Cisco 8831 3PCC - no admin web interface???
Lbredefe
When I try to login to my 8831 after a hard factory reset, using http, I just get a list of information with NO option to log in and tweak settings so I can make this device work with sip provider.
i type in http://<ipaddress>/admin/
and I get one like if text saying page does not exist on server
i have tried tons of things but if there is no admin login... I have no idea how I will be able to configure it.
41 Replies 41
While you're prepping the phone, make sure the phone is on it's own connection.
Sorry I am a bit new at this ....
So do I need to run your recommended software on a windows server machine to assign DHCP to the phone via a switch
or
can I just setup the phone and Run the software on a windows 10 pro laptop hardwired to their own router that will assign DHCP to both?
(in both cases this would be separate from everything else on the network. )
Run TFTPd64 in your Windows machine. Configure DHCP option 150 using TFTPd64.
Make sure TFTPd64 is pointing to the same directory where the phone files are located.
Thanks Leo I will try it tomorrow morning.
I guess I’m just thinking in my head that the same server that assigns DHCP has to also tell the phone where tftp is. So my worry is based on the fact that the router assigning DHCP is NOT run by the windows laptop... how would it know to find the tftp server created by my laptop? Maybe I am overthinking it. I will do what you said and see if the phone “finds” the laptop and tftpd64 virtual server through my netgear basic blue gigabit switch.
If I don’t put a router in the formula and only use the blue netgear switch, then the only thing that could assign DHCP to the phone is tftpd64 running on windows laptop ... right?
i swear I’m going to make this work lol I just have some noob questions I need to get out of the way so I can solidify a basic understanding.
Leo, alright I have the following running, I have attached screenshots
1) windows 10 laptop plugged into "uplink port" on netgear GS108 switch.
2) phone plugged into a downlink port, currently phone is off. phone also has power adapter ready to be plugged in.
3) TFTPd64 is running on windows 10 laptop with tftp and dhcp ON.
4) option 150 is set to forward to TFTP address
5) tftp is pointed to directory where I will put files
DHCP and tftp are set according to the screenshots, please review and let me know what I am doing wrong. it does not appear to be assigning the phone an IP via the switch. also my adapter, the Realtek family gb/e adapter is grayed out but when I run ipconfig in command prompt it is showing as connected to the switch.
thanks very much for your time.
  1. been working on this all afternoon. I did update the DHCP option 150 address as it had an error in it.
  2. I am concerned my NIC is grayed out in TFTPd64.
  3. I previously said the phone was unplugged and would not pull DHCP, well I plugged the power in and it would not pull DHCP from my laptop running TFTPd64.
  4. also... the NIC on my laptop is set to have a static IP since the switch will not assign it one. let me know if this is correct please sir.
  5. I think i am confused about the relationship between TFTPd64 via my NIC and the switch. is TFTPd64 DHCP server going to assign IP's to the cisco devices plugged into the switch?
  6. I did try plugging my 8831 into a regular router and it pulled DHCP just fine so i believe this is a setting issue.
  7. I am also getting an error message in SFTPd64 saying "communication received from unbound device" - I attached the screenshot.
Leo if you wouldn't mind responding point by point i would immensely appreciate it. I can do this with pretty direct guidance and these items will help clear some confusion.
once again, thank you very much for your time.
Ok, let's try a different direction.
1. Plug your PC and the phone to the router separately.
2. The PC becomes the TFTP server. Note the IP address of the PC.
3. Router supports DHCP function see if DHCP Option 150 can be configured and pointing to the PC.
4. Factory-reset the phone (which will reboot). Take note if the phone gets a valid IP address or not.
awesome ok I can do that.
I ordered the RV320 because it had built in option 150 for DHCP. I have attached a screenshot of it being setup online. I will wait until it comes in, in a couple days and then follow your instruction. I think it auto-assigning DHCP to the phone will help some along with the built in TFTP IP settings with integrated option 150. I will then put the laptop's IP address as the TFTP server and we will work together to configure the TFTP in TFTPd64.
thanks again Leo.
Alright Leo sir,
  1. the RV325 cisco switch is in and configured to point clients to tftp 192.168.1.100 which is the IP of the laptop running TFTP.
