Cisco 8821 with PushToTalk
Yangjp715
Level 2
Level 2
Hi All,
Is there anyone who knows a Cisco product which supports PushToTalk? Cisco Unified Quick Connect was eos in 2011, but there is no replacement. Additionally, does Cisco 8821 support bar-code scanner?
Thanks in advance,
Eric
Ratheesh Kumar
Hi Eric
Informacast Singlewire supports PTT.
https://www.singlewire.com/pushtotalk.html
Cisco 8821 does not have bar code scanning functionality.
Cheers
Rath!
Hi Rath,
Thanks for your reply.
Is 8821 able to work with Cisco IPICS for PTT if there is no Singlewire paging?
Eric
Hi Eric
Please check this. Hope this is helpful for you.
http://www.cisco.com/c/en/us/products/collateral/physical-security/ipics-server-software/data_sheet_C78-728836.html
Cheers!
Rath
It seems that Cisco IPICS is used for radio system.
