Cisco C3560E-POE48 issue with PoE on some ports
JunaidM
I have a Cisco 3560 E Series Switch with 48 PoE ports, all PoE ports were working properly in my office, it happened that we did not used it for about 6 months and when we installed it back in operational environment only 19 interfaces worked as PEO and 29 ported did not worked on POE.
All ports are working good with data traffic but for PoE I are facing serious issue as I have to resolve this issue.
Anyone please help for the resolution , will be thankful if it could get resolved.
25 Replies 25
Leo Laohoo
When connecting something to port 2, what does the logs say?
NOTE:  Update the firmware of the switch.  I suspect the ports are dead.
When I connect my Laptop it start working normally at port 2 but when I connect IP Phone on the same port it do not work, total 29 ports of this switch are in same condition.
For this how can I generate a report of that and if I make any decision I need to let my management understand the exact reason.
Logs are normal when connecting an IP Phone on interface gi0/1 that power is granted and port is UP, but there is not log showing when connected to port gi0/2.
Please advice.
I have attached debug all logs can you please check if anything is found from this, I connected the IP Phone on interface gi0/2 which was not working and ENTERED the command debug all so this result came out.
Please do the needful, I believe debug logs will help out to find the issue.
balaji.bandi
we have missed the debug logs here - are you using same Cable was working with Port 1 and 2 ?
Do you have any patch pannel ?
BB
Debug file is removed by this platform automatically, I am using this switch in my table no other port is connected except my 1 cable which I was changed but in vain the situation was same.
Switch#debug all
This may severely impact network performance. Continue? (yes/[no]): yes
All possible debugging has been turned on
Switch#
*Mar 1 02:52:49.778: VR Iter=0x00038792, FLCD Iter=0x000678FC, FLCD Invokes=0x0CC514E6
*Mar 1 02:52:49.795: Cur-Clk 0x00000128 (1 usec), Max-Clk 0x0000172F (23 usec)
*Mar 1 02:52:49.795: special_oce_change_vectorsSent on 0 frame 78003F8
Received: pak 3B99374 datagramstart 7BD1E76
*Mar 1 02:52:49.795: Iter = 422776, Invokes = 213458097
*Mar 1 02:52:49.795: Cur-Clk 0x000005DC (6 usec), Max-Clk 0x00001CCC (29 usec)
*Mar 1 02:52:49.795: First switch 1, Cur switch 1, checked all 1
*Mar 1 02:52:49.795: Link Down : Completed Yes
*Mar 1 02:52:49.795: Switch : 1
*Mar 1 02:52:49.795: IPC message required : No
intr_link_down_gbitlist :
local_link_down_gbitlist :
local_link_up_gbitlist :
stack_link_up_gbitlist :
stack_link_down_gbitlist :
: select debug vectors
*Mar 1 02:52:49.778: fib_loadinfo_change_vectors: 8 datagramstart 7BD2736
*Mar 1 02:52:49.887: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
RFP = 0x0, WFP = 0x0, SRFP = 0x0, PktFull = 0x0, FifoFull = 0x0,
TxBytes = 0x0, MatchCount = 0
*Mar 1 02:52:49.887: Curr: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
RFP = 0x0, WFP = 0x0, SRP = 0x0, PktFull = 0x0, FifoFull = 0x0,
networkTxReady = 0x1, TxBytes = 0x0
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 29, Is Port-Empty ? 1, W1 0x18001800, W2 0x1800
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 29, MatchCount 0
*Mar 1 02:52:49.887: select debug vectors
*Mar 1 02:52:49.778: qos_oce_c
*Mar 1 02:52:49.887: Prev: Asic 0, Port 0, RP = 0xB40, WP = 0xB40, SRP = 0xB40
RFP = 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.887: Curr: Asic 0, Port 0, RP = 0xB40, WP = 0xB40, SRP = 0xB40
RFP = 0x2, WFP = 0x2, SRP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 0, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 0, MatchCount 0
*Mar 1 02:52:49.887: hange_vectors: select debug vectors
*Mar 1 02:52:49.778: lookup_ipv4_oce_change_0x0, FifoFull = 0x0,
*Mar 1 02:52:49.887: Curr: Asic 0, Port 14, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 14, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.887: Asic-Num 0, Port-Num 14, MatchCount 0
*Mar 1 02:52:49.887: vectors: select debug vector
*Mar 1 02:52:49.887: Prev: Asic 1, Port 29, RP = 0x1E00, WP = 0x1E00, SRP = 0x1E00
*Mar 1 02:52:49.887: Curr: Asic 1, Port 29, RP = 0x1E00, WP = 0x1E00, SRP = 0x1E00
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 29, Is Port-Empty ? 1, W1 0x1E001E00, W2 0x1E00
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 29, MatchCount 0
*Mar 1 02:52:49.896: s
*Mar 1 02:52:49.778: push_counter_oce_change_vectors: select debug vectors
*Mar 1 02:52:49.778: TTY0: r 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.896: Curr: Asic 1, Port 0, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 0, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 0, MatchCount 0
*Mar 1 02:52:49.896: esume timer ty
*Mar 1 02:52:49.896: Prev: Asic 1, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 1, Is Port-Empty ? 1, W1 0x3C003C0, W2 0x22203C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 1, MatchCount 0
*Mar 1 02:52:49.896: pe 1 (OK)
*Mar 1 02:52:49.778: Entering wait_for_stack_manager_election
*Mar 1 02:52tFull = 0x0, FifoFull = 0x0,
TxBytes = 0x19754, MatchCount = 0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 2, RP = 0x46A0, WP = 0x46A0, SRP = 0x46A0
RFP = 0xA, WFP = 0xA, SRP = 0xA, PktFull = 0x0, FifoFull = 0x0,
networkTxReady = 0x1, TxBytes = 0x19754
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 2, Is Port-Empty ? 1, W1 0x46A046A0, W2 0xAAA46A0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 2, MatchCount 0
*Mar 1 02:52:49.896: :49.795:
*Mar 1 02:52:49.896: Prev: Asic 1, Port 3, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 3, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 3, Is Port-Empty ? 1, W1 0x8C008C0, W2 0x22208C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 3, MatchCount 0
*Mar 1 02:52:49.896: XC
all_tracked_gid_gbitlist :
Sent on 0 frame 780 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.896: Curr: Asic 1, Port 4, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 4, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 4, MatchCount 0
*Mar 1 02:52:49.896: 03F8
Received: pak 3B9970
*Mar 1 02:52:49.896: Prev: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:52:49.896: Prev: Asic 0, Port 14, RP = 0xB40, WP = 0xB40, SRP = 0xB40
RFP = ull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.896: Curr: Asic 1, Port 6, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 6, Is Port-Empty ? 1, W1 0x10401040, W2 0x2221040
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 6, MatchCount 0
*Mar 1 02:52:49.896: 0x2, W
*Mar 1 02:52:49.896: Prev: Asic 1, Port 7, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 7, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 7, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 7, MatchCount 0
*Mar 1 02:52:49.896: FP = 0x2, SRFP = 0x2, PktFull =
*Mar 1 02:52:49.896: Prev: Asic 1, Port 0, RP = 0x140,RP = 0x1540
*Mar 1 02:52:49.896: Curr: Asic 1, Port 8, RP = 0x1540, WP = 0x1540, SRP = 0x1540
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 8, Is Port-Empty ? 1, W1 0x15401540, W2 0x2221540
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 8, MatchCount 0
*Mar 1 02:52:49.896: WP = 0x140, SRP = 0x1
*Mar 1 02:52:49.896: Prev: Asic 1, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 9, Is Port-Empty ? 1, W1 0x17C017C0, W2 0x22217C0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 9, MatchCount 0
*Mar 1 02:52:49.896: 40
*Mar 1 02:52:49.896: Prev: Asic 1, Port 2, RP = 0x46SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.896: Curr: Asic 1, Port 10, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 10, Is Port-Empty ? 1, W1 0x1A401A40, W2 0x2221A40
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 10, MatchCount 0
*Mar 1 02:52:49.896: A0, WP = 0x46A0, SRP = 0x46A0
*Mar 1 02:52:49.896: Prev: Asic 1, Port 11, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.896: Curr: Asic 1, Port 11, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 11, Is Port-Empty ? 1, W1 0x1CC01CC0, W2 0x2221CC0
*Mar 1 02:52:49.896: Asic-Num 1, Port-Num 11, MatchCount 0
RFP = 0xA, WFP = 0xA, SRFP = 0xA, Pk
*Mar 1 02:52:49.896: Prev: Asic 1, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.904: Curr: Asic 1, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 14, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 14, MatchCount 0
*Mar 1 02:52:49.904: Port 4, RP = 0xB40, WP = 0xB40, SRP = 0xB40
RFP = 0
*Mar 1 02:52:49.904: Prev: Asic 1, Port 15, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 15, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 15, Is Port-Empty ? 1, W1 0x3C003C0, W2 0x22203C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 15, MatchCount 0
*Mar 1 02:52:49.904: x2, WFP =
*Mar 1 02:52:49.896: Prev: Asic 1, Port 6, RP = 0x1040, WP = 0x1040, SRP = 0x10 FifoFull = 0x0,
*Mar 1 02:52:49.904: Curr: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 16, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 16, MatchCount 0
*Mar 1 02:52:49.904: 40
*M
*Mar 1 02:52:49.904: Prev: Asic 1, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 17, Is Port-Empty ? 1, W1 0x8C008C0, W2 0x22208C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 17, MatchCount 0
*Mar 1 02:52:49.904: ar 1 02:52:49.896: Prev: Asic 1, Port 8, RP = 0x1540, WP = 0x1540, S
*Mar 1 02:52: FifoFull = 0x0,
*Mar 1 02:52:49.904: Curr: Asic 1, Port 18, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 18, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 18, MatchCount 0
*Mar 1 02:52:49.904: 49.896: Pr
*Mar 1 02:52:49.904: Prev: Asic 1, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 19, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 19, MatchCount 0
*Mar 1 02:52:49.904: ev: Asic 1, Port 10, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:52:49.904: Curr: Asic 1, Port 20, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 20, Is Port-Empty ? 1, W1 0x10401040, W2 0x2221040
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 20, MatchCount 0
*Mar 1 02:52:49.904: Prev: Asic 1, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 21, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 21, MatchCount 0
*Mar 1 02:52:49.904: Asic 1, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
RFP = 0x2, WFP = 0x2, SRFP = FP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.904: Curr: Asic 1, Port 22, RP = 0x1540, WP = 0x1540, SRP = 0x1540
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 22, Is Port-Empty ? 1, W1 0x15401540, W2 0x2221540
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 22, MatchCount 0
*Mar 1 02:52:49.904: 0x2,
*Mar 1 02:52:49.904: Prev: Asic 1, Port 16, RP
*Mar 1 02:52:49.904: Prev: Asic 1, Port 23, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 23, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 23, Is Port-Empty ? 1, W1 0x17C017C0, W2 0x22217C0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 23, MatchCount 0
*Mar 1 02:52:49.904: = 0x640, WP = 0x640, SRP = 0x640
RFP = 0x2, WFP = 0x2, SRFP = 0x2, FifoFull = 0x0,
*Mar 1 02:52:49.904: Curr: Asic 1, Port 24, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 24, Is Port-Empty ? 1, W1 0x1A401A40, W2 0x2221A40
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 24, MatchCount 0
*Mar 1 02:52:49.904: PktFull = 0x0,
*Mar 1 02:52
*Mar 1 02:52:49.904: Prev: Asic 1, Port 25, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.904: Curr: Asic 1, Port 25, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 25, Is Port-Empty ? 1, W1 0x1CC01CC0, W2 0x2221CC0
*Mar 1 02:52:49.904: Asic-Num 1, Port-Num 25, MatchCount 0
*Mar 1 02:52:49.904: :49.904: Prev: Asic 1, Port 18, RP = 0xB40, WP = 0xB40, SRP = 0xB40
RFP = 0P = 0x6, SRFP = 0x6, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.913: Curr: Asic 2, Port 28, RP = 0x1E20, WP = 0x1E20, SRP = 0x1E20
RFP = 0xB, WFP = 0xB, SRP = 0xB, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 28, Is Port-Empty ? 1, W1 0x1E201E20, W2 0xBBB1E20
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 28, MatchCount 0
*Mar 1 02:52:49.913: x2, WFP = 0x2, SRFP = 0x2, PktFul
*Mar 1 02:52:49.913: Prev: Asic 2, Port 29, RP = 0x1E00, WP = 0x1E00, SRP = 0x1E00
*Mar 1 02:52:49.913: Curr: Asic 2, Port 29, RP = 0x1E00, WP = 0x1E00, SRP = 0x1E00
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 29, Is Port-Empty ? 1, W1 0x1E001E00, W2 0x1E00
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 29, MatchCount 0
*Mar 1 02:52:49.913: l = 0x0,
*Mar 1 02:52:49.904: Prev: Asic 1, Port 20, RP = 0x1040P = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.913: Curr: Asic 2, Port 0, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 0, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 0, MatchCount 0
*Mar 1 02:52:49.913: , WP = 0x1040, SRP
*Mar 1 02:52:49.913: Prev: Asic 2, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.913: Curr: Asic 2, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 1, Is Port-Empty ? 1, W1 0x3C003C0, W2 0x22203C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 1, MatchCount 0
*Mar 1 02:52:49.913: = 0x1040
RFP = 0x2
*Mar 1 02:52:49.904: Prev: Asic 1, Port 22, RP = 0x1540, WP = 0x1FP = 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.913: Curr: Asic 2, Port 2, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 2, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 2, MatchCount 0
*Mar 1 02:52:49.913: 540, SRP = 0x1540
RFP = 0x2, WFP
*Mar 1 02:52:49.913: Prev: Asic 2, Port 3, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.913: Curr: Asic 2, Port 3, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 3, Is Port-Empty ? 1, W1 0x8C008C0, W2 0x22208C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 3, MatchCount 0
*Mar 1 02:52:49.913: = 0x2, SR
*Mar 1 02:52:49.904: Prev: Asic 1, Port 24, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:52:49.904: Prev: Asic 2, Port 28, RP = 0x1E40, WP = 0x1E40, SRP = 0x1E40
RFP = 0x6, WF