  2. tftpd64 is running on the laptop and is "bound" to the dell gigi NIC IP address 192.168.1.100
  3. the phone is PICKING THIS UP :) and showing TFTP IP as 192.168.1.100 on the keypad while the RV325 has assigned it an IP address of 192.168.1.101
  4. TFTPd64 is setup to point to a directory on my desktop that contains the dial plan file and SEPAC44F2130679.cnf.xml which i have done my best to edit and copied below.
  5. the phone is not showing any  status messages popping up like it used to, simply saying "phone not registered" so i assume my config file needs tweaked.
  6. I did not put the firmware in the TFTP folder because it is already installed on the phone, is this ok?
  7. below are the contents of my config file...
<?xml version="1.0" encoding="UTF-8"?>
<device>
<deviceProtocol>SIP</deviceProtocol>
<sshUserId>cisco</sshUserId>
<sshPassword>cisco</sshPassword>
<tzdata>
<tzolsonversion>2015a</tzolsonversion>
<tzupdater>tzupdater.jar</tzupdater>
</tzdata>
<devicePool>
<dateTimeSetting>
<name>CMLocal</name>
<dateTemplate>D/M/YYa</dateTemplate>
<timeZone>AUS Eastern Standard/Daylight Time</timeZone>
<olsonTimeZone>Australia/Sydney</olsonTimeZone>
<ntps>
<ntp>
<name>NTP SERVER IP ADDRESS- i have no idea what this means?</name>
<ntpMode>Unicast</ntpMode>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
<sipPort>5060</sipPort>
<securedSipPort>5061</securedSipPort>
</ports>
<processNodeName>can this be a domain name or MUST it be an IP Address?</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<commonProfile>
<phonePassword></phonePassword>
<backgroundImageAccess>true</backgroundImageAccess>
<callLogBlfEnabled>2</callLogBlfEnabled>
</commonProfile>
<loadInformation>sip9971.9-4-2SR1-2</loadInformation>
<featurePolicyFile>DefaultFP.xml</featurePolicyFile>
<vendorConfig>
<disableSpeaker>false</disableSpeaker>
<disableSpeakerAndHeadset>false</disableSpeakerAndHeadset>
<pcPort>0</pcPort>
<settingsAccess>1</settingsAccess>
<garp>0</garp>
<voiceVlanAccess>0</voiceVlanAccess>
<ciscoCamera>1</ciscoCamera>
<videoCapability>1</videoCapability>
<usbClasses>0,1,2</usbClasses>
<sdio>1</sdio>
<wifi>0</wifi>
<bluetoothProfile>0,1</bluetoothProfile>
<powerNegotiation>0</powerNegotiation>
<autoSelectLineEnable>0</autoSelectLineEnable>
<webAccess>0</webAccess>
<sshAccess>0</sshAccess>
<sshPort>22</sshPort>
<g722CodecSupport>2</g722CodecSupport>
<daysDisplayNotActive>1,7</daysDisplayNotActive>
<displayOnTime>07:00</displayOnTime>
<displayOnDuration>12:00</displayOnDuration>
<displayIdleTimeout>00:15</displayIdleTimeout>
<displayOnWhenIncomingCall>1</displayOnWhenIncomingCall>
<spanToPCPort>1</spanToPCPort>
<loggingDisplay>1</loggingDisplay>
<loadServer></loadServer>
</vendorConfig>
<commonConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<bluetooth>1</bluetooth>
<wifi>0</wifi>
<joinAndDirectTransferPolicy>0</joinAndDirectTransferPolicy>
</commonConfig>
<enterpriseConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<wifi>0</wifi>
<videoCapability>0</videoCapability>
<eapAuthentication>2</eapAuthentication>
<webProtocol>0</webProtocol>
</enterpriseConfig>
<advertiseG722Codec>1</advertiseG722Codec>
<networkLocale>United_States</networkLocale>
<networkLocaleInfo>
<name>United_States</name>
<uid>64</uid>
<version>1.0.0.0-1</version>
</networkLocaleInfo>
<deviceSecurityMode>1</deviceSecurityMode>
<idleTimeout>0</idleTimeout>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesNumber></messagesNumber>
<messagesURL></messagesURL>
