Cisco 8945 phones will not work with LLDP
Quintin.Mayo
Level 3
Level 3
We have a mixture of 7900 and 8945 series phones and using the LLDP discovery protocol. When testing the phones we found the 7900 series works fine but the 8945 phones are having issues. We conducted a packet capture and found the 8945 phone is getting the LLDP request, but not joining the voice VLAN 20. Traffic from phones are staying on VLAN 10 (default native VLAN) Problem is with 8945 phones only. Customer is using non-Cisco switches Fortinet. Any assistance would be greatly appreciated.
Cisco 8945 Device Protocol: SCCP
SCCP894x.9-4-2SR3-1
Phone Type Product Type: Cisco 8945
Real-time Device Status
Registration: Registered with Cisco Unified Communications Manager
IPv4 Address: x.x.x.x
Active Load ID: SCCP894x.9-4-2SR3-1
Download Status: None
Ratheesh Kumar
Hi there
Cisco 8945 supports LLDP.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/10_0/english/admin_guide/P415_BK_AA30369C_00_adminguide-8941-8945-10_0.pdf
May be you are hitting the bug CSCub98603
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCub98603/?rfs=iqvred
Symptom:
IP Phone 8945 using sip firmware doesn't communicate in the proper VLAN.
Conditions:
When the following conditions are met:
- using third party switches with LLDP enabled or Cisco switches with CDP disabled and LLDP enabled
- the phone is configured to use both LLDP and CDP
Workaround:
Disable CDP and reset the phone using the call agent. For example in the CUCM Administration pages disable "Cisco Discovery Protocol (CDP): Switch PortRequired" on the phone configuration page.
Try the above workaround. If that doesnt work match the config as explained in the below link. Then try upgrading the firmware of the phones.
https://forum.fortinet.com/tm.aspx?m=152838
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
kevin crowley
I was looking at cisco unified ip phone 9841 and 8945 guide. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/10_0/english/admin_guide/P415_BK_AA30369C_00_adminguide-8941-8945-10_0.pdf.
One the protocols used is LLDP.
But I also saw LLDP-MED (Link Layer Discovery Protocol-Media Endpoint Devices). One of the things this does is communicate information such as Voice VLAN CONFIGURATION.
Have you done a packet capture to search for this?
