phone showing blank screen after factory reset.
Hi Everyone,
I have factory resetted my cisco 7961 ip phone firstly using 123456789*0# and then 3497672850*# ,but now its showing blank screen with all line buttons blinking in sequence.
What happened to my ip phone ? is it dead ? how can I make my cisco 7961 IP Phone working again.
Please guide me
Thankx & Regards
Deepak
21 Replies 21
Hi AyoDeji,
Need your assistance as I tried
m installed tftpd on my PC and given and downloaded the firmware 8.5.3  from cisco website for 7945 IP phone
I have taken a spare switch wherein I configured the default settings as per below
interface Vlan1
ip address 192.168.11.1 255.255.255.0
ip dhcp excluded-address 192.168.11.1 192.168.11.20
ip dhcp pool 40
   network 192.168.11.0 255.255.255.0
   option 150 ip 192.168.11.22
   dns-server 192.168.11.4 192.168.1.4
   default-router 192.168.11.1
and checked the IP assigned to the Laptop its getting IP Address as 192.168.11.22
Now I connected Faulty IP Phone to other port of the switch and tried to open the tftpd64 fro the PC am able to see some file transactions happening on tftpd but Phone reboots after 3 mins and nothing happens after that
need to understand what's the problem attaching logs for your reference.
Need to understand where is the problem is am directing to the correct way or is there any configuration issue in either tftpd/Switch.
Please asist me as am having five 7945G IP Phones which are having this issue and need to push firmware in those IP Phones.
As am downloaded the firmware in local Laptop am giving IP of my Laptop as option 150 TFTP server in the root directory of tftpd however once I try to run tftpd some file transactions happen and LED of IP phones Blinks for a moment but after exactly 3 minutes port goes down automatically and comes up (i.e Phone restarts)
and again LED blinks for while and same things happens repeatedly
Need to know does Firmware really getting pushed to IP Phone or not.
Please assist as not able to figure out the problem ..
Hi Aok (+5) for excellent explanation...
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hi AyoDeji,
interface Vlan1
ip dhcp pool 40
Hello aokanlawon
after this procedure my problem was solved too, thanks a lot
Leonardo
Hi can u please provide me step by step guide where i can update firmware using my laptop on my faulty 7942 which is having blank display but speak button light on
You are a life saver bro ! keep representing Naija positively..... A simple detail i missed was the base/default SCCP firmware. it was written on the Cisco 7942G. After identifying the correct firmware, i loaded it via TFTP and 50 dead phones came back to life.