<proxyServerURL></proxyServerURL>
<servicesURL>http://cisco.internect.net/</servicesURL>
<dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig>
<dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
<dscpForCm2Dvce>96</dscpForCm2Dvce>
<transportLayerProtocol>2</transportLayerProtocol>
<dndCallAlert>5</dndCallAlert>
<phonePersonalization>1</phonePersonalization>
<rollover>0</rollover>
<singleButtonBarge>0</singleButtonBarge>
<joinAcrossLines>1</joinAcrossLines>
<autoCallPickupEnable>false</autoCallPickupEnable>
<blfAudibleAlertSettingOfIdleStation>0</blfAudibleAlertSettingOfIdleStation>
<blfAudibleAlertSettingOfBusyStation>0</blfAudibleAlertSettingOfBusyStation>
<capfAuthMode>0</capfAuthMode>
<capfList>
<capf>
<phonePort>3804</phonePort>
</capf>
</capfList>
<certHash></certHash>
<encrConfig>false</encrConfig>
<sipProfile>
<sipProxies>
<backupProxy>USECALLMANAGER</backupProxy>
<backupProxyPort>5060</backupProxyPort>
<emergencyProxy>USECALLMANAGER</emergencyProxy>
<emergencyProxyPort>5060</emergencyProxyPort>
<outboundProxy>sip.onsip.com - not sure if this is right?</outboundProxy>
<outboundProxyPort></outboundProxyPort>
<registerWithProxy>true</registerWithProxy>
</sipProxies>
<sipCallFeatures>
<cnfJoinEnabled>true</cnfJoinEnabled>
<callForwardURI>x-cisco-serviceuri-cfwdall</callForwardURI>
<callPickupURI>x-cisco-serviceuri-pickup</callPickupURI>
<callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI>
<callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI>
<meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI>
<abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI>
<rfc2543Hold>false</rfc2543Hold>
<callHoldRingback>2</callHoldRingback>
<localCfwdEnable>true</localCfwdEnable>
<semiAttendedTransfer>true</semiAttendedTransfer>
<anonymousCallBlock>2</anonymousCallBlock>
<callerIdBlocking>2</callerIdBlocking>
<dndControl>1</dndControl>
<remoteCcEnable>true</remoteCcEnable>
<retainForwardInformation>true</retainForwardInformation>
</sipCallFeatures>
<sipStack>
<sipInviteRetx>6</sipInviteRetx>
<sipRetx>10</sipRetx>
<timerInviteExpires>180</timerInviteExpires>
<timerRegisterExpires>3600</timerRegisterExpires>
<timerRegisterDelta>5</timerRegisterDelta>
<timerKeepAliveExpires>120</timerKeepAliveExpires>
<timerSubscribeExpires>120</timerSubscribeExpires>
<timerSubscribeDelta>5</timerSubscribeDelta>
<timerT1>500</timerT1>
<timerT2>4000</timerT2>
<maxRedirects>70</maxRedirects>
<remotePartyID>false</remotePartyID>
<userInfo>None</userInfo>
</sipStack>
<autoAnswerTimer>0</autoAnswerTimer>
<autoAnswerAltBehavior>false</autoAnswerAltBehavior>
<autoAnswerOverride>true</autoAnswerOverride>
<transferOnhookEnabled>false</transferOnhookEnabled>
<enableVad>false</enableVad>
<preferredCodec>none</preferredCodec>
<dtmfAvtPayload>101</dtmfAvtPayload>
<dtmfDbLevel>3</dtmfDbLevel>
<dtmfOutofBand>avt</dtmfOutofBand>
<alwaysUsePrimeLine>true</alwaysUsePrimeLine>
<alwaysUsePrimeLineVoiceMail>true</alwaysUsePrimeLineVoiceMail>
<kpml>3</kpml>
<natEnabled>false</natEnabled>
<natAddress></natAddress>
<stutterMsgWaiting>2</stutterMsgWaiting>
<callStats>false</callStats>
<silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts>
<disableLocalSpeedDialConfig>false</disableLocalSpeedDialConfig>
<startMediaPort>10000</startMediaPort>
<stopMediaPort>20000</stopMediaPort>
<voipControlPort>5060</voipControlPort>
<dscpForAudio>184</dscpForAudio>
<dscpVideo>136</dscpVideo>
<dscpForTelepresence>128</dscpForTelepresence>
<ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy>