*Mar 1 02:52:49.913: Prev: Asic 2, Port 0, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.913: Prev: Asic 2, Port 2, RP = 0x640, WP = 0x640, SRP = 0x640
R
*Mar 1 02:52:49.913: Prev: Asic 2, Port 4, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.913: Curr: Asic 2, Port 4, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 4, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 4, MatchCount 0
*Mar 1 02:52:49.913: Prev: Asount 0
*Mar 1 02:52:49.913: ic 2, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC
*Mar 1 02:52:49.913: Prev: Asic 2, Port 6, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:49.913: Curr: Asic 2, Port 6, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 6, Is Port-Empty ? 1, W1 0x10401040, W2 0x2221040
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 6, MatchCount 0
*Mar 1 02:52:49.913: 0
TxB
*Mar 1 02:52:49.913: Prev: Asic 2, Port 7, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.913: Curr: Asic 2, Port 7, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 7, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 7, MatchCount 0
*Mar 1 02:52:49.913: ytes = 0x0, MatchCount = 0
*Mytes = 0x0, MatchCount = 0
*Mar 1 02:52:49.913: Curr: Asic 2, Port 8, RP = 0x1540, WP = 0x1540, SRP = 0x1540
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 8, Is Port-Empty ? 1, W1 0x15401540, W2 0x2221540
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 8, MatchCount 0
*Mar 1 02:52:49.913: ar 1 02:52:49.913: Curr: Asic 2, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.913: Prev: Asic 2, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.913: Curr: Asic 2, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 9, Is Port-Empty ? 1, W1 0x17C017C0, W2 0x22217C0
*Mar 1 02:52:49.913: Asic-Num 2, Port-Num 9, MatchCount 0
RFP = 0x2, WFP = 0x2, SRP = 0x2, PktFull = 0x0, Fi2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.921: Curr: Asic 2, Port 10, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 10, Is Port-Empty ? 1, W1 0x1A401A40, W2 0x2221A40
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 10, MatchCount 0
*Mar 1 02:52:49.921: foFull = 0x0,
*Mar 1 02:52:49.921: Prev: Asic 2, Port 11, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.921: Curr: Asic 2, Port 11, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 11, Is Port-Empty ? 1, W1 0x1CC01CC0, W2 0x2221CC0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 11, MatchCount 0
*Mar 1 02:52:49.921: ic-Num 2, Port-Numx2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.921: Curr: Asic 2, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 14, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 14, MatchCount 0
*Mar 1 02:52:49.921: 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:52
*Mar 1 02:52:49.921: Prev: Asic 2, Port 15, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.921: Curr: Asic 2, Port 15, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 15, Is Port-Empty ? 1, W1 0x3C003C0, W2 0x22203C0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 15, MatchCount 0
*Mar 1 02:52:49.921: :49.913: Asic-Num 2, Port-Num 5, 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.921: Curr: Asic 2, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 16, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 16, MatchCount 0
*Mar 1 02:52:49.921: MatchC
*Mar 1 02:52:49.913: Prev: Asic 2, Port 8, RP = 0x1540, WP = 0x1
*Mar 1 02:52:49.921: Prev: Asic 2, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.921: Curr: Asic 2, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 17, Is Port-Empty ? 1, W1 0x8C008C0, W2 0x22208C0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 17, MatchCount 0
*Mar 1 02:52:49.921: 540, SRP = 0x1540
RFP = 0FP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:49.921: Curr: Asic 2, Port 18, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 18, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 18, MatchCount 0
*Mar 1 02:52:49.921: x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
TxB
*Mar 1 02:52:4
*Mar 1 02:52:49.921: Prev: Asic 2, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.921: Curr: Asic 2, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 19, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:52:49.921: Asic-Num 2, Port-Num 19, MatchCount 0
*Mar 1 02:52:49.921: 9.921: Prev: Asic 2, Port 10, RP = 0x1A40, WP = uq_di cmi=0 di=15F
*Mar 1 02:52:49.938: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:52:49.938: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:52:49.938: Successful return from hrm_mod_cpuq_di
*Mar 1 02:52:49.938: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)Sent on 0 frame 78003F8
Received: pak 3B98FE0 datagramstart 7BD15B6
*Mar 1 02:52:50.173: Receiving message : 60 82 0 0 E2
*Mar 1 02:52:50.173: RE message received from sub 0, length:2 (No interrupt)0x1A40, SRP = 0x1A40
RFP = 0x2, WFP = 0x
Switch#
Switch#
*Mar 1 02:52:50.173: RE_SYS : Interrupts pending for sub 0, apps 0Sent on 0 frame 78003F8
*Mar 1 02:52:50.173: REM TX Message : 77 81 1 F9
*Mar 1 02:52:51.045: Receiving message : 67 82 0 0 E9
*Mar 1 02:52:51.045: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:52:51.045: RE_SYS : Interrupts pending for sub 7, apps 0 Prev: Asic 2, Port 14, RP = :0 Port 1 Active :0
*Mar 1 02:52:51.104: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:52:51.104: Receiving message : 6E 2 0 0 70
*Mar 1 02:52:51.104: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:52:51.104: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:52:51.104: REM TX Message : 7E 82 3E 0 3E
*Mar 1 02:52:51.850: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 2 A A A 10 10 10 7 F F F F E E E E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7B0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:49.
*Mar 1 02:52:51.884: REM TX Message : 7E 82 3F 0 3F
*Mar 1 02:52:52.588: Receiving message : 6E 82 0 0 F0
*Mar 1 02:52:52.597: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:52:52.597: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:52:52.597: REM TX Message : 70 1 1 72
*Mar 1 02:52:52.597: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:52:52.597: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:52:52.597: Entering hrm_get_cpuq_cmi cpu=6
*Mar 1 02:52:52.597: Successful return from hrm_get_cpuq_cmi
*Mar 1 02:52:52.597: Entering hrm_mod_cpuq_di cmi=7 di=15F921: Prev: Asic 2, Port 16 :0 Port 1 Active :0
*Mar 1 02:52:52.647: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:52:52.656: POE_GET_EVENTS sent to E
*Mar 1 02:52:52.656: Receiving message : 60 2 0 0 62
*Mar 1 02:52:52.656: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:52:52.656: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:52:52.656: REM TX Message : 77 1 1 79
*Mar 1 02:52:53.209: Receiving message : 67 2 0 0 69
*Mar 1 02:52:53.209: RE message received from sub 7, length:2 (No interrupt), RP = 0x640, WP = 0x640, SRP = 0x640
RFP =
*Mar 1 02:52:53.209: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:52:53.209: REM TX Message : 70 82 3E 0 30
*Mar 1 02:52:53.931: Receiving message : 60 BA 0 0 11 11 33 13 11 11 11 31 0 0 0 0 0 0 3 40 F 6 6 6 17 16 15 B B B B B 5 A 4 15 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 FB
*Mar 1 02:52:53.931: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:52:53.931: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:52:53.931: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:52:53.931: rok_thermal_processing : 2
*Mar 1 02:52:53.931: REM TX Message : 70 2 3E 10 C0Sent on 0 frame 78003F8
c 2, Port 18, RP = 0xB40, WP = 0 70
*Mar 1 02:52:54.006: REM TX Message : 3E 7 28 0 FF 0 0 0 0 6C
*Mar 1 02:52:54.006: REM TX Message : 7E 1 1 80
*Mar 1 02:52:54.593: Receiving message : 6E 2 0 0 70
*Mar 1 02:52:54.593: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:52:54.593: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:52:54.593: REM TX Message : 77 82 3E 0 37
*Mar 1 02:52:54.602: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:52:54.602: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:52:54.602: Entering hrm_mod_cpuq_di 0xB40, SRP = 0xB40
RFP = 0x2, W
*Mar 1 02:52:49.938: Successful return from hrm_get_well_known_di_ cmi=0 di=15F
*Mar 1 02:52:54.602: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:52:54.602: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:52:54.602: Successful return from hrm_mod_cpuq_di
*Mar 1 02:52:54.602: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)Sent on 0 frame 78003F8
*Mar 1 02:52:55.290: Receiving message : 67 BA 0 0 31 33 33 13 11 11 11 11 0 0 0 0 0 0 0 0 D E D C 4 3 2 9 9 9 9 9 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 99
*Mar 1 02:52:55.290: RE message received from sub 7, length:58 (No interrupt)with_mvid
*Mar 1 02:52:49.90 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:52:55.357: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:52:55.357: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:52:55.357: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:52:55.357: MDFS: RP received IPC packet from LC in slot 1 of type download
*Mar 1 02:52:55.357: MDFS: RP received reload request from LC in slot 1
*Mar 1 02:52:55.357: REM TX Message : 7E 82 3F 0 3F
*Mar 1 02:52:55.927: Receiving message : 6E 82 0 0 F038: Entering hrm_mod_cp
*Mar 1 02:52:51.104: Port 0 Enabled:0 Port 1 Enabl
*Mar 1 02:52:55.927: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:52:55.927: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:52:55.936: REM TX Message : 77 81 1F 17
*Mar 1 02:52:56.615: obfl_io_flush_process: write lock acquired for 'obfl0::errmsg_cont'
*Mar 1 02:52:56.615: obfl_io_flush_process: write lock released for 'obfl0::errmsg_cont'
*Mar 1 02:52:56.615: obfl_io_flush_process: write lock acquired for 'obfl0::volt_cont'
*Mar 1 02:52:56.615: obfl_io_flush_process: write lock released for 'obfl0::volt_cont'
*Mar 1 02:52:56.623: obfl_io_flush_process: write lock acquired for 'obfl0::uptime_cont'
ed:0
*Mar 1 02:52:51.104: 5 : 126,
*Mar 1 02:52:56.682: sys vol 6 : 105,
*Mar 1 02:52:56.682: sys vol 7 : 79,
*Mar 1 02:52:56.691: REM TX Message : 70 81 1 F2Sent on 0 frame 78003F8
Received: pak 3B99708 datagramstart 7BD2736
*Mar 1 02:52:57.261: Receiving message : 60 82 0 0 E2
*Mar 1 02:52:57.261: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:52:57.261: RE_SYS : Interrupts pending for sub 0, apps 0Sent on 0 frame 78003F8
Received: pak 3B98C4C datagramstart 7BD0CF6
*Mar 1 02:52:57.261: hl3mm: RPF throttling, total h/w routes 0 Port 0 Active
*Mar 1 02:52:52.647: Port 0 Enabled:0 Port 1
*Mar 1 02:52:57.278: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x0000081D, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0008, size: 0x05B8
*Mar 1 02:52:57.278: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x0000081D, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0007, size: 0x05B8
*Mar 1 02:52:57.278: SNMP: HC Timer 3ADDB8C fired
*Mar 1 02:52:57.278: SNMP: HC Timer 3ADDB8C rearmed, delay = 5000
*Mar 1 02:52:57.278: REM TX Message : 77 81 1 F9
*Mar 1 02:52:57.991: Receiving message : 67 82 0 0 E9
*Mar 1 02:52:57.991: RE message received from sub 7, length:2 (No interrupt)Enabled:0
*Mar 1 02:52:52.647:= 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:52:58.041: Curr: Asic 2, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:52:58.041: Asic-Num 2, Port-Num 14, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:52:58.041: Asic-Num 2, Port-Num 14, MatchCount 0
*Mar 1 02:52:58.041: Port 0 Active 0 0 0 0 0 0 0 0 E9
*Mar 1 02:52:58.049: Prev: Asic 2, Port 20, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:58.049: Curr: Asic 2, Port 20, RP = 0x1040, WP = 0x1040, SRP = 0x1040
*Mar 1 02:52:58.049: Asic-Num 2, Port-Num 20, Is Port-Empty ? 1, W1 0x10401040, W2 0x2221040
*Mar 1 02:52:58.049: Asic-Num 2, Port-Num 20, MatchCount 0
*Mar 1 02:52:58.049: M TX Message : 3E 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0ar 1 02:52:59.358: hrpc_recv_req_frag: Handler OK 3CB27E8Sent on 0 frame 78003F8
*Mar 1 02:52:59.358: Receiving message : 6E 2 0 0 70
*Mar 1 02:52:59.366: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:52:59.366: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:52:59.366: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
Request 37 received from 1, length 38128
*Mar 1 02:52:59.366: REM TX Message : 70 2 3E 0 B0 0 0
*Mar 1 02:52:55.348: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0
*Mar 1 02:52:59.996: Receiving message : 60 3A 0 0 11 11 33 13 11 11 11 13 0 0 0 0 0 0 3 40 2 F F F 19 18 17 1 A A A A 4 9 C C 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 60
*Mar 1 02:52:59.996: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:52:59.996: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:52:59.996: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:52:59.996: REM TX Message : 70 82 3E 10 40Sent on 0 frame 78003F8
*Mar 1 02:53:00.709: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 03A 0 0 11 11 33 13 11 11 11 11 0 0 0 0 0 0 0 0 1 E E E 7 6 5 11 9 9 9 9 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DF
*Mar 1 02:53:00.767: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:00.767: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:00.767: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:53:00.776: REM TX Message : 77 82 3E 10 47
*Mar 1 02:53:01.363: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
*Mar 1 02:52:56.682: sys vol 3 : 132,
*Mar 1 02:52:56.682: sys vol 4 : 158,
*Mar 1 02:52:58.041: Prev: Asic 2, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
RFP = 0x2,
*Mar 1 02:53:01.371: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:01.371: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:53:01.371: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:01.371: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:02.084: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:02.084: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:02.084: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:53:02.084: REM TX Message : 30 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 62
