Does anyone knows if the Plantronics C054 is fully compatible with the plantronics C054 wireless headset? Thanks
-Cesar Fiestas
Solved! Go to Solution.
Hi Cesar,
Yes the CS540 is fully compatible with the 8851 with the use of the APU-72 EHS cord.
http://www.plantronics.com/us/compatibility-guide/#/search/
Cheers!
Rob
Hi Cesar,
Cheers!
Rob
Rob,
Thanks for your answer and your time I appreciated.
Cesar Fiestas
