Cisco 880VA ISR as CME?
Hello to all,
We are planning a Voice implementation in a small office, only 2 persons.
We are thinking in Cisco 880VA ISR, because in specifications we saw that supports until 5 IP Phones. We want to know if this router have the same CME features as Cisco 2811 or similar.
Thanks in advance.
Rob Huffman
Hi Maximo,
Yes, the 881V would work great for a 2 person office with expansion to 5 users as you noted;
Q. Is Cisco Unified Communications Manager Express supported on the Cisco 880 Series voice models?
A. Cisco Unified Communications Manager Express is supported on the Cisco 881V and 887VA-V platforms with a 5-user Cisco Unified Communications Manager Express (Cisco Unified CME)/Cisco Unified Survivable Remote Site Telephony (Cisco Unified SRST) license upgrade. The Cisco 880 Series SRST models have SRST support only.
Q. Which version of Cisco Unified Communications Manager Express is supported?
A. Version 8.6 or later.
From;
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/qa_c67_458826.html
Cheers!
Rob
