cisco BE6K HA
Dear All,
Please advise on the issue below
we've installed BE6K with version 9.1(2) (CUCM, CUC and IM&P) two years back and now upgrading it to version 11.0. once we complete the upgrade we want deploy high availability and we've ordered new BE6M-M4-K9=. server. Are we required to add any licenses to make the HA up and running ?
2 Accepted Solutions
Jitender Bhandari
Hi Kennedy,
you dont need a separate license for the new server for redundancy if that's what you meant, but you will have to get you license migrated to 11 once you upgrade.
check the below link for more details
http://docwiki.cisco.com/wiki/Implementing_BE_6000_9.0
JB
Adding to what Jitender is saying, licensing model has changed starting version 9 and is based on user licenses now instead of SW, Feature, DLUs as it used to be till 8.x. Hence simply go ahead and purchase the new BE6K, deploy CM on it add to the existing cluster nothing to worry about the licenses.
Deepak
7 Replies 7
Jitender Bhandari
Hi Kennedy,
JB
Hi Jitender,
thanks for your valuable response
For the upgrade (9.1(2) to 11.0) we've ordered the licenses below. our issue was if we're required to have HA license for CUCM, CUC and IM&P applications.
R-CBE6K-K9 Cisco Business Edition 6000-Electronic SW Delivery-Top Level
CON-ECMU-RCBE6KK SWSS UPGRADES Cisco Business Editi
BE6K-SW-11.0 Business Edition 6000 v11 export restricted software
UPG-6K-STD BE6000 CUWL Standard - SW Upgrade
UC-9.X Version 9.x
EXPWY-VE-C-K9 Cisco Expressway-C Server, Virtual Edition
EXPWY-VE-E-K9 Cisco Expressway-E Server, Virtual Edition
SW-EXP-8.X-K9 Software Image for Expressway with Encryption, Version X8
UPG-UCM9TO11-STD UC Manager Upgrade STD, v9.x to v11.x, 1 user
BE-UWL-11X-STD BE6000 CUWL Standard 11.x Users - Service Use Only
CON-ECMU-BEUWLSTD SWSS UPGRADES BE6000 CUWL Standard 11.x Users - Servic
UPG-UCXN9TO11-STD Unity Connection Upgrade STD, v9.x to v11.x, 1 user
LIC-EXP-E-PAK Expressway Series, Expressway-E PAK
LIC-EXP-GW Enable GW Feature (H323-SIP)
LIC-EXP-E Enable Expressway-E Feature Set
LIC-EXP-TURN Enable TURN Relay Option
LIC-EXP-AN Enable Advanced Networking Option
LIC-SW-EXP-K9 License Key Software Encrypted
LIC-EXP-SERIES Enable Expressway Series Feature Set
BE6K-UPG-PAK Cisco Business Edition 6K Upg - PAK - Partial Fulfillment
Hi Kennedy,
As informed above we don't need any license for redundancy that is more of configuration then license.
If you need more information on licensing you can look at below links
https://supportforums.cisco.com/document/9869241/understanding-enterprise-license-manager
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmfeat/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100/CUCM_BK_F3AC1C0F_00_cucm-features-services-guide-100_chapter_0100101.html
JB
does that answer your question Kennedy
JB
Hi JB,
It's clear now and I'm about to start the deployment based on your confirmation
Many Thanks
Happy to help
JB
Deepak
