Cisco 7965
adelbenmo
Hi All,
we have Call Manager 6 ,and we want to buy some cisco 7965G phone.
when I try to add a new phone I found only 7965 on the list  — no 7965G
is this mean that I cannot  use 7965G  on our CCM ?
Please kindly advise,
Cheers
Adel
8 Replies 8
Jaime Valencia
Have you tried to configure it???
java
if this helps, please rate
not yet I want to Make sure before  raising the PO.
some one told me that I need to download the firmware for the cisco 7965g
our CCM version is cucm 6.1.2.1000-13
please would you assist
You can add the 7965G phone by selecting 7965 under device menu, there are some other phone you will find listed as G-GE, example 7941G-GE \ 7961 G-GE those have to be added with that option only for successful registration.
below is admin guide just in case
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7965g_7945g/6_0/english/administration/guide/7965-Admin-Book-Wrapper/7965prf.html
Jitender Bhandari
Hi Adel,
I just wanted to add a note to the good tips from Jitender (+5)
The "G" in 7965G stands for global which means that the phone uses global icons for the keys/buttons as discussed in this good blog;
http://www.cxtec.com/blog/3-helpful-tips-about-the-cisco-7900-series/
When you see 7965 in add/device/phone in your options type drop-down that means you are good to go with the 7965G and you can go ahead and place your order.
Cheers!
Rob
[+5] to Rob for sharing the link .
regds,
aman
Thanks Jitender,Rob,
i appreciate you help , i'll go ahead and raise PR/PO
Cheers,
Adel
Hi Rob,
Thanks for putting the Cherry on the top :-)
JB
