I hope everyone is doing OK> I am trying to order a cisco 3925 chassis to be configured with SRST and as a CUBE VG to interact with the PSTN using SIP.
but I have a question in regards to the software part number for the IOS version that is.
Do I need the following parts for one chassis;
L-SL-39-UC-K9= or S39UK9-15001M ?
AND
L-SL-39-UC-K9=
OR
just S39UK9-15001M for the ios version?
Thanks is advance!
Solved! Go to Solution.
If you need the router base license "SL-39-IPB-K9" and UC license i.e. "SL-39-UC-K9", plus if you want to use it as CUBE you need appropriate number of CUBE licenses.
Chris,
Thanks for the clarification. Appreciated.
-Cesar Fiestas
