cisco ATA 191 RJ11 cable distance limitations
mzee.sidd
There are 3 analog phones connected in three lifts i.e. one analog phone in each lift coming from IT server room(Siemens PBX) and we would be removing the Siemens PBX and connect an ATA 191 for analog phones connectivity. I wanted to know whether there will any communication issue or any other problem as about how far an analog device could be controlled from ATA 191 with cable length is around 300metres from IT server room to the lifts i.e. between ATA and analog phones in the lifts.
Thanks.
Adam Pawlowski
The data sheet shows the maximum load at 3 REN , and there's an older community post here which describes what you want
https://community.cisco.com/t5/ip-telephony-and-phones/maximum-length-of-a-single-twisted-pair-run/td-p/1476757
It appears to refer to this:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccp/sccpach5.pdf
Which is listening a table of loop length to REN I guess based on the loop current. It also suggests under it that you try it and see if it works. 1000 feet doesn't seem to be excessive, and I've not encountered many analog phone devices which had a problem, though some older microprocessor designs were sensitive, only discovered after testing.
mzee.sidd
Hi Adam,
Thanks for the information. Also, Will test it out to see the results.
