09-02-2024
02:03 PM
- last edited on
09-02-2024
06:22 PM
by
shule
I am honestly clueless. I installed CUCM in my homelab for fun mind you ive installed 100ish CUCMs in the past and have never had this problem when it came to cucm. My phones are giving me an SRP error and it feels like no one on the internet know how to help. If anyone on here does know I would be forever grateful.
The logs boil down to this:
Configuring IP
ITL Installed
File not found SEP(ciscophone).cnf.xml.sgn
XMLDefault.cnf.xml.sgn (HTTP) - I am assuming it taking a default template of some sort.
The SRP Register failed.
I have tried fixing my DNS bc it was yelling at me about my dns but that did nothing. I tried setting the DNS Records too for example my cucm is "PREMNetworksCUCM01.PremNetworks.org" (that's not on the public internet don't worry just a homelab dns
i tried adding that URL into my DNS and it didn't work. I feel so lost so if someone could help it would make my day.
09-03-2024 04:49 AM
The SRP error you're encountering with CUCM can be challenging, especially when it appears to stem from configuration files not being found. Here are some steps you can take to troubleshoot and potentially resolve the issue:
These steps should help narrow down the issue and get your phones to register successfully. If the problem persists, you might need to perform a deeper dive into the specific configuration settings or even re-examine the CUCM installation itself.
09-03-2024 05:15 AM
Look at your DHCP server in your Unify switch. What is the configuration of the DHCP Option 150?
09-03-2024 06:16 AM
If your Status messages don't show a DHCP timeout nor a TFTP timeout, then you can assume they are reaching a CUCM server that has the TFTP service is active. If you have "File Not Found" then for some reason CUCM is not recognizing them as phones that already exist in the CUCM database. Are the phones built on CUCM? Are they built with the correct model (and protocol - if they are old enough to still allow SCCP)? What happens if you turn on Auto-Registration, do they register?
I've been working with Cisco phones for a couple of decades and don't recognize "SRP" as a phone-related 'thing'. Can you confirm that error? Or did you mean to type "The SIP Register failed."?
Maren
09-04-2024 02:15 AM
The “File not found SEP(ciscophone).cnf.xml.sgn” error clearly indicates that the configuration file for your MAC address is not found on the CUCM. It’s trying to use the default profile, which will never register like SCCP phones.
Please check if you have configured the phone on CUCM with the correct MAC address.
On the Cisco phone, verify that it has the correct TFTP address, which should be your Call Manager server IP address.
As @Maren Mahoney highlighted, even I can’t recognize SRP.
