Cisco ATA for Faxes
sienz.sienz
We are trying to convert some of analog lines to our CUCM 8.6.  Anyone knows which Cisco ATA should be use that support Faxes?
Thank you
Harmit Singh
Hi sienz,
I'm assuming you are referring to Cisco ATA 187.
The Cisco ATA supports two modes of fax services, in which fax signals are transmitted using the G.711 codec:
•  Fax pass-through mode: The mode enables receiver-side  called-station-identification (CED) tone detection with automatic  G.711A-law or G.711μ-law switching.
•  T38 fax relay mode: The T.38 fax relay feature enables devices to use  fax machines to send files over the IP network. In general, when a fax  is received, it is converted to an image, sent to the T.38 fax device,  and converted back to an analog fax signal. T.38 fax relays configured  with voice gateways decode or demodulate the fax signals before they are  transported over IP.
Note:  Success of fax transmission depends on network conditions and the fax  modem response to these conditions. The network must have reasonably low  network jitter, network delay, and packet loss rate.
Here is a link for the data sheet of ATA 187:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps514/ps11026/data_sheet_c78-608596.html
HTH.
Harmit.