*Mar 1 02:53:02.093: REM TX Message : 37 13 21 FF FF 0 0WFP = 0x2, SRFP
*Mar 1 02:52:59.358: hrpc_recv_message: recvd req ack src_box: 1,NTS sent to E
*Mar 1 02:53:02.152: Receiving message : 60 2 0 0 62
*Mar 1 02:53:02.152: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:53:02.152: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:53:02.152: REM TX Message : 77 1 1 79Sent on 0 frame 78003F8
*Mar 1 02:53:02.714: Receiving message : 67 2 0 0 69 dest_box: 1 code: succes
*Mar 1 02:53:02.739: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:53:02.739: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:53:03.452: Receiving message : 6E 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 5 B B B 3 3 3 4 D D D D C C C C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 C7
*Mar 1 02:53:03.460: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:03.460: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:03.460: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:53:03.460: REM TX Message : 7E 82 3E 10 4ESent on 0 frame 78003F8
s, seq_num: 0x0000081D
*M
*Mar 1 02:53:00.767: Successful return from hdm_poll_device_n_staage received E from E , valid : 64 length : 58
*Mar 1 02:53:03.527: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:53:03.527: REM TX Message : 77 81 1F 17
*Mar 1 02:53:04.073: Receiving message : 67 82 2E 0 17
*Mar 1 02:53:04.073: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:04.073: REM TX Message : 77 1 1D 95
*Mar 1 02:53:04.098: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:53:04.098: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:53:04.098: sys vol 0 : 221,ckport_status
*Mar 1 02:53:00
*Mar 1 02:53:04.098: sys vol 1 : 212,
*Mar 1 02:53:04.098: sys vol 2 : 176,
*Mar 1 02:53:04.098: sys vol 3 : 132,
*Mar 1 02:53:04.098: sys vol 4 : 158,
*Mar 1 02:53:04.098: sys vol 5 : 126,
*Mar 1 02:53:04.098: sys vol 6 : 105,
*Mar 1 02:53:04.098: sys vol 7 : 79,
*Mar 1 02:53:04.098: REM TX Message : 70 82 3E 0 30
*Mar 1 02:53:04.811: Receiving message : 60 BA 0 0 13 11 11 11 33 33 33 11 0 0 0 0 0 0 3 40 D 8 8 8 11 11 11 9 4 3 2 1 F 2 3 C 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E8
*Mar 1 02:53:04.811: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:04.811: PoE message received E from 0 , valid : 64 length : 58.767: Receiving message : 67
*Mar 1 02:53:02.143: Port 0 received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:04.878: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:04.878: Copy for instance 0, page 1, 58 bytesSent on 0 frame 78003F8
*Mar 1 02:53:04.878: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:53:04.886: REM TX Message : 7E 1 1 80
*Mar 1 02:53:05.423: Receiving message : 6E 2 0 0 70Enabled:0 Port 1 Enabled:0
*Mar 1 02:53:05.423: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:05.423: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:53:05.423: REM TX Message : 3F 1 3 43
*Mar 1 02:53:05.423: REM TX Message : 77 82 3E 0 37Sent on 0 frame 78003F8
*Mar 1 02:53:06.119: Receiving message : 67 BA 0 0 13 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 0 8 8 8 11 11 11 9 A A A A 9 9 9 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 4B
*Mar 1 02:53:06.128: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:06.128: PoE message received E from 7 , valid : 64 length : 58*Mar 1 02:53:02.143: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:53: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:53:06.178: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:06.186: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:53:06.186: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:06.186: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:06.186: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:53:06.186: REM TX Message : 7E 82 3E 0 3E02.143: Successful return from
*Mar 1 02:53:06.790: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 9 A A A 2 2 2 B C C C C B B B B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 44
*Mar 1 02:53:06.790: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:06.790: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:06.790: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:53:06.790: REM TX Message : 7E 2 3E 10 CE
*Mar 1 02:53:07.512: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6hdm_poll_device_n_stackport_status
*Mar 1 02:53:02.143: POE_GET_EVE
*Mar ge received F from E , valid : 64 length : 2
*Mar 1 02:53:07.579: REM TX Message : 30 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E2
*Mar 1 02:53:07.579: REM TX Message : 37 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E9
*Mar 1 02:53:07.579: REM TX Message : 3E 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 70
*Mar 1 02:53:07.579: REM TX Message : 3E 7 28 0 FF 0 0 0 0 6C
*Mar 1 02:53:07.579: REM TX Message : 70 81 1 F2Sent on 0 frame 78003F8
*Mar 1 02:53:08.158: Receiving message : 60 82 0 0 E2 1 02:53:03.527: RE message received from sub E, length:5
*Mar 1 02:53:08.183: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:08.183: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:53:08.183: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:08.183: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:08.183: Receiving message : 67 82 0 0 E9
*Mar 1 02:53:08.191: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:08.191: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:08.191: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:53:08.913: Receiving message : 60 3A 0 0 31 33 11 31 11 11 11 13 0 0 0 0 0 0 3 40 7 12 11 108 (No interrupt)
*Mar 1 02:53:03.527: PoE mess 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ar 1 02:53:08.971: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1B
*Mar 1 02:53:08.980: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:08.980: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:08.980: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:53:08.980: REM TX Message : 77 1 1F 97Sent on 0 frame 78003F8
*Mar 1 02:53:09.517: Receiving message : 67 2 2E0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 97
*Mar 1 02:53:09.517: RE message received from sub 7, length:2 (No interrupt)Sent on 0 frame 78003F8
*Mar 1 02:53:09.517: STP sync: Send ALL port data to all other switches...
*Mar 1 02:53:09.517: STP sync: NULL sync_data -- nothing to send
*Mar 1 02:53:09.517: REM TX Message : 77 81 1D 15
*Mar 1 02:53:09.517: SNMP: HC Timer 3B0D070 fired
*Mar 1 02:53:09.517: SNMP: HC Timer 3B0D070 rearmed, delay = 10000
*Mar 1 02:53:09.517: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:53:10.238: Receiving message : 67 8A DD D4 B0 84 9E 7E 69 4F 0 0 AA 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:53:04.878: RE message
*Mar 1 02:53:06quest 37 received from 1, length 38128
*Mar 1 02:53:10.314: REM TX Message : 77 82 3E 10 47Sent on 0 frame 78003F8
*Mar 1 02:53:10.892: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:53:10.901: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:10.901: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:10.901: Copy for instance 1, page 1, 58 bytes.178: Port 0 Enabled:0
*Mar 1 02:53:10.901: MDFS: LC sending download message to RP with code 256 of size 12
*Mar 1 02:53:10.901: IPC: Server sent MSG: ptr: 0x30B8908, flags: 0x108, retries: 0, seq: 0x0, refcount: 1, retry: never, rpc_result = 0x0, data_buffer = 0x3082FA0, header = 0x78944C0, data = 0x78944E0 || HDR: src: 0x10000, dst: 0x10007, index: 0, seq: 0, sz: 12, type: 785, flags: 0x40 hi: 0x0, lo: 0x0 || DATA: 00 00 00 01 00 00 01 00 FF FF 01 00
*Mar 1 02:53:10.901: REM TX Message : 7E 1 1 80
*Mar 1 02:53:10.901: MDFS: RP received IPC packet from LC in slot 1 of type download
*Mar 1 02:53:10.901: MDFS: RP received reload request from LC in slot 1 Port 1 Enabled:0
*Mar 1 02:53:07.579: RE messaRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:53:11.639: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:53:11.639: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:53:11.639: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:53:11.639: ge received from sub E, 0 0 0 0 0 0 0 A6
*Mar 1 02:53:12.243: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:12.243: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:12.243: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:53:12.243: REM TX Message : 70 2 3E 0 B0Sent on 0 frame 78003F8
*Mar 1 02:53:12.939: Receiving message : 60 3A 0 0 13 11 33 13 33 33 33 11 0 0 0 0 0 0 3 40 2 2 2 2 F E D 1 5 4 3 2 10 3 4 D 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 66
*Mar 1 02:53:12.939: RE message received from sub 0, length:58 (No interrupt) length:2 (No interrupt)
*Mar 1 02:53:07.579: PoE messa
*Mar 1 02:53:08.971: Successful returl = 0x0, FifoFull = 0x0,
*Mar 1 02:53:12.964: Curr: Asic 1, Port 4, RP = 0xB40, WP = 0xB40, SRP = 0xB40
*Mar 1 02:53:12.964: Asic-Num 1, Port-Num 4, Is Port-Empty ? 1, W1 0xB400B40, W2 0x2220B40
*Mar 1 02:53:12.964: Asic-Num 1, Port-Num 4, MatchCount 0
*Mar 1 02:53:12.964: n from hdm_poll_device_n_sta
*Mar 1 02:53:12.973: Prev: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:53:12.973: Curr: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:53:12.973: Asic-Num 1, Port-Num 16, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:53:12.973: Asic-Num 1, Port-Num 16, MatchCount 0
*Mar 1 02:53:12.973: ckport_status
*Mar 1 02:53:08.971: POE_GET_EVENTS sent to E
*M
*Mar 1 02:53:10.2:53:15.917: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000820
*Mar 1 02:53:15.917: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:53:15.917: REM TX Message : 77 1 1 79
*Mar 1 02:53:15.917: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:53:15.984: Receiving message : 67 2 0 0 69
*Mar 1 02:53:15.984: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:15.984: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:15.984: REM TX Message : 7E 81 1 0
*Mar 1 02:53:16.009: Receiving message : 6E 82 0 0 F0314: Invoking hrpc handler: 8BEAD0, src 1, req 37
*Mar 1 02:53:16.009: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:16.009: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:53:16.009: REM TX Message : 70 82 3E 0 30
*Mar 1 02:53:16.731: Receiving message : 60 BA 0 0 31 33 11 11 11 11 11 13 0 0 0 0 0 0 3 40 4 3 2 1 F F F 11 2 2 2 2 D 1 4 4 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:53:16.731: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:16.731: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:16.731: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:53:16.731: REM TX Message : 70 2 3E 10 C0, size 38128 bytesHQM: hqm_request_handler
Re
*Mar 1 02:53:11.639: Prytes
*Mar 1 02:53:16.798: REM TX Message : 7E 2 3F 0 BFSent on 0 frame 78003F8
*Mar 1 02:53:17.503: Receiving message : 6E 2 0 0 70
*Mar 1 02:53:17.503: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:17.503: PoE message received F from E , valid : 64 length : 2Sent on 0 frame 78003F8
*Mar 1 02:53:17.503: POE_GET_EVENTS sent to E
*Mar 1 02:53:17.503: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0ev: As
*Mar 1 02:53:17.503: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:53:17.503: Entering hrm_mod_cpuq_di cmi=0 di=15F
*Mar 1 02:53:17.503: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:17.503: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:53:17.503: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:17.503: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:17.503: REM TX Message : 70 81 1 F2
*Mar 1 02:53:18.023: Receiving message : 60 82 0 0 E2
*Mar 1 02:53:18.023: RE message received from sub 0, length:2 (No interrupt)ic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
RFP = 0x2, WFP = 0x2, 02:53:18.081: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:53:18.081: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:18.081: Receiving message : 67 82 0 0 E9
*Mar 1 02:53:18.081: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:18.081: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:18.081: REM TX Message : 7E 81 1 0
*Mar 1 02:53:18.803: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:18.803: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:18.803: RE_SYS : Interrupts pending for sub 14, apps 0S
*Mar 1 02:53:12.964: Prev: Asic 1, Port 4, R
*Mar 1 02:53:18.828: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:53:18.828: REM TX Message : 77 82 3E 10 47
*Mar 1 02:53:19.415: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:53:19.424: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:19.424: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:19.424: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:53:19.424: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:53:19.424: get_volt:volt=221, sensor = 0, OBFL device 'obfl0:'
*Mar 1 1 Active :0
*Mar 1 02:53:19.474: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:19.474: Receiving message : 6E 2 0 0 70
*Mar 1 02:53:19.474: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:19.474: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:53:19.482: REM TX Message : 70 1 1 72
*Mar 1 02:53:20.195: Receiving message : 60 2 0 0 62
*Mar 1 02:53:20.195: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:53:20.195: RE_SYS : Interrupts pending for sub 0, apps 002:53:15.909
*Mar 1 02:53:20.204: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:20.204: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:53:20.204: SNMP: HC Timer 3B0D070 fired
*Mar 1 02:53:20.204: SNMP: HC Timer 3B0D070 rearmed, delay = 10000
*Mar 1 02:53:20.204: POE_GET_EVENTS sent to E
*Mar 1 02:53:20.204: FIBbg: Timer 'FIB checkers: IPv4 scan-rp-lc scanner' expired, calling 0x00FB623C, context 0x00010002)
*Mar 1 02:53:20.204: FIBchck: [scan-rp-lc:v4] Invoking timer callback
*Mar 1 02:53:20.204: FIBbg: Restarting timer 'FIB checkers: IPv4 scan-rp-lc scanner' with delay 60000Sent on 0 frame 78003F8
: %SYS-3-LOGGER_DROPPED: System dropped 1164 console debug messages.
