Cisco 8300 replacing 2911 FXO
andrew.neff
Beginner
Beginner
I'm swapping out old 2911 with 8300 including an FXO interface for analog phone line.
In "Add a new Gateway" in Call Mgr the 8300 is not listed in "Gateway Type."  Is there a generic choice that would work or do I need Call Mgr upgrade?
My CUCM is System version: 11.5.1.16900-16
2 Accepted Solutions
b.winter
VIP Advisor VIP Advisor
VIP Advisor
According to the compatibility matrix, the Catalyst 8k router are supported from 12.5 SU4 and higher.
Edit: Assuming that MGCP is used as @Roger Kallberg said. If you wanna use SIP, there shouldn't be a problem.
As @b.winter wrote you’ll need to be on CM version 12.5 SU4 or newer to have this model as a selectable option.
Response Signature
8 Replies 8
b.winter
VIP Advisor
Bengaluru-17.6.5
The version of IOS is not really related to this.
Response Signature
Roger Kallberg
VIP Expert VIP Expert
VIP Expert
Assuming that you’re trying to add it as a MGCP gateway? If so you’ll likely need to upgrade your CM to a version that includes this router model. An option would be to use SIP as the control protocol as that’s device agnostic.
Response Signature
2911 running mgcp.  I use same config on 8300, a little different syntax on the card//:
voice-port 1/1/0
signal groundStart
timing hookflash-out 50
timing guard-out 1000
description NOT IN USE
voice-port 1/1/1
description 303.442.2057 - 911 NOT TESTED ON NEW ROUTER
mgcp
mgcp call-agent bldrw-sub.eco.neoninternal.org 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0/0
mgcp bind media source-interface GigabitEthernet0/0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager redundant-host dencl-sub.eco.neoninternal.org dencl-pub.eco.neoninternal.org
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.203.5.71 10.100.103.71
ccm-manager config
dial-peer voice 999020 pots
service mgcpapp
port 1/1/0
dial-peer voice 999021 pots
service mgcpapp
shutdown
port 1/1/1
Response Signature
b.winter
VIP Advisor
@andrew.neff Thank you for not rating my post, which provided you the info in the first place, as an accepted solution^^
sorry, this is my very first post, so just navigating around the buttons has been fun.
I mistook your response for applying to my router version
Recognize Your Peers
