Cisco Jabber for iPhone - Expressway Edge - Phone Services Not Working
Network Admin
We have Collaboration Edge Deployed.
Notes : 1. We are using CUCM 10.5.2 and no jabber-config.xml file exist.
             2. We have Split DNS. Though we have CUCM , IMP etc in company.local , users login both from inside and outside as user@company.com
Cisco Jabber for Android and  Jabber for Windows is working fine from Internet.
Cisco Jabber for iPhone is Working fine from inside network locally. But Cisco Jabber for iPhone is not connected to Phone Services when connected from internet through Expressway Edge. What could be the issue ?
7 Replies 7
Ayodeji Okanlawon
Is jabber for iPhone connected to the IM and P server? So is it only phone services that doesn't work?
Please rate all useful posts
We can not log in from Cisco Jabber from iPhone means its not even logged in to IM and P. I can login all other devices and am able get them worked and connected to Phone services / IM and P / Voicemail etc
Okay..can you please send the logs for jabber for iphone?
I have same problem mra client can login via internet as well but can not connect phone services
if user login using with csf device  phone services does not work but when user login with tct device phone services works fine.
I uploaded expc/e and jabber cleint logs and found  401 not authorised error expc and e
SIPMSG:
 |SIP/2.0 401 Unauthorised
 Via: SIP/2.0/TLS 192.168.100.30:5061;branch=z9hG4bK984e55b4366c5ca7f0405b1f53f810a51538;received=192.168.100.30;rport=25004
 Call-ID: c1a133987b08ea23@192.168.100.30
 CSeq: 25035 OPTIONS
 To: <sip:90.158.111.150:7001>;tag=0910f74914a8ea0f
 Server: TANDBERG/4132 (X8.7.3)
 WWW-Authenticate: Digest realm="Traversal Server  (MRA)", nonce="b7bc5007b91ed029d2a65e099b90783b30e4028984c53020fa6d2e7fb2c0", opaque="AQAAACMsvd0cCOFwdoQkESuqE2n/Lf3S", stale=FALSE, algorithm=MD5, qop="auth"
 Content-Length: 0
This looks like problem with Travelsal zone configuration, password for traversal zone being incorrect.
Can you go to your Traversal client (VCS-C) Zone configuration and check what's the peer address status?
Leszek
All zone is seems active , sip peer is active on vcs traversal client.
SIP: Reachable: x.x.x.x:7001
Did you ever resolve this issue? I am having the same problem. When I look at the client log it does not seem to attempt to use the collab-edge srv record.