*Mar 1 0
*Ma = 0x5, SRP = 0x5, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:53:20.799: Asic-Num 2, Port-Num 28, Is Port-Empty ? 1, W1 0x1FE01FE0, W2 0x5551FE0
*Mar 1 02:53:20.799: Asic-Num 2, Port-Num 28, MatchCount 0
*Mar 1 02:53:20.799: Prev: Asic 2, Port 29, RP = 0x1E00, WP = 0x1E00, SRP = 0x1E00
TxBytes = 0x0, MatchCount = 0r 1 02:53:16.798: PoE message re
*Mar 1 02:53:21.529: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:53:21.529: ERD available:1
*Mar 1 02:53:21.529: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:53:21.529: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:53:22.125: Receiving message : 67 2 0 0 69
*Mar 1 02:53:22.125: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:22.125: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:22.125: REM TX Message : 7E 81 1 0ceived E from 0 , valid : 64 length : 58
*Mar 1 02:53:16.798: Copy for instance 0 Port 1 Active :0
*Mar 1 02:53:22.175: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:22.175: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:22.175: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:22.175: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:53:22.175: REM TX Message : 70 82 3E 0 30
*Mar 1 02:53:22.888: Receiving message : 60 BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 3 40 8 2 2 2 11 11 11 7 1 1 1 1 C 11 B 3 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6C, page 1, 58 b
*Mar 1 02:53:18.081: Port
*Mar 1 02:53:22.897: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:22.897: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:23.484: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:53:23.484: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:23.484: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:23.484: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:53:23.484: REM TX Message : 7E 2 3F 0 BF0 Enabled:0 Port 1 Enabled:0
*Mar 1
*Mar 1 02:53:19.474: Port 0 Enabled:0 Port 1 Enable 1 02:53:24.255: Receiving message : 67 82 2E 0 17
*Mar 1 02:53:24.255: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:24.255: REM TX Message : 77 1 1D 95
*Mar 1 02:53:24.255: hl3mm: RPF throttling, total h/w routes 0
*Mar 1 02:53:24.255: rpf timer restart period 5000
*Mar 1 02:53:24.272: hrpc_send_request: sending 27 msgs, seq_num 2082, req_num 37 class 14d:0
*Mar 1 02:53:24.281: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:53:24.281: sys vol 0 : 221,
*Mar 1 02:53:24.281: sys vol 1 : 212,
*Mar 1 02:53:24.281: sys vol 2 : 176,
*Mar 1 02:53:24.281: sys vol 3 : 132,
*Mar 1 02:53:24.281: sys vol 4 : 158,
*Mar 1 02:53:24.281: sys vol 5 : 126,
*Mar 1 02:53:24.281: sys vol 6 : 105,
*Mar 1 02:53:24.281: sys vol 7 : 79,
*Mar 1 02:53:24.281: REM TX Message : 70 81 1 F2
*Mar 1 02:53:25.002: Receiving message : 60 82 0 0 E2
*Mar 1 02:53:25.002: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:53:25.002: RE_SYS : Interrupts pending for sub 0, apps 0 Port 0 Active :0 Port
*Mar 1 02:53:20.799: Curr: Asic 2, Port 28, RP =0, FifoFull = 0x0,
*Mar 1 02:53:25.027: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:53:25.027: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:53:25.027: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:53:25.027: 0x1FE0, WP = 0x1FE0, SRP = 0x1FE0Fibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened
*Mar 1 02:53:25.606: MAD available:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:53:25.606: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:53:25.606: ERD available:1
*Mar 1 02:53:25.606: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:53:25.606: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:53:26.302: Receiving message : 67 82 0 0 E9
*Mar 1 02:53:26.302: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:26.302: RE_SYS : Interrupts pending for sub 7, apps 0
RFP = 0x5, WFP
CEr 1 02:53:22.175: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:53:27.217: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:53:27.217: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:27.225: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:27.225: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:53:27.225: REM TX Message : 7E 81 1 0
*Mar 1 02:53:27.225: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:53:27.225: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:53:27.225: Entering hrm_mod_cpuq_di cmi=0 di=15F
*Mar 1 02:53:27.225: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:27.225: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:53:27.225: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:27.225: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)Sent on 0 frame 78003F8
*Mar 1 02:53:27.921: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:27.921: RE message received from sub E, length:2 (No interrupt) Port 0 Active :0
*Mar 1 02:53:23.542: PoE message received F from E , valid obfl_io_flush_process: write lock acquired for 'obfl0::temp_cont'
*Mar 1 02:53:27.980: obfl_io_flush_process: write lock released for 'obfl0::temp_cont'
*Mar 1 02:53:28.836: Receiving message : 60 3A 0 0 13 11 11 11 33 33 31 11 0 0 0 0 0 0 3 40 0 3 3 3 B B B 6 14 13 12 11 3 12 2 B 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 77
*Mar 1 02:53:28.836: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:28.836: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:28.836: Copy for instance 0, page 0, 58 bytes: 64 length : 2
*Mar 1 02:53:23.542: REM TX Messag
*Mar 1 02:53:28.836: REM TX Message : 70 82 3E 10 40
*Mar 1 02:53:29.599: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1B
*Mar 1 02:53:29.599: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:29.599: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:29.599: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:53:29.599: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:53:29.616: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
TxBytes = 0x0, MatchCount = 0e : 77 81 1F 17
*Mar
*Mar 1 02:53:25.027: Prev: Asic 1, Port 5, RP = 0xDC0, W
*Mar 1 02:53:29.675: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:53:29.683: REM TX Message : 30 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 62
*Mar 1 02:53:29.683: REM TX Message : 37 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69
*Mar 1 02:53:29.683: REM TX Message : 3E 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F0
*Mar 1 02:53:29.683: REM TX Message : 3E 87 28 0 FF 0 0 0 0 EC
*Mar 1 02:53:29.683: REM TX Message : 70 1 1 72Sent on 0 frame 78003F8
P = 0xDC0
*Mar 1 02:53:30.555: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:53:30.555: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:53:30.555: POE_GET_EVENTS sent to E
*Mar 1 02:53:30.564: SNMP: HC Timer 3B0D070 fired
*Mar 1 02:53:30.564: SNMP: HC Timer 3B0D070 rearmed, delay = 10000
*Mar 1 02:53:31.252: Receiving message : 67 3A 0 0 31 33 11 11 11 11 11 11 0 0 0 0 0 0 0 0 6 F E D D D D 8 B B B B A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1E
*Mar 1 02:53:31.252: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:31.252: PoE message received E from 7 , valid : 64 length : 58, SRP = 0xDC0
RFP = 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0xHQM: hqm_request_handler 7, length:58 (No interrupt)
*Mar 1 02:53:31.319: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:31.319: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:53:31.319: REM TX Message : 77 1 1F 97
*Mar 1 02:53:32.191: Receiving message : 67 2 2E 0 97
*Mar 1 02:53:32.191: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:32.191: REM TX Message : 77 81 1D 15
*Mar 1 02:53:32.191: MDFS: RP servicing reload for LC in slot 1
*Mar 1 02:53:32.191: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
Request 37 received
*Mar 1 02:53:32.191: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000823, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0000, size: 0x05B8
*Mar 1 02:53:32.191: hrpc_send_req_ack: sending req_ack for request 2083
*Mar 1 02:53:32.191: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000823
*Mar 1 02:53:32.191: hrpc_recv_req_frag: Handler OK 3CB27E8Sent on 0 frame 78003F8
*Mar 1 02:53:32.200: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
Request 37 received from 1, length 38128 from 1, length 38128
*Mar 1 02:53:26.369: REM TX Message : 7E 2 3E 10
*Mar 1 02:53:27ctive :0 Port 1 Active :0
*Mar 1 02:53:32.996: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:33.005: Receiving message : 67 2 0 0 69
*Mar 1 02:53:33.005: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:33.005: RE_SYS : Interrupts pending for sub 7, apps 0Sent on 0 frame 78003F8
*Mar 1 02:53:33.005: REM TX Message : 7E 82 3E 0 3E
*Mar 1 02:53:33.860: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 11 9 9 9 A A A A 5 5 5 5 4 4 4 4 0 0 0 0 0 0 0 0 0 0 0.980: obfl_io_flush_process: 0 0 0 0 0 0 0 0 0 0 0 0 0 28
*Mar 1 02:53:33.869: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:33.869: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:33.869: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:53:33.869: REM TX Message : 7E 2 3E 10 CE
*Mar 1 02:53:34.439: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:53:34.448: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:34.448: PoE message received E from E , valid : 64 length : 58 write lock released for 'obfl0::env_cont'
*Mar 1 02:53:29.675: Receiving message : 6E 2 0 0 70
*Mar 1 02:53:29.675: RE message received from sub E, length:2 (No interrupt) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:53:31.319: RE message received from sub
*Mar 1 02:53:32.996: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:53:32.996: Port 0 A
*Mar 1 02:53:34.506: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:53:34.506: Successful return from Switch#
S34.506: REM TX Message : 70 82 3E 0 30Sent on 0 frame 78003F8
*Mar 1 02:53:35.211: Receiving message : 60 BA 0 0 13 11 11 11 11 11 11 31 0 0 0 0 0 0 3 40witch#
Switch#
Switch#
S
*Mar 1 02:53:35.236: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000824, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0008, size: 0x05B8
*Mar 1 02:53:35.236: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000824, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0007, size: 0x05B8
*Mar 1 02:53:35.236: SNMP: HC Timer 3ADDB8C fired
*Mar 1 02:53:35.236: SNMP: HC Timer 3ADDB8C rearmed, delay = 5000
*Mar 1 02:53:35.236: REM TX Message : 70 2 3E 10 C0
*Mar 1 02:53:35.245: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0witch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switchrm_Mar 1 02:53:36.016: Receiving message : 67 BA 0 0 13 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 1 10 10 10 11 11 11 11 C C C C B B B B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7C
*Mar 1 02:53:36.025: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:36.025: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:36.025: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:53:36.025: REM TX Message : 77 2 3E 10 C7
*Mar 1 02:53:36.922: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0mod_cpuq_di
*Mar 1 02:53:
*Mar 1 02:53:36.931: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:36.931: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:53:36.931: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:36.931: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:37.660: Receiving message : 6E 2 0 0 70
*Mar 1 02:53:37.660: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:37.660: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:53:37.660: rok_thermal_processing : 2
*Mar 1 02:53:37.660: REM TX Message : 70 81 1 F234.506: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:34.506: Receiving 0, length:2 (No interrupt)
*Mar 1 02:53:37.887: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:53:37.887: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:53:37.895: REM TX Message : 77 81 1F 17
*Mar 1 02:53:38.785: Receiving message : 67 82 2E 0 17
*Mar 1 02:53:38.785: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:38.785: REM TX Message : 77 1 1D 95
*Mar 1 02:53:38.793: POE_GET_EVENTS sent to ESent on 0 frame 78003F8
*Mar
*Mar 1 02:53:38.852: sys vol 0 : 221,
*Mar 1 02:53:38.852: sys vol 1 : 212,
*Mar 1 02:53:38.852: sys vol 2 : 176,
*Mar 1 02:53:38.852: sys vol 3 : 132,
*Mar 1 02:53:38.852: sys vol 4 : 158,
*Mar 1 02:53:38.852: sys vol 5 : 126,
*Mar 1 02:53:38.852: sys vol 6 : 105,
*Mar 1 02:53:38.852: sys vol 7 : 79,
*Mar 1 02:53:38.852: REM TX Message : 7E 82 3E 0 3E
*Mar 1 02:53:39.372: Receiving message : 6E BA 0 0 11 11 33 13 11 11 11 11 0 0 0 0 0 0 0 0 C 9 9 9 0 0 0 8 C C C C B B B B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5F
*Mar 1 02:53:39.380: RE message received from sub E, length:58 (No interrupt) 1 02:53:34.506: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:5ssful return from hrm_mod_cpuq_di
*Mar 1 02:53:39.380: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)Sent on 0 frame 78003F8
*Mar 1 02:53:40.261: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:53:40.261: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:40.261: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:40.261: Copy for instance 2, page 1, 58 bytes3:34.506: RE_SYS : Interrup
*Mar 1 02:53:40.353: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:53:40.353: REM TX Message : 70 82 3E 10 40Sent on 0 frame 78003F8
*Mar 1 02:53:41.058: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0Sent on 0 frame 78003F8
*Mar 1 02:53:41.058: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:41.058: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:41.058: Copy for instance 0, page 1, 58 bytests pending for sub 14, apps 0
