06-18-2018 05:11 AM - edited 03-17-2019 01:01 PM
I have a Cisco ASA 5510 Version 9.1(7)9 with multiple tunnels, (2) of which have duplicate hosts. These 2 tunnels are completely separate no communication between the two. The Chicago tunnel was just added and appears to be having issues with 105.180.90.16 passing traffic.
Can I have duplicate hosts like this ? dev1 and Chicago-local share a local IP too 192.168.68.58
nat (INSIDE,OUTSIDE) source static dev1 dev1-Global destination static kansas kansas
object-group network kansas
network-object 105.180.90.16 255.255.255.255
object-group network Chicago-remote
nat (INSIDE,OUTSIDE) source static Chicago-local Chicago-local destination static Chicago-remote Chicago-remote no-proxy-arp route-lookup
06-18-2018 05:30 AM
Hi there
I wish you could post this under the Network or Security section as this is for IP Telephony.
https://supportforums.cisco.com/t5/network-infrastructure/ct-p/4461-network-infrastructure
https://supportforums.cisco.com/t5/security/ct-p/4561-security
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-18-2018 05:52 AM
I posted in the appropriate forum, how can I delete this post ?
06-18-2018 06:02 AM
As I responded, you might lose that option to delete it. The only time a post can be deleted by a member is if no one else has responded to the discussion. In order to delete a discussion that has responses you need to submit a request to supportforums-info@cisco.com.
Hope this helps!
Cheers
Rath!