<softKeyFile>softKey9971.xml</softKeyFile>
<dialTemplate>dialplan.xml</dialTemplate>
<phoneLabel>Conference</phoneLabel>
<sipLines>
<line button="1" lineIndex="1">
<featureID>9</featureID>
<featureLabel>LABEL</featureLabel>
<name>use username that onsip gave me?</name>
<displayName>Conference</displayName>
<contact>CONTACT</contact>
<proxy>USECALLMANAGER</proxy>
<port>5060</port>
<autoAnswer>
<autoAnswerEnabled>2</autoAnswerEnabled>
</autoAnswer>
<callWaiting>3</callWaiting>
<authName>use auth name that onsip gave me?</authName>
<authPassword>password removed for this post only</authPassword>
<sharedLine>false</sharedLine>
<messageWaitingLampPolicy>3</messageWaitingLampPolicy>
<messageWaitingAMWI>1</messageWaitingAMWI>
<messagesNumber>VOICE MAIL NUMBER</messagesNumber>
<ringSettingIdle>4</ringSettingIdle>
<ringSettingActive>5</ringSettingActive>
<forwardCallInfoDisplay>
<callerName>true</callerName>
<callerNumber>false</callerNumber>
<redirectedNumber>false</redirectedNumber>
<dialedNumber>true</dialedNumber>
</forwardCallInfoDisplay>
<maxNumCalls>4</maxNumCalls>
<busyTrigger>2</busyTrigger>
</line>
<line button="3">
<featureID>21</featureID>
<featureLabel>LABEL BUTTON 2</featureLabel>
<speedDialNumber>NUMBER</speedDialNumber>
<featureOptionMask>1</featureOptionMask>
</line>
<line button="3">
<featureLabel>LABEL BUTTON 3</featureLabel>
</line>
<line button="4">
<featureLabel>LABEL BUTTON 4</featureLabel>
</line>
<line button="5">
<featureLabel>LABEL BUTTON 5</featureLabel>
</line>
<line button="6">
<featureLabel>LABEL BUTTON 6</featureLabel>
</line>
</sipLines>
</sipProfile>
<phoneServices>
<provisioning>0</provisioning>
<phoneService type="1" category="0">
<name>Missed Calls</name>
<url>Application:Cisco/MissedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<phoneService type="2" category="0">
<name>Voicemail</name>
<url>Application:Cisco/Voicemail</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Received Calls</name>
<url>Application:Cisco/ReceivedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Placed Calls</name>
<url>Application:Cisco/PlacedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<phoneService type="0" category="0">
<name>Australian Services</name>
<url>http://cisco.internect.net/</url>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
</device>
<name>put the IP address of the router in here</name>
<outboundProxy>leave this BLANK</outboundProxy>
<processNodeName>Asterisk server IP address or your SIP provider address</processNodeName>
<name>This is just a locally significant name</name>
<authName>Username from the SIP provider</authName>
<authPassword>Password you set</authPassword>
Did you factory-reset the phone?
i just did and now i am seeing status messages!!!!!!!!!
here is as follows:
"Error Verifying Config Info"
"SEPAC44F2130679.cnf.xml"
"No Trust List Installed"
"time zone data download failed"
"error updating locale"
"file not found : soktKey9971.xml"
I can see the phone showing up on the client list in TFTPd62, about every minute or so it pops on for about 5 seconds then drops off client list on the TFTP server tab so that is some progress!!!!
i have pasted the config file again below AND THE TFTPD64 SERVER LOG after making your changes... and yes, i do have the RV325 plugged into my home router via WAN port so I am getting internet to the RV325.
onsip did not provide a server IP, just the following in the attachments..so i did a domain to IP converter.... please see attachements.