*Mar 1 02:53:34.506: REM T 1 02:53:41.939: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:41.939: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:41.939: REM TX Message : 77 2 3E 0 B7
*Mar 1 02:53:41.955: MDFS: LC sending download message to RP with code 256 of size 12
*Mar 1 02:53:41.955: IPC: Server sent MSG: ptr: 0x30B85F8, flags: 0x108, retries: 0, seq: 0x0, refcount: 1, retry: never, rpc_result = 0x0, data_buffer = 0x3083DF0, header = 0x78967E0, dMta = 0x7896800X
*Mar 1 02:53:41.989: Prev: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:53:41.989: Curr: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:53:41.997: Asic-Num 2, Port-Num 21, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:53:41.997: Asic-Num 2, Port-Num 21, MatchCount 0
*Mar 1 02:53:41.997: essage : 3F 1 3 43
*Mar 1 02:53:
*Mar 1 02:53:36.016: Fibs-ATMFail # of Covering fibs x: 1, dest_box: 1 code: success, seq_num: 0x00000825
*Mar 1 02:53:42.677: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:53:42.685: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:53:43.524: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:43.524: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:43.524: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:53:43.533: REM TX Message : 7E 2 3E 0 BE0.Fib delete not happened
*Mar
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock released for 'obfl0::poe_cont'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock acquired for 'obfl0::env_hist'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock released for 'obfl0::env_hist'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock acquired for 'obfl0::env_cont'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock released for 'obfl0::env_cont'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock acquired for 'obfl0::temp_cont'
*Mar 1 02:53:43.591: obfl_io_flush_process: write lock released for 'obfl0::temp_cont'
*Mar 1 02:53:44.321: Receiving message : 6E BA 0 0 FF FF 0 0 0 1 02:53:37.887: Receiving message : 60 82 0 0 E2
*Mar 1 02:53:37.887: RE me:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:44.329: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:53:44.329: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:44.329: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:45.135: Receiving message : 67 2 2E 0 97
*Mar 1 02:53:45.135: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:45.135: REM TX Message : 77 81 1D 15ssage received from sub
*Mar 1 02
*Mar 1 02:53:45.193: sys vol 7 : 79,
*Mar 1 02:53:45.193: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:53:45.923: Receiving message : 60 3A 0 0 11 11 11 11 33 33 33 11 0 0 0 0 0 0 3 40 8 A A A E E E 7 0 0 0 0 8 0 D 5 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 4C
*Mar 1 02:53:45.923: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:45.923: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:45.923: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:53:45.923: REM TX Message : 70 82 3E 10 40Fibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened:53:39.380: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:eceived E from 0 , valid : 64 length : 58
*Mar 1 02:53:45.957: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:53:45.957: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:53:46.854: Receiving message : 6E 2 0 0 70
*Mar 1 02:53:46.854: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:46.854: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:53:46.854: REM TX Message : 70 1 1 72
*Mar 1 02:53:46.854: POE_GET_EVENTS sent to E53:39.380: Succe
*Mar 1
*Mar 1 02:53:46.913: Entering hrm_mod_cpuq_di cmi=0 di=15F
*Mar 1 02:53:46.913: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:46.913: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:53:46.913: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:46.913: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:46.913: Receiving message : 60 2 0 0 62
*Mar 1 02:53:46.913: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:53:46.922: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:53:46.922: REM TX Message : 77 2 3E 0 B7Sent on 0 frame 78003F8
02:53:41.066: REM TX Message : 77 81 1 F9
*Mar 1 02:53:41.939: Receiving message :11 11 11 11 0 0 0 0 0 0 0 0 F 11 11 11 4 4 4 E A A A A 9 9 9 9 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 D1
*Mar 1 02:53:47.651: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:47.651: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:47.651: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:53:47.651: MDFS: RP servicing reload for LC in slot 1
*Mar 1 02:53:47.651: REM TX Message : 77 82 3E 10 47
*Mar 1 02:53:48.465: rok_thermal_processing : 2
*Mar 1 02:53:48.473: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 67 82 0 0 E9
*Mar
*Mar 1 02 0 0 E2
*Mar 1 02:53:48.532: REM TX Message : 37 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69
*Mar 1 02:53:48.532: REM TX Message : 3E 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F0
*Mar 1 02:53:48.532: REM TX Message : 3E 87 28 0 FF 0 0 0 0 EC
*Mar 1 02:53:48.532: REM TX Message : 7E 82 3E 0 3E
*Mar 1 02:53:48.541: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
Request 37 received from 1, length 38128Sent on 0 frame 78003F8
*Mar 1 02:53:49.254: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 D F F F 2 2 2 C 8 8 8 8 7 7 7 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0:53:42.677: hrpc_recv_message: recvd req ack src_bo
*Mar 1 02:53:44.329: EntMar 1 02:53:49.254: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:53:49.254: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:49.254: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:50.101: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:53:50.109: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:50.109: PoE message received E from E , valid : 64 length : 58ering hrm_mod_cpuq_di cmi=7 d
*Mar 1 02:53:50.160: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:53:50.160: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:53:50.160: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:50.168: Receiving message : 67 2 0 0 69
*Mar 1 02:53:50.168: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:50.168: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:53:50.168: REM TX Message : 77 81 1F 17
*Mar 1 02:53:50.738: Receiving message : 67 82 2E 0 17
*Mar 1 02:53:50.738: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:50.747: REM TX Message : 77 1 1D 95i=15F
*Mar 1 02:53:44.329: sf_asic_set_destmap: sfASIC:0 PortASIC
*Mar 1 02:53:45.957: lable:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:53:50.747: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:53:50.747: ERD available:1
*Mar 1 02:53:50.747: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:53:50.747: Fibs-ATMFail # of Covering fibs 0.Fib delete not happenedSent on 0 frame 78003F8
Received: pak 3B99374 datagramstart 7BD1E76
*Mar 1 02:53:51.544: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2ARE message recei
*Mar 1 02:53:51.628: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:51.628: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:53:51.628: Receiving message : 60 BA 0 0 31 33 11 11 11 11 11 11 0 0 0 0 0 0 3 40 7 E D C B B B 9 E E E E 8 D 7 10 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F3
*Mar 1 02:53:51.636: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:51.636: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:51.636: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:53:51.636: REM TX Message : 70 2 3E 10 C0Sent on 0 frame 78003F8
*Mar 1 02:53:45.957: PoE message rRecei0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:53:52.181: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:52.181: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:52.181: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:53:52.190: REM TX Message : 7E 81 1 0
*Mar 1 02:53:52.894: Receiving message : 6E 82 0 0 F0
*Mar 1 02:53:52.894: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:53:52.894: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:53:52.894: REM TX Message : 77 82ved: pak 3B98C4C datagramstart 7B 3E 0 37
*Mar 1 02:53:52.911: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
RFP = 0x0, WFP = 0x0, SRFP = 0x0, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:53:52.911: Curr: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
RFP = 0x0, WFP = 0x0, SRP = 0x0, PktFull = 0x0, FifoFull = 0x0,
networkTxReady = 0x1, TxBytes = 0x0
*Mar 1 02:53:52.911: Asic-Num 0, Port-Num 29, Is Port-Empty ? 1, W1 0x18001800, W2 0x1800
*Mar 1 02:53:52.911: Asic-Num 0, Port-Num 29, MatchCount 0
*Mar 1 02:53:52.911: D0CF6
*Mar 1 02:53:47.643: Receiving message : 67 3A 0 0 11 11 11 110 Port 1 Active :0
*Mar 1 02:53:52.953: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:52.953: Receiving message : 67 BA 0 0 11 11 11 11 33 33 33 33 0 0 0 0 0 0 0 0 7 E E E B B B 9 19 18 17 16 18 17 16 15 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 44
*Mar 1 02:53:52.961: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:53:52.961: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:53:52.961: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:53:52.961: REM TX Message : 77 2 3E 10 C7
*Mar 1 02:53:54.723: Receiving message : 6E 3A 0 0 11 11 11 11 33 33 33 33 0 0 0 0 0 0 0 0 4 B B B 8 8 8 6 5 4 3 2 4 3 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 13
*Mar 1 02:53:54.723: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:53:54.723: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:53:54.723: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:53:54.723: REM TX Message : 7E 82 3E 10 4E*Mar 1 02:53:49.254: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:00x1A40
RFP = 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:53:54.773: Curr: Asic 2, Port 10, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
RFP = 0x2, WFP = 0x2, SRP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:53:54.773: Asic-Num 2, Port-Num 10, Is Port-Empty ? 1, W1 0x1A401A40, W2 0x2221A40
*Mar 1 02:53:54.773: Asic-Num 2, Port-Num 10, MatchCount 0
*Mar 1 02:53:54.773: x34CEA74 RingMap:0x3C3F190
*Fibs-AdjFail Retry Q dept
*Mar 1 02:53:54.773: Prev: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:53:54.773: Curr: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:53:54.773: Asic-Num 2, Port-Num 21, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:53:54.773: Asic-Num 2, Port-Num 21, MatchCount 0
*Mar 1 02:53:54.773: h 0.Fib delete not happened, Adj not Vlan not modification happened
02:53:56.367: Receiving message : 67 82 2E 0 17
*Mar 1 02:53:56.367: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:53:56.367: REM TX Message : 77 1 1D 95Sent on 0 frame 78003F8
*Mar 1 02:53:57.139: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:53:57.139: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:53:57.139: sys vol 0 : 221,
*Mar 1 02:53:57.139: sys vol 1 : 212,
*Mar 1 02:53:57.139: sys vol 2 : 176,*Mar || HDR: src: 0x10000, dst: 0x10007, index: 0, seq: 0, sz: 12, type: 785, flags: 0x40 hi: 0x0, lo: 0x0 || DATA: 00 00 00 01 00 00 01 00 FF FF 01 00
*Mar 1 02:53:57.164: Receiving message : 60 BA 0 0
*Mar 1 02:53:57.164: MDFS: RP received IPC packet from LC in slot 1 of type download
*Mar 1 02:53:57.164: MDFS: RP received reload request from LC in slot 1 11 11 11 11 11 11 11 13 0 0 0 0 0 0 3 40 3 A A A A A A D A A A A 4 9 0 C 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 84
*Mar 1 02:53:57.994: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:57.994: PoE message received E from 0 , valid : 64 length : 58 1 02:53:50.747: MAD avai
*Mar 1 02:53:52.181: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0
*Mar 1 02:53:52.953: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:53:52.953: Port 0 Actar 1 02:53:58.053: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:53:58.053: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:53:58.053: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:53:58.062: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:53:58.062: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:53:58.062: Copy for instance 0, page 1, 58 bytes
eMar 1 02:53:58.062: REM TX Message : 70 81 1 F2iv
*Mar 1 02:53:58.791: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:53:58.791: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:53:58.791: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:58.791: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:53:59.664: obfl_io_flush_process: write lock acquired for 'obfl0::errmsg_cont'
*Mar 1 02:53:59.664: obfl_io_flush_process: write lock released for 'obfl0::errmsg_cont'
*Mar 1 02:53:59.664: obfl_io_flush_process: write lock acquired for 'obfl0::volt_cont'
*Mar 1 02:53:54.765: Prev: Asic 2, Port 10, RP = 0x1A40, WP = 0x1A40, SRP =
*Mar 1 02:53:56.367: Successful return from hrm_mod_cpuq_di
*Mar 1 02:53:56.367: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1
*Mar 1 02:53:58.053: Port 0 Enabled:0 Port 1 Enabled:0
*M
*Mar 1 02:53:59.723: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000828
*Mar 1 02:53:59.723: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:53:59.731: Invoking hrpc handler: 8h#
Swit sub 7, length:58 (No interrupt)
*Mar 1 02:54:00.335: PoE message received E from 7 , valid : 64 length : 58ch#
