Cisco 8945 video call
I buy a Cisco 8945 phone, and register on the CUCM, but I couldn't make a video call. it says "Video not available for the call, remote device is not video enabled". Who can help me? Thanks.
Hope you are calling between video  phones.
Check if video enabled on CUCM phone page.
if enabled
Enable Video Capability
If your system administrator enables video on the Cisco Unified Communications Manager, you can enable your phone to send video.
Procedure
Step 1   Press Applications
Step 2   Use the Navigation pad and Select button to select Preferences.
Step 3   Select Camera.
Step 4   Select Video and press Edit.
Step 5   Select On or Off.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/10_0/english/user_guide/P415_BK_UD805A4F_00_user-guide-8941-8945-10_0/P415_BK_UD805A4F_00_user-guide-8941-8945-10_0_chapter_01001.html
Response Signature
if enabled
Procedure
Response Signature
Thank you, I will try your suggestion.
Thanks for your suggestion. Now, I can make a call between cisco phone. But I have a other brand phone that is Yealink SIP-T58A phone. And I make a video call from Cisco 8945 to Yealink phone. But if failed. I want to export the pcap file to do further analysis. But I don't know how to export, could you give me some advice? Many thanks.