config file copied below:
<device>
<tzdata>
</tzdata>
<devicePool>
<dateTimeSetting>
<ntps>
<ntp>
<name>192.168.1.1</name>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<callManager>
<ports>
</ports>
<processNodeName>199.7.172.27</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<commonProfile>
</commonProfile>
<vendorConfig>
<pcPort>0</pcPort>
<garp>0</garp>
<sdio>1</sdio>
<wifi>0</wifi>
</vendorConfig>
<commonConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<wifi>0</wifi>
</commonConfig>
<enterpriseConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<wifi>0</wifi>
</enterpriseConfig>
<networkLocaleInfo>
<uid>64</uid>
<idleURL></idleURL>
<capfList>
<capf>
</capf>
</capfList>
<sipProfile>
<sipProxies>
<outboundProxy></outboundProxy>
</sipProxies>
<sipCallFeatures>
</sipCallFeatures>
<sipStack>
</sipStack>
<kpml>3</kpml>
<sipLines>
<name>lbredefe</name>
<port>5060</port>
<autoAnswer>
</autoAnswer>
<authName>removed for forum post</authName>
<authPassword>removed for forum post</authPassword>
</line>
<line button="3">
</line>
<line button="3">
</line>
<line button="4">
</line>
<line button="5">
</line>
<line button="6">
</line>
</sipLines>
</sipProfile>
<phoneServices>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<name>OnSip</name>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
</device>
TFTPD64 SERVER LOG - 5 basic events repeating
Connection received from 192.168.1.101 on port 37743 [17/05 12:10:22.415]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:10:22.415]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:10:22.415]
Connection received from 192.168.1.101 on port 47351 [17/05 12:10:32.326]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:10:32.326]
Using local port 57262 [17/05 12:10:32.327]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:10:32.361]
Connection received from 192.168.1.101 on port 54920 [17/05 12:11:22.753]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:11:22.753]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:11:22.753]
Connection received from 192.168.1.101 on port 39131 [17/05 12:11:32.554]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:11:32.554]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:11:32.555]
Connection received from 192.168.1.101 on port 53011 [17/05 12:11:42.326]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:11:42.326]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:11:42.327]
then this is the same thing repeating over and over again
Connection received from 192.168.1.101 on port 42703 [17/05 12:11:52.233]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:11:52.233]
Using local port 55821 [17/05 12:11:52.248]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:11:52.263]
Connection received from 192.168.1.101 on port 59100 [17/05 12:12:42.633]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:12:42.633]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:12:42.634]
Connection received from 192.168.1.101 on port 47329 [17/05 12:12:52.378]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:12:52.378]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:12:52.378]
Connection received from 192.168.1.101 on port 56776 [17/05 12:13:02.263]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:13:02.263]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:13:02.264]
Connection received from 192.168.1.101 on port 52799 [17/05 12:13:12.174]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:13:12.175]
Using local port 52631 [17/05 12:13:12.175]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:13:12.204]
Connection received from 192.168.1.101 on port 53231 [17/05 12:13:56.327]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:13:56.328]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:13:56.328]
Connection received from 192.168.1.101 on port 40825 [17/05 12:14:05.458]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:14:05.458]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:14:05.458]
Connection received from 192.168.1.101 on port 50314 [17/05 12:14:14.558]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:14:14.558]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:14:14.559]
Connection received from 192.168.1.101 on port 59563 [17/05 12:14:24.099]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:14:24.099]
Using local port 60469 [17/05 12:14:24.099]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:14:24.114]
Connection received from 192.168.1.101 on port 38924 [17/05 12:15:07.482]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:15:07.482]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:15:07.482]
Connection received from 192.168.1.101 on port 34466 [17/05 12:15:16.580]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:15:16.580]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:15:16.581]
Connection received from 192.168.1.101 on port 48001 [17/05 12:15:25.690]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:15:25.690]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:15:25.690]
Connection received from 192.168.1.101 on port 60674 [17/05 12:15:35.096]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:15:35.096]
Using local port 50143 [17/05 12:15:35.096]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:15:35.127]