Switch#BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:00.335: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:54:00.335: REM TX Message : 7E 82 3E 0 3EFibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened
*Mar 1 02:54:00.335: MAD available:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:54:00.335: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:54:00.335: ERD available:1
*Mar 1 02:54:00.335: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:54:00.335: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:54:01.023: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0gth 38128
*Mar 1 02:54:00.327: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:54:00.335: RE messag.098: REM TX Message : 77 81 1 F9Sent on 0 frame 78003F8
*Mar 1 02:54:01.803: Receiving message : 67 82 0 0 E9
*Mar 1 02:54:01.803: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:01.803: RE_SYS : Interrupts pending for sub 7, apps 0Sent on 0 frame 78003F8
*Mar 1 02:54:01.803: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:54:01.803: SNMP: HC Timer 3B0D070 fired
*Mar 1 02:54:01.803: SNMP: HC Timer 3B0D070 rearmed, delay = 10000
*Mar 1 02:54:01.803: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:54:01.828: Receiving message : 60 3A 0e received from
Sw 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5A
*Mar 1 02:54:01.828: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:01.828: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:01.828: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:54:01.828: REM TX Message : 70 82 3E 10 40
*Mar 1 02:54:02.575: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1B
*Mar 1 02:54:02.583: RE message received from sub 0, length:58 (No interrupt)itch#
Switch#
Swit 1 02:54:02.667: REM TX Message : 77 1 1F 97
*Mar 1 02:54:03.221: Receiving message : 67 2 2E 0 97
*Mar 1 02:54:03.221: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:03.221: REM TX Message : 77 81 1D 15
*Mar 1 02:54:03.221: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:54:03.221: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:54:03.221: Entering hrm_get_cpuq_cmi cpu=6
*Mar 1 02:54:03.221: Successful return from hrm_get_cpuq_cmi
*Mar 1 02:54:03.221: Entering hrm_mod_cpuq_di cmi=7 di=15F
*Mar 1 02:54:03.221: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190ch#
S
*Mar 1 02:54:03.221: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:54:03.221: Successful return from hrm_mod_cpuq_di
*Mar 1 02:54:03.221: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:54:04.085: Receiving message : 67 8A DD D4 B0 84 9E 7E 69 4F 0 0 AA
*Mar 1 02:54:04.085: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:54:04.085: sys vol 0 : 221,
*Mar 1 02:54:04.085: sys vol 1 : 212,
*Mar 1 02:54:04.085: sys vol 2 : 176,
*Mar 1 02:54:04.085: sys vol 3 : 132,
*Mar 1 02:54:04.085: sys vol 4 : 158,
*Mar 1 02:54:04.085: sys vol 5 : 126,
*Mar 1 02:54:04.085: sys vol 6 : 105,witch#
Switch#
Port 1 Active :0
*Mar 1 02:54:04.135: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:04.143: Receiving message : 67 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 4 10 10 10 9 9 9 11 6 6 6 6 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 B5
*Mar 1 02:54:04.143: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:04.143: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:04.143: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:54:04.143: REM TX Message : 77 82 3E 10 47Switch#
Switch# 0 0 0
*Mar 1 02:54:04.697: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000829
*Mar 1 02:54:04.697: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:54:04.697: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:05.586: Receiving message : 6E 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 A 5 5 5 F F F 6 C C C C B B B B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 D8
*Mar 1 02:54:05.586: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:05.595: PoE message received E from E , valid : 64 length : 58 0 0 0 0
Switch#
Switch#ttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:54:05.653: Receiving message : 6E BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26
*Mar 1 02:54:05.653: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:05.653: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:05.653: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:54:05.653: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:54:06.341: Receiving message : 6E 2 0 0 70
Sw
*Mar 1 02:54:06.341: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:06.341: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:54:06.341: REM TX Message : 30 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 62
*Mar 1 02:54:06.341: REM TX Message : 37 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69
*Mar 1 02:54:06.341: REM TX Message : 3E 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F0
*Mar 1 02:54:06.341: REM TX Message : 3E 87 28 0 FF 0 0 0 0 EC
*Mar 1 02:54:06.341: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:54:07.214: Receiving message : 60 3A 0 0 33 33 11 31 11 11 11 11 0 0 0 0 0 0 3 40 0 5 4 3 5 5 5 4 2 2 2 2 D 1 C 4 0 0 0 0 0 0 0 10 0 0itch#
Switch#
Switch#
*Mar 1 02:54:07.281: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:07.281: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:07.281: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:07.281: REM TX Message : 77 1 1F 97Sent on 0 frame 78003F8
*Mar 1 02:54:08.019: Receiving message : 67 2 2E 0 97Switch#
*Mar 1 02:54:08.044: sys vol 4 : 158,
*Mar 1 02:54:08.044: sys vol 5 : 126,
*Mar 1 02:54:08.044: sys vol 6 : 105,
*Mar 1 02:54:08.044: sys vol 7 : 79,
*Mar 1 02:54:08.044: REM TX Message : 77 2 3E 0 B7
*Mar 1 02:54:08.933: Receiving message : 67 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 C C C C C C C B 9 9 9 9 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 CC
*Mar 1 02:54:08.933: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:08.933: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:08.933: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:54:08.933: REM TX Message : 77 82 3E 10 47Sent on 0 frame 78003F8
Switch#
Switch#
Switch#
Swi 1 Active :0
*Mar 1 02:54:08.992: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:08.992: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:54:08.992: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:08.992: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:08.992: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:54:09.000: REM TX Message : 70 1 1 72tch#
Switch#
Switch#nodebugal
*Mar
*Mar 1 02:54:04.135: Port 0 Enab
*Mar 1 02:54:09.697: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:54:09.697: Fibs-ATMFail # of Covering fibs 0.Fib delete not happenedSent on 0 frame 78003F8
*Mar 1 02:54:10.527: Receiving message : 6E BA 0 0 11 11 33 13 33 33 33 33 0 0 0 0 0 0 0 0 9 9 9 9 3 2 1 8 11 10 F E 10 F E D 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 6
*Mar 1 02:54:10.527: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:10.527: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:10.527: Copy for instance 2, page 0, 58 bytesled:0 Port 1 Enab0000082A, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0000, size: 0x05B8
*Mar 1 02:54:10.594: hrpc_send_req_ack: sending req_ack for request 2090
*Mar 1 02:54:10.594: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x0000082A
*Mar 1 02:54:10.594: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:54:10.594: Receiving message : 6E 3A 0 0 FF
*Mar 1 02:54:10.594: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
Request 37 received from 1, length 38128 FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0led:0
*Mar 1 02:54:04.135: Port 0 Active :0
*Mar 1 02:54:05.64 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:54:11.316: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:11.316: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:11.316: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:54:11.316: REM TX Message : 70 82 3E 0 30Sent on 0 frame 78003F8
*Mar 1 02:54:12.154: Receiving message : 60 BA 0 0 11 11 11 31 11 11 11 11 0 0 0 0 0 0 3 40 10 10 10 10 2 2 2 17 D D D D 7 C 6 F 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 CE
*Mar 1 02:54:12.163: RE message received from sub 0, length:58 (No interrupt)5: Successful return from h2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:54:12.188: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:54:12.188: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:54:12.188: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:54:12.188: rm_mod_cpuq_di
*Mar 1 02:54:05.645: Throttled: ARP thro
*Mar 1 02:54:12.196: Prev: Asic 1, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:54:12.196: Curr: Asic 1, Port 17, RP = 0x8C0, WP = 0x8C0, SRP = 0x8C0
*Mar 1 02:54:12.196: Asic-Num 1, Port-Num 17, Is Port-Empty ? 1, W1 0x8C008C0, W2 0x22208C0
*Mar 1 02:54:12.196: Asic-Num 1, Port-Num 17, MatchCount 0
*Mar 1 02:54:12.196: Successful return from hdm_poll_device_n_stackp15.158: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:54:15.158: REM TX Message : 70 1 1 72
*Mar 1 02:54:16.055: Receiving message : 60 2 0 0 62
*Mar 1 02:54:16.055: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:54:16.055: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:54:16.055: REM TX Message : 77 1 1 79
*Mar 1 02:54:16.055: hrpc_send_request: sending 27 msgs, seq_num 2091, req_num 37 class 14
*Mar 1 02:54:16.055: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x0000082B, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0006, size: 0x05B8ort_status
*Mar 1 02:54:07.281: Receiving
*Mar 1 02:54:08.992: Port 0 Enabled:0 Por
*Mar 1 02:54:16.114: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:54:16.114: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:54:16.114: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:16.114: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:16.114: Receiving message : 67 2 0 0 69
*Mar 1 02:54:16.114: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:16.114: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:54:16.114: REM TX Message : 7E 81 1 0
*Mar 1 02:54:16.902: Receiving message : 6E 82 0 0 F0t 1 Enabled:0
*Mar 1 02:apps 0
*Mar 1 02:54:16.902: REM TX Message : 70 82 3E 0 30
*Mar 1 02:54:17.733: Receiving message : 60 BA 0 0 11 11 11 11 33 33 31 11 0 0 0 0 0 0 3 40 1 6 6 6 2 2 2 3 15 14 13 12 4 13 3 C 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E9
*Mar 1 02:54:17.741: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:17.741: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:17.741: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:54:17.741: REM TX Message : 70 2 3E 10 C054:08.992: Port 0 Active :0 Port
*Mar 1 02:54:10.59
*Mar 1 02:54:17.808: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:17.808: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:17.808: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:17.808: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:54:18.547: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:18.547: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:18.547: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:54:18.547: REM TX Message : 70 81 1 F2Fibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened4: hrpc_recv_message: recvd req s_availability_status:2287
*Mar 1 02:54:18.547: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:54:18.547: ERD available:1
*Mar 1 02:54:18.547: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:54:18.547: Fibs-ATMFail # of Covering fibs 0.Fib delete not happenedSent on 0 frame 78003F8
Received: pak 3B98FE0 datagramstart 7BD15B6
*Mar 1 02:54:19.377: Receiving message : 60 82 0 0 E2
*Mar 1 02:54:19.377: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:54:19.377: RE_SYS : Interrupts pending for sub 0, apps 0msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x
*Mar 1 02:54:12.188: Prev:
*Mar 1 02:54:19.461: voltage_recorder_process: ct(730954459)-pt(730944376) = 10083, frequency =1, max_time_for_logging =720
*Mar 1 02:54:19.461: REM TX Message : 77 2 3E 10 C7Sent on 0 frame 78003F8
Received: pak 3B99708 datagramstart 7BD2736
*Mar 1 02:54:20.182: rok_thermal_processing : 2
*Mar 1 02:54:20.182: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:54:20.191: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:20.191: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:20.191: Copy for instance 1, page 1, 58 bytesAsic 1id wkt 43, vlan 0
*Mar 1 02:54:20.191: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:54:20.191: Entering hrm_mod_cpuq_di cmi=0 di=15F
*Mar 1 02:54:20.191: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:54:20.191: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:54:20.191: Successful return from hrm_mod_cpuq_di
*Mar 1 02:54:20.191: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0), Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
RFP = 0x
*Mar 1 02:54:15.15
*Mar 1 02:54:21.055: Prev: Asic 1, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:54:21.055: Curr: Asic 1, Port 14, RP = 0x140, WP = 0x140, SRP = 0x140
*Mar 1 02:54:21.055: Asic-Num 1, Port-Num 14, Is Port-Empty ? 1, W1 0x1400140, W2 0x2220140
*Mar 1 02:54:21.055: Asic-Num 1, Port-Num 14, MatchCount 0
*Mar 1 02:54:21.055: 8: %SYS-3-LOGGER_DROPPED: System dropped 1900 console d SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:54:21.055: Curr: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:54:21.055: Asic-Num 1, Port-Num 16, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:54:21.055: Asic-Num 1, Port-Num 16, MatchCount 0
*Mar 1 02:54:21.055: ebug messages.
