There are some paremeter to check.
Is your phone receiving networking info from a DHCP Server.
If yes, is the DNS Serfer info included?
I also suggest to check LAN Interface configuration on the switch you are connecting your phone.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