Connection received from 192.168.1.101 on port 34372 [17/05 12:16:18.498]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:16:18.498]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:16:18.499]
Connection received from 192.168.1.101 on port 37663 [17/05 12:16:27.589]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:16:27.589]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:16:27.589]
Connection received from 192.168.1.101 on port 42390 [17/05 12:16:36.699]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:16:36.699]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:16:36.699]
Connection received from 192.168.1.101 on port 33740 [17/05 12:16:46.128]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:16:46.128]
Using local port 56771 [17/05 12:16:46.128]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:16:46.152]
Connection received from 192.168.1.101 on port 49377 [17/05 12:17:29.449]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:17:29.449]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:17:29.450]
Connection received from 192.168.1.101 on port 39758 [17/05 12:17:38.589]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:17:38.589]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:17:38.590]
Connection received from 192.168.1.101 on port 57028 [17/05 12:17:47.708]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:17:47.708]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:17:47.709]
Connection received from 192.168.1.101 on port 50903 [17/05 12:17:57.201]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:17:57.201]
Using local port 58385 [17/05 12:17:57.201]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:17:57.233]
Connection received from 192.168.1.101 on port 53296 [17/05 12:18:40.862]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:18:40.862]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:18:40.863]
Connection received from 192.168.1.101 on port 56349 [17/05 12:18:50.000]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:18:50.000]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:18:50.000]
Connection received from 192.168.1.101 on port 46681 [17/05 12:18:59.132]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:18:59.132]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:18:59.133]
Connection received from 192.168.1.101 on port 57494 [17/05 12:19:08.600]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:19:08.600]
Using local port 54301 [17/05 12:19:08.600]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:19:08.622]
Connection received from 192.168.1.101 on port 43585 [17/05 12:19:51.902]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:19:51.902]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:19:51.902]
Connection received from 192.168.1.101 on port 44451 [17/05 12:20:01.084]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:20:01.084]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:20:01.084]
Connection received from 192.168.1.101 on port 37425 [17/05 12:20:10.223]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:20:10.223]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:20:10.224]
Connection received from 192.168.1.101 on port 45714 [17/05 12:20:19.793]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:20:19.793]
Using local port 63931 [17/05 12:20:19.793]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11840 bytes in 0 s. 0 blk resent [17/05 12:20:19.814]
Connection received from 192.168.1.101 on port 44745 [17/05 12:21:03.302]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:21:03.302]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:21:03.302]
Connection received from 192.168.1.101 on port 50781 [17/05 12:21:12.453]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:21:12.453]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:21:12.454]
Connection received from 192.168.1.101 on port 53077 [17/05 12:21:21.632]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:21:21.632]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:21:21.632]
Connection received from 192.168.1.101 on port 44409 [17/05 12:21:31.111]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:21:31.111]
Using local port 52810 [17/05 12:21:31.111]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11820 bytes in 0 s. 0 blk resent [17/05 12:21:31.127]
Connection received from 192.168.1.101 on port 50262 [17/05 12:21:49.166]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:21:49.166]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:21:49.166]
Connection received from 192.168.1.101 on port 47174 [17/05 12:22:03.979]
Read request for file </sl-sip.jar>. Mode octet [17/05 12:22:03.980]
File <sl-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:22:03.980]
Connection received from 192.168.1.101 on port 56317 [17/05 12:22:11.798]
Read request for file <sip9971.9-4-2SR1-2.loads>. Mode octet [17/05 12:22:11.798]
File <sip9971.9-4-2SR1-2.loads> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:22:11.799]
Connection received from 192.168.1.101 on port 47454 [17/05 12:22:16.584]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:22:16.585]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:22:16.585]