*Mar 1 02:54:
*Mar 1 02:54:16.902: RE message received from su
*Mar 1 02:54:22.472: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:22.472: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:22.472: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:54:22.472: REM TX Message : 7E 82 3E 10 4E
*Mar 1 02:54:23.160: Receiving message : 6E BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26
*Mar 1 02:54:23.160: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:23.160: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:23.169: Copy for instance 2, page 1, 58 bytesb E, length:2 (No interruptan not modification happened
*Mar 1 02:54:23.169: MAD available:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:54:23.169: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:54:23.169: ERD available:1
*Mar 1 02:54:23.169: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:54:23.169: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:54:24.075: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:24.075: RE message received from sub E, length:2 (No interrupt))
*Mar 1 02:54:16.902: RE_SYS : Interrupts pending for sub 14,
*Mar 1 02:54:18.5
*Mar 1 02:54:24.133: REM TX Message : 77 1 1F 97
*Mar 1 02:54:24.737: Receiving message : 67 2 2E 0 97
*Mar 1 02:54:24.737: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:24.737: REM TX Message : 77 81 1D 15
*Mar 1 02:54:24.737: hl3mm: RPF throttling, total h/w routes 0
*Mar 1 02:54:24.737: rpf timer restart period 5000
*Mar 1 02:54:24.754: hrpc_send_request: sending 27 msgs, seq_num 2093, req_num 37 class 14
*Mar 1 02:54:24.754: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x0000082D, flags: 0x0002, num_frags: 0x001B, frag_num: 0x001A, size: 0x004447: MAD availa1 02:54:24.763: REM TX Message : 70 82 3E 0 30Sent on 0 frame 78003F8
Received: pak 3B98C4C datagramstart 7BD0CF6
*Mar 1 02:54:25.576: rok_thermal_processing : 2
*Mar 1 02:54:25.576: Receiving message : 60 BA 0 0 11 11Sent on 0 frame 78003F8
11 11 11 11 31 11 0 0 0 0 0 0 3 40 E 7 7 7 D D D A 1 1 1 1 C 1B B 3 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A2
*Mar 1 02:54:25.585: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:25.585: PoE message received E from 0 , valid : 64 length : 58ble:1, Stn available:1, Src:hcef_adj_update_hw_resource
*Mar 1 02:54:25.643: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:25.643: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:25.643: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:25.643: REM TX Message : 77 1 1 79
*Mar 1 02:54:26.256: Receiving message : 67 2 0 0 69
*Mar 1 02:54:26.256: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:26.256: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:54:26.256: REM TX Message : 77 82 3E 0 37
*Mar 1 02:54:26.281: Receiving message : 67 BA 0 0 11 11 11 11 33 33 33 33 0 0 0 0 0 0 0 0 9 2 2 2 8 8 8 5 7 6 5 4 6 5 4 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0M TX Message : 77 81 1 FMar 1 02:54:26.281: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:26.281: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:54:26.281: REM TX Message : 77 2 3E 10 C7Sent on 0 frame 78003F8
*Mar 1 02:54:27.128: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:54:27.136: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:27.136: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:20.191: Entering hrm_get_well_known_di_with_mv
*Mar 1 02:54:27.195: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:54:27.195: Receiving message : 6E 82 0 0 F0
*Mar 1 02:54:27.195: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:27.195: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:54:27.204: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:27.204: REM TX Message : 7E 2 3E 0 BE
*Mar 1 02:54:27.950: Receiving message : 6E 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 7 11 11 11 6 6 6 3 B B B B A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 D3rt 16, RP = 0x640, WP = 0x64 1 02:54:27.959: MDFS: RP received reload request from LC in slot 1
*Mar 1 02:54:28.856: Receiving message : 6E BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26
*Mar 1 02:54:28.856: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:28.856: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:28.856: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:54:28.865: REM TX Message : 7E 2 3F 0 BF0, SRP = 0x640
*Mar 1 02:54:23.169: REM TX Message : 7E 2 3F 0 0 F0
*Mar 1 02:54:28.923: REM TX Message : 77 81 1F 17Sent on 0 frame 78003F8
*Mar 1 02:54:29.628: Receiving message : 67 82 2E 0 17
*Mar 1 02:54:29.628: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:29.628: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:54:29.628: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:54:29.628: Entering hrm_mod_cpuq_di cmi=0 di=15F
*Mar 1 02:54:29.628: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:54:29.628: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003 0 BFFibs-AdjFail Retry Q deptDI=0x15F,CMI=0x0)
*Mar 1 02:54:29.628: REM TX Message : 77 1 1D 95
*Mar 1 02:54:30.484: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:54:30.484: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:54:30.484: sys vol 0 : 221,
*Mar 1 02:54:30.484: sys vol 1 : 212,
*Mar 1 02:54:30.484: sys vol 2 : 176,
*Mar 1 02:54:30.484: sys vol 3 : 132,
*Mar 1 02:54:30.484: sys vol 4 : 158,
*Mar 1 02:54:30.484: sys vol 5 : 126,
*Mar 1 02:54:30.484: sys vol 6 : 105,
*Mar 1 02:54:30.484: sys vol 7 : 79,h 0.Fib delete not happened, Adj not Vl
*Mar 1 02:54:24.763: sys vol 7 : 79,
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock acquired for 'obfl0::env_hist'
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock released for 'obfl0::env_hist'
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock acquired for 'obfl0::env_cont'
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock released for 'obfl0::env_cont'
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock acquired for 'obfl0::temp_cont'
*Mar 1 02:54:30.576: obfl_io_flush_process: write lock released for 'obfl0::temp_cont'
*Mar 1 02:54:31.222: rok_thermal_processing : 2
*Mar 1 02:54:31.222: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0Mar 1 02:54:ub 0, length:58 (No interrupt)
*Mar 1 02:54:31.230: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:31.230: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:31.230: REM TX Message : 70 81 1 F2Sent on 0 frame 78003F8
*Mar 1 02:54:32.069: Receiving message : 60 82 0 0 E2
*Mar 1 02:54:32.069: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:54:32.069: RE_SYS : Interrupts pending for sub 0, apps 0Sent on 0 frame 78003F8
24.763: REM TX Message : 3E 87 28 0 FF 0 0 0 0 EC
*Mar 0 0 0 0 85
*Mar 1 02:54:26.281
*Mar 1 02:54:32.128: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:54:32.128: Receiving message : 67 BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 5 3 3 3 2 2 2 4 4 4 4 4 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DD
*Mar 1 02:54:32.128: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:32.128: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:32.128: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:54:32.128: REM TX Message : 77 2 3E 10 C7
*Mar 1 02:54:32.916: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0: RE me
*Mar 1 02:54:32.925: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x0000082E, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0000, size: 0x05B8
*Mar 1 02:54:32.925: hrpc_send_req_ack: sending req_ack for request 2094
*Mar 1 02:54:32.925: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x0000082E
*Mar 1 02:54:32.925: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:54:32.933: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:33.654: Receiving message : 67 82 0 0 E9ssage received from sub 7, length:58 (No interrupt)
*00 01 00 00 01 00 FF FF 01 00
*Mar 1 02:54:27.959: MDFS: RP received IPC packet from LC in slot 1 of type download
*Mar
*Mar 1 02:54:29.628: Successful return from hrm_mod_cpuq_di
*Mar 1 02:54:29.628: Throttled: ARP throttle Adj( 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:54:31.230: RE message received from s
*Mar 1 02:54:33.705: Prev: Asic 2, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
RFP = 0x2, WFP = 0x2, SRFl
Switch#nodebugall
Translating "nodebugall"...domain server (255.255.255.255)P = 0x2, PktFull = 0x0, FifoFull = 0 = 0x12C0
*Mar 1 02:54:33.705: Curr: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:54:33.705: Asic-Num 2, Port-Num 21, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:54:33.705: Asic-Num 2, Port-Num 21, MatchCount 0
*Mar 1 02:54:33.705: x0,
TxBytes = 0x0,
*Mar 1 02:54:35.148: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:54:35.148: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:54:35.148: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:35.148: Receiving message : 6E 82 0 0 F0
*Mar 1 02:54:35.148: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:35.148: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:54:35.156: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:54:35.777: Receiving message : 60 3A 0 0 31 33 11 31 11 11 11 11 0 0 0 0 0 0 3 40 E 5 4 3 E E E 4 D D D D 7 C 6 F 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7BMatchCount = 0
*Mar 1 02:54:33.705: Curr: Asic 2, Port 19, RP = 0xDC0, WP =h:58 (No interrupt)
*Mar 1 02:54:35.810: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:35.810: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:35.810: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:54:36.532: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:36.532: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:36.532: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:54:36.532: rok_thermal_processing : 2
*Mar 1 02:54:36.532: REM TX Message : 3F 1 3 43
*Mar 1 02:54:36.532: REM TX Message : 30 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 62 0xDC0, SRP = 0xDC0
*Mar 1 02:54:36.582: Curr: Asic 2, Port 10, RP = 0x1A40, WP = 0x1A40, SRP = 0x1A40
*Mar 1 02:54:36.582: Asic-Num 2, Port-Num 10, Is Port-Empty ? 1, W1 0x1A401A40, W2 0x2221A40
*Mar 1 02:54:36.582: Asic-Num 2, Port-Num 10, MatchCount 0
*Mar 1 02:54:36.590: Prev: Asic 2, Port 11, RP = 0x1CC0, WP = 0x1CC0, SRP = 0x1CC0
TxBytes = 0x0, MatchCount = 0 = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:54:ll = 0x0, FifoFull = 0x0,
*Mar 1 02:54:36.590: Asic-Num 2, Port-Num 20, Is Port-Empty ? 1, W1 0x10401040, W2 0x2221040
*Mar 1 02:54:36.590: Asic-Num 2, Port-Num 20, MatchCount 0
*Mar 1 02:54:36.590: Prev: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
TxBytes = 0x0, MatchCount = 033.705: Asic-Num 2, Por
*Mar 1 02:54:38.126: Prev: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:54:38.126: Curr: Asic 1, Port 16, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:54:38.126: Asic-Num 1, Port-Num 16, Is Port-Empty ? 1, W1 0x6400640, W2 0x2220640
*Mar 1 02:54:38.126: Asic-Num 1, Port-Num 16, MatchCount 0
*Mar 1 02:54:38.134: t-Num 19, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:54:33.705: Asic-Num 2, P 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:54:38.134: Curr: Asic 1, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:54:38.134: Asic-Num 1, Port-Num 19, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:54:38.134: Asic-Num 1, Port-Num 19, MatchCount 0
*Mar 1 02:54:38.134: ort-Num 19, MatchCount 0
*Mar 1
*Mar 1 02:54:41.154: %SYS-3-LOGGER_DROPPED: System dropped 1513 console debug messages.
02:54:33.705:
*Mar 1 02:54:
*Mar 1 02:54:41.154: Receiving message : 67 82 0 0 E9
*Mar 1 02:54:41.154: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:41.154: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:54:41.154: REM TX Message : 7E 1 1 80Sent on 0 frame 78003F8
*Mar 1 02:54:41.179: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:41.179: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:41.179: RE_SYS : Interrupts pending for sub 14, apps 0Sent on 0 frame 78003F8
33.705: Prev: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP
*Mar 1 02:54:35.es = 0x0, MatchCount = 0
*Mar 1 02:54:42.211: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:54:42.219: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:54:42.219: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:54:42.219: 810: RE message received
*Mar 1 02:54:45.331: %SYS-3-LOGGER_DROPPED: System dropped 778 console debug messages.