Connection received from 192.168.1.101 on port 57625 [17/05 12:22:26.031]
Read request for file <United_States/g3-tones.xml>. Mode octet [17/05 12:22:26.031]
File <United_States\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [17/05 12:22:26.031]
Connection received from 192.168.1.101 on port 56178 [17/05 12:22:39.034]
Read request for file <dialplan.xml>. Mode octet [17/05 12:22:39.034]
Using local port 60547 [17/05 12:22:39.036]
<dialplan.xml>: sent 1 blk, 104 bytes in 0 s. 0 blk resent [17/05 12:22:39.037]
Connection received from 192.168.1.101 on port 34869 [17/05 12:22:48.246]
Read request for file <softKey9971.xml>. Mode octet [17/05 12:22:48.246]
File <softKey9971.xml> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:22:48.247]
Connection received from 192.168.1.101 on port 60749 [17/05 12:23:05.180]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:23:05.180]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:23:05.181]
Connection received from 192.168.1.101 on port 56703 [17/05 12:23:15.028]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:23:15.028]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:23:15.028]
Connection received from 192.168.1.101 on port 48797 [17/05 12:23:24.882]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:23:24.882]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:23:24.883]
Connection received from 192.168.1.101 on port 49891 [17/05 12:23:34.752]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:23:34.752]
Using local port 63985 [17/05 12:23:34.752]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11820 bytes in 0 s. 0 blk resent [17/05 12:23:34.764]
Connection received from 192.168.1.101 on port 58292 [17/05 12:23:55.869]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:23:55.869]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:23:55.869]
Connection received from 192.168.1.101 on port 38387 [17/05 12:24:07.395]
Read request for file </sl-sip.jar>. Mode octet [17/05 12:24:07.395]
File <sl-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:24:07.396]
Connection received from 192.168.1.101 on port 38733 [17/05 12:24:17.553]
Read request for file <sip9971.9-4-2SR1-2.loads>. Mode octet [17/05 12:24:17.553]
File <sip9971.9-4-2SR1-2.loads> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:24:17.554]
Connection received from 192.168.1.101 on port 56702 [17/05 12:24:21.952]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:24:21.952]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:24:21.952]
Connection received from 192.168.1.101 on port 58218 [17/05 12:24:31.860]
Read request for file <United_States/g3-tones.xml>. Mode octet [17/05 12:24:31.860]
File <United_States\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [17/05 12:24:31.861]
Connection received from 192.168.1.101 on port 51478 [17/05 12:24:46.372]
Read request for file <dialplan.xml>. Mode octet [17/05 12:24:46.372]
Using local port 61666 [17/05 12:24:46.373]
<dialplan.xml>: sent 1 blk, 104 bytes in 0 s. 0 blk resent [17/05 12:24:46.374]
Connection received from 192.168.1.101 on port 45797 [17/05 12:24:56.179]
Read request for file <softKey9971.xml>. Mode octet [17/05 12:24:56.179]
File <softKey9971.xml> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:24:56.179]
Connection received from 192.168.1.101 on port 55868 [17/05 12:28:11.723]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:28:11.723]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:28:11.723]
Connection received from 192.168.1.101 on port 43188 [17/05 12:28:22.373]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:28:22.373]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:28:22.374]
Connection received from 192.168.1.101 on port 51513 [17/05 12:28:32.737]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:28:32.737]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:28:32.737]
Connection received from 192.168.1.101 on port 50922 [17/05 12:28:42.682]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:28:42.682]
Using local port 49431 [17/05 12:28:42.682]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11820 bytes in 0 s. 0 blk resent [17/05 12:28:42.713]
Connection received from 192.168.1.101 on port 49648 [17/05 12:29:01.801]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:29:01.801]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:29:01.801]
Connection received from 192.168.1.101 on port 56626 [17/05 12:29:12.769]
Read request for file </sl-sip.jar>. Mode octet [17/05 12:29:12.769]
File <sl-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:29:12.769]
Connection received from 192.168.1.101 on port 42911 [17/05 12:29:20.061]
Read request for file <sip9971.9-4-2SR1-2.loads>. Mode octet [17/05 12:29:20.061]
File <sip9971.9-4-2SR1-2.loads> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:29:20.061]
Connection received from 192.168.1.101 on port 50046 [17/05 12:29:25.231]
Read request for file <United_States/g3-tones.xml>. Mode octet [17/05 12:29:25.231]
File <United_States\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [17/05 12:29:25.231]
Connection received from 192.168.1.101 on port 55067 [17/05 12:29:36.370]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:29:36.370]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:29:36.370]
Connection received from 192.168.1.101 on port 49620 [17/05 12:29:45.559]
Read request for file <dialplan.xml>. Mode octet [17/05 12:29:45.559]
Using local port 56215 [17/05 12:29:45.560]
<dialplan.xml>: sent 1 blk, 104 bytes in 0 s. 0 blk resent [17/05 12:29:45.562]
Connection received from 192.168.1.101 on port 39276 [17/05 12:29:54.759]
Read request for file <softKey9971.xml>. Mode octet [17/05 12:29:54.759]
File <softKey9971.xml> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:29:54.759]
Connection received from 192.168.1.101 on port 43696 [17/05 12:33:07.020]
Read request for file <CTLSEPAC44F2130679.tlv>. Mode octet [17/05 12:33:07.020]
File <CTLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:33:07.020]
Connection received from 192.168.1.101 on port 39889 [17/05 12:33:17.638]
Read request for file <ITLSEPAC44F2130679.tlv>. Mode octet [17/05 12:33:17.638]
File <ITLSEPAC44F2130679.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:33:17.639]
Connection received from 192.168.1.101 on port 47890 [17/05 12:33:30.027]
Read request for file <ITLFile.tlv>. Mode octet [17/05 12:33:30.027]
File <ITLFile.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:33:30.027]
Connection received from 192.168.1.101 on port 35026 [17/05 12:33:43.447]
Read request for file <SEPAC44F2130679.cnf.xml>. Mode octet [17/05 12:33:43.447]
Using local port 52901 [17/05 12:33:43.448]
<SEPAC44F2130679.cnf.xml>: sent 24 blks, 11820 bytes in 0 s. 0 blk resent [17/05 12:33:43.497]
Connection received from 192.168.1.101 on port 54155 [17/05 12:34:05.106]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:34:05.106]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:34:05.106]
Connection received from 192.168.1.101 on port 38671 [17/05 12:34:16.038]
Read request for file </sl-sip.jar>. Mode octet [17/05 12:34:16.038]
File <sl-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:34:16.039]
Connection received from 192.168.1.101 on port 53703 [17/05 12:34:25.426]
Read request for file <sip9971.9-4-2SR1-2.loads>. Mode octet [17/05 12:34:25.426]
File <sip9971.9-4-2SR1-2.loads> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:34:25.441]
Connection received from 192.168.1.101 on port 58243 [17/05 12:34:30.101]
Read request for file <tzupdater.jar>. Mode octet [17/05 12:34:30.101]
File <tzupdater.jar> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:34:30.101]
Connection received from 192.168.1.101 on port 58897 [17/05 12:34:39.780]
Read request for file <United_States/g3-tones.xml>. Mode octet [17/05 12:34:39.780]
File <United_States\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [17/05 12:34:39.781]
Connection received from 192.168.1.101 on port 57966 [17/05 12:34:53.658]
Read request for file <dialplan.xml>. Mode octet [17/05 12:34:53.658]
Using local port 50764 [17/05 12:34:53.659]
<dialplan.xml>: sent 1 blk, 104 bytes in 0 s. 0 blk resent [17/05 12:34:53.660]
Connection received from 192.168.1.101 on port 37365 [17/05 12:35:03.333]
Read request for file <softKey9971.xml>. Mode octet [17/05 12:35:03.333]
File <softKey9971.xml> : error 2 in system call CreateFile The system cannot find the file specified. [17/05 12:35:03.333]
<line button="3">
</line>
<line button="3">
</line>
<line button="4">
</line>
<line button="5">
</line>
<line button="6">
Above, take these lines off.
<messagesNumber>12345</messagesNumber>
Above, change that.
Save the config, factory reset the phone.
Let's see if this works.
alright made those changes, and copied in config file below, phone is saying "phone not registered" still, and when i hit the apps button, i no longer see "onsip" on the menu as #5 although not sure that matters or if that is a good thing since when i would select it previously it would basically list the entire config file with an error flag at the top.
do you think i should just try this with a trial of asterisk (meaning using their creds) instead of onsip since people here have experience using asterisk it seems?
trying to make it easier for you to help me.
config file pasted below:
<device>
<tzdata>
</tzdata>
<devicePool>
<dateTimeSetting>
<ntps>
<ntp>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<callManager>
<ports>
</ports>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<commonProfile>
</commonProfile>
<vendorConfig>
<pcPort>0</pcPort>
<garp>0</garp>
<sdio>1</sdio>
<wifi>0</wifi>
</vendorConfig>
<commonConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<wifi>0</wifi>
</commonConfig>
<enterpriseConfig>
<usb1>1</usb1>
<usb2>1</usb2>
<sdio>1</sdio>
<wifi>0</wifi>
</enterpriseConfig>
<networkLocaleInfo>
<uid>64</uid>
<idleURL></idleURL>
<capfList>
<capf>
</capf>
</capfList>
<sipProfile>
<sipProxies>
</sipProxies>
<sipCallFeatures>
</sipCallFeatures>
<sipStack>
</sipStack>
<kpml>3</kpml>
<sipLines>
<port>5060</port>
<autoAnswer>
</autoAnswer>
<authName>removed for this post only</authName>
<authPassword>removed for this post only</authPassword>
</line>
</line>
</sipLines>
</sipProfile>
<phoneServices>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<vendor></vendor>
<version></version>
</phoneService>
<name>OnSip</name>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
</device>