from sub 0, lengt
*Mar 1 02:54:
*Mar 1 02:54:45.331: POE_GET_EVENTS sent to E
*Mar 1 02:54:45.331: REM TX Message : 7E 2 3E 0 BESent on 0 frame 78003F8
*Mar 1 02:54:46.212: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
*Mar 1 02:54:46.212: Curr: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
networkTxReady = 0x1, TxBytes = 0x036.590: Curr: Asic 2, Port 20, RP = 0x1040, WP = 0x1040, SRP = 0x1040
RFP = 0x2, WFP = 0x2, SRwrite lock acquired for 'obfl0::env_cont'
*Mar 1 02:54:46.288: obfl_io_flush_process: write lock released for 'obfl0::env_cont'
*Mar 1 02:54:46.288: obfl_io_flush_process: write lock acquired for 'obfl0::temp_cont'
*Mar 1 02:54:46.288: obfl_io_flush_process: write lock released for 'obfl0::temp_cont'
*Mar 1 02:54:47.152: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:47.152: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:47.152: PoE message received F from E , valid : 64 length : 2P = 0x2, PktFu
*Mar 1 02:54:38
*Mar 1 02:54:47.152: REM TX Message : 70 81 1 F2
*Mar 1 02:54:47.152: POE_GET_EVENTS sent to ESent on 0 frame 78003F8
*Mar 1 02:54:47.865: rok_thermal_processing : 2
*Mar 1 02:54:47.865: Receiving message : 60 82 0 0 E2
*Mar 1 02:54:47.865: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:54:47.873: RE_SYS : Interrupts pending for sub 0, apps 0Sent on 0 frame 78003F8
*Mar 1 02:54:47.882: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
TxBytes = 0x0, MatchCount = 0.134: Prev: Asic 1, Port 19, RP = 0xDC0, WP = 0xDC0, SRP = 0xD 02:54:47.923: drop_adj: Cnt:0
*Mar 1 02:54:47.923: Updating HWL:0, HWS:0, URes:0 USup:0, NAdj:0,EncF:0, CPU:0, Null:0, Drop:0
*Mar 1 02:54:47.923: Sending HWL:0, HWS:0, URes:0 USup:0, NAdj:0,EncF:0, CPU:0, Null:0, Drop:0
*Mar 1 02:54:47.932: REM TX Message : 77 1 1 79
*Mar 1 02:54:48.796: Receiving message : 67 2 0 0 69
*Mar 1 02:54:48.796: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:48.796: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:54:48.796: REM TX Message : 7E 81 1 0C0
*Mar 1 02:54:48.804: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000831, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0000, size: 0x05B8
*Mar 1 02:54:48.804: hrpc_send_req_ack: sending req_ack for request 2097
*Mar 1 02:54:48.804: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000831
*Mar 1 02:54:48.804: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:54:48.804: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:49.484: Receiving message : 6E 82 0 0 F0 =
*Mar 1 02:54:42.211: Prev: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0ed:0 Port 1 Enabled:0
*Mar 1 02:54:49.542: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:54:49.542: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:49.542: Receiving message : 60 3A 0 0 31 33 11 11 33 33 31 11 0 0 0 0 0 0 3 40 5 6 5 4 1 1 1 1 16 15 14 13 5 14 4 D 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 AF
*Mar 1 02:54:49.551: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:49.551: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:49.551: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:54:49.551: REM TX Message : 70 82 3E 10 40, SRP
*Mar 1 02:54:50.448: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1B
*Mar 1 02:54:50.448: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:50.448: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:50.448: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:50.448: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:54:51.153: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:51.153: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:51.153: PoE message received F from E , valid : 64 length : 2= 0xDC0
TxByt
*Mar 1 02:54:46.288: obfl_io_flush_process: write lock released for 'obfl0::env_hist'
*Mar 1 02:54:47.923: Entering hrm_read_sbd table=6, si=F
*Mar 1 02:54:47.923: Successful return from hrm_read_sbd
*Mar 1
% Unknown command or computer name, or unable to
*Mar 1 02:54:49.542: Port 0 Enabl
*Mar 1 02:54:51.203: madmax_asic_set_ring_map: Address: 0x5001057C Val: find computer address
Switch1 02:54:51.212: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:51.212: REM TX Message : 77 1 1D 95
*Mar 1 02:54:52.109: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:54:52.109: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:54:52.109: sys vol 0 : 221,
*Mar 1 02:54:52.109: sys vol 1 : 212,
*Mar 1 02:54:52.109: sys vol 2 : 176,#
Switch#no deb
Switch#no debug al
Switch#no debug0x00000043
*Mar 1 02:54:51.203: Successful return from hrm_mod_cpuq_di
*Mar 1 02:54:51.203: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:54:51.212: Receiving message : 67 82 2E 0 17
*Mar
*Mar 1 02:54:52.135: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000832, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0007, size: 0x05B8
*Mar 1 02:54:52.135: SNMP: HC Timer 3ADDB8C fired
*Mar 1 02:54:52.135: SNMP: HC Timer 3ADDB8C rearmed, delay = 5000
*Mar 1 02:54:52.135: POE_GET_EVENTS sent to E
*Mar 1 02:54:52.135: Receiving message : 60 2 0 0 62
*Mar 1 02:54:52.135: RE message r all
Switch#eceived from sub 0, length:2 (No interrupt)
*Mar 1 02:54:52.135: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:54:52.135: REM TX Message : 77 82 3E 0 37Sent on 0 frame 78003F8
*Mar 1 02:54:52.873: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:54:52.873: rok_thermal_processing : 2
*Mar
Switch# 1 02:54:52.873: REM TX Message : 77 2 3E 10 C7
*Mar 1 02:54:53.703: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:54:53.703: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:53.703: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:54:53.703: Copy for instance 1, page 1, 58
Switch bytes
*Mar 1 02:54:53.712: REM TX Message : 77 81 1 F9 cmi=0 di=15F
*Mar 1 02:54:53.712: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA7#
Switch#no debug all
All possible debugging has been turned off
Switch#
Translating "yes"...domain server (255.255.255.255)4 RingMap:0x3C3F190
*Mar 1 02:54:53.712: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:54:53.712: Successful return from hrm_mod_cpuq_di
*Mar 1 02:54:53.712: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
*Mar 1 02:54:53.712: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:54:53.712: SNMP: HC Timer 3B0D070 fired
*Mar 1 02:54:53.712: SNMP: HC Timer 3B0D070 rearmed, delay = 10000Sent on 0 frame 78003F8
*Mar 1 02:54:54.458: Receiving message : 67 82 0 0 E9
*Mar 1 02:54:54.517: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000832
*Mar 1 02:54:54.517: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:54:54.517: Receiving message : 6E 82 0 0 F0
*Mar 1 02:54:54.517: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:54.517: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:54:54.517: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:54:54.525: REM TX Message : 7E 2 3E 0 BE
*Mar 1 02:54:55.389: Receiving message : 6E 3A 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 7 3 3 3 1 1 1 6 8 8 8 8 7 7 7 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 85
*Mar 1 02:54:55.389: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:55.389: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:55.389: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:54:55.398: REM TX Message : 7E 82 3E 10 4E
*Mar 1 02:54:55.985: Receiving message : 6E BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26
*Mar 1 02:54:55.985: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:54:55.985: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:54:56.052: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:56.052: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:56.052: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:54:56.052: REM TX Message : 70 2 3E 10 C0Sent on 0 frame 78003F8
*Mar 1 02:54:56.757: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:54:56.765: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:54:56.765: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:54:56.765: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:54:56.765: REM TX Message : 7E 2 3F 0 BF
*Mar 1 02:54:56.790: Receiving message : 6E 2 0 0 70
*Mar 1 02:54:56.790: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:54:56.790: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:54:56.790: REM TX Message : 30 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E2
*Mar 1 02:54:56.790: REM TX Message : 37 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69
*Mar 1 02:54:56.790: REM TX Message : 3E 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 F0
*Mar 1 02:54:56.790: REM TX Message : 3E 87 28 0 FF 0 0 0 0 EC
*Mar 1 02:54:56.790: REM TX Message : 70 81 1 F2Sent on 0 frame 78003F8
*Mar 1 02:54:57.596: Receiving message : 60 82 0 0 E2
*Mar 1 02:54:57.596: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:54:57.596: RE_SYS : Interrupts pending for sub 0, apps 0Sent on 0 frame 78003F8
*Mar 1 02:54:57.612: Prev: Asic 0, Port 29, RP = 0x1800, WP = 0x1800, SRP = 0x1800
*Mar 1 02:54:57.679: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:54:57.679: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:54:57.679: Receiving message : 67 2 2E 0 97
*Mar 1 02:54:57.679: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:54:57.679: REM TX Message : 77 81 1D 15
*Mar 1 02:54:58.560: Receiving message : 67 8A DD D4 B0 84 9E 7E 69 4F 0 0 AA
*Mar 1 02:54:58.560: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:54:58.560: sys vol 0 : 221,
*Mar 1 02:54:58.560: sys vol 1 : 212,
*Mar 1 02:54:58.560: sys vol 2 : 176,
*Mar 1 02:54:58.560: sys vol 3 : 132,
% Unknown command or computer name, or unable to find computer addressf type download
*Mar 1 02:54:58.569: MDFS: RP received reload request from LC in slot 1
*Mar 1 02:54:59.240: Receiving message : 67 3A 0 0 11 11 33 33 33 33 33 33 0 0 0 0 0 0 0 0 4 A A A 1A 19 18 B 10 F E D F E D C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 DD
*Mar 1 02:54:59.240: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:59.240: PoE witch#
Switch#
Smessage received E from 7 , valid : 64 length : 58
*Mar 1 02:54:59.240: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:54:59.240: REM TX Message : 77 82 3E 10 47
*Mar 1 02:54:59.298: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:54:59.298: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:54:59.298: Successful return from hdm_witch#
Switch#
Switcpoll_device_n_stackport_status
*Mar 1 02:54:59.298: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:54:59.298: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:54:59.307: PoE message received E from 7 , valid : 64 lenh#
Switcgth : 58
*Mar 1 02:54:59.307: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:54:59.307: REM TX Message : 77 1 1 79Sent on 0 frame 78003F8
*Mar 1 02:55:00.104: hrpc_recv_message: recvd req ack src_box: 1, dest_box: 1 code: success, seq_num: 0x00000833
*Mar 1 02:55:00.104: hrpc_recv_req_frag: Handler OK 3CB27E8
*Mar 1 02:55:00.104: Invoking hrph#
Sc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:55:00.859: Receiving message : 6E BA 0 0 13 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 E 9 9 9 11 11 11 A 4 4 4 4 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 34
*Mar 1 02:55:00.859: RE message received from sub E, lengthwitch#
Switch#
Switc:58 (No interrupt)
*Mar 1 02:55:00.859: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:00.917: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:55:00.917: Successful return from hrm_mod_cpuq_di
*Mar 1 02:55:00.917: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:55:00.917: Receiving message : 6h#
*Mar 1 02:55:00.917: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:00.917: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:00.917: Copy for instance 2, page 1, 58 bytes
Switch#Mar 1 02:55:00.926: REM TX Message : 7E 81 1 0
*Mar 1 02:55:01.815: Receiving message : 6E 82 0 0 F0
*Mar 1 02:55:01.815: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:01.815: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:55:01.815: REM TX Message : 70 2 3E 0 B0
*Mar 1 02:55:02.427: obfl_io_flush_process: write lock acquired for 'obfl0::errmsg_cont'
*Mar 1 02:55:02.427: obfl_io_flush_process: write lock released for 'obfl0::errmsg_cont'
*Mar 1 02:55:02.427: obfl_io_flush_process: write lock acquired for 'obfl0::volt_cont'
*Mar 1 02:55:02.427: obfl_io_flush_process: write lock released for 'obfl0::volt_cont'
*Mar 1 02:55:02.486: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:55:02.486: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:55:02.486: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:55:02.486: REM TX Message : 70 82 3E 10 40
*Mar 1 02:55:03.199: Receiving message : 60 BA 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1B
*Mar 1 02:55:03.208: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:55:03.208: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:55:03.208: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:55:03.233: REM TX Message : 30 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E2
*Mar 1 02:55:03.233: REM TX Message : 37 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E9
*Mar 1 02:55:03.233: REM TX Message : 3E 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 70
*Mar 1 02:55:03.241: REM TX Message : 3E 7 28 0 FF 0 0 0 0 6C
*Mar 1 02:55:03.241: REM TX Message : 77 81 1F 17
*Mar 1 02:55:03.811: Receiving message : 67 82 2E 0 17
*Mar 1 02:55:03.811: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:55:03.811: rok_thermal_processing : 2
*Mar 1 02:55:03.811: REM TX Message : 77 1 1D 95
*Mar 1 02:55:03.820: MDFS: RP servicing reload for LC in slot 1
*Mar 1 02:55:03.879: hulc_ethernet_periodic for FastEthernet0-Physical
*Mar 1 02:55:03.879: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:55:03.879: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:55:03.879: sys vol 0 : 221,
*Mar 1 02:55:03.879: sys vol 1 : 212,
*Mar 1 02:55:03.879: sys vol 2 : 176,
*Mar 1 02:55:03.879: sys vol 3 : 132,
*Mar 1 02:55:03.879: sys vol 4 : 158,
*Mar 1 02:55:03.879: sys vol 5 : 126,
*Mar 1 02:55:03.879: sys vol 6 : 105,
*Mar 1 02:55:03.879: sys vol 7 : 79,
*Mar 1 02:55:03.879: REM TX Message : 77 82 3E 0 37
*Mar 1 02:55:04.743: Receiving message : 67 BA 0 0 31 33 11 31 11 11 11 11 0 0 0 0 0 0 0 0 C 17 16 15 4 4 4 16 8 8 8 8 7 7 7 7 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 B7
*Mar 1 02:55:04.743: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:55:04.743: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:55:04.743: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:55:04.751: REM TX Message : 77 2 3E 10 C7
*Mar 1 02:55:05.464: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:55:05.464: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:55:05.531: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:05.531: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:55:05.531: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128
Switch# bytesHQM: hqm_request_handler
*Mar 1 02:55:05.531: REM TX Message : 7E 82 3E 0 3E
*Mar 1 02:55:06.378: Receiving message : 6E BA 0 0 11 11 33 13 11 11 11 11 0 0 0 0 0 0 0 0 8 2 2 2 B A 9 1 4 4 4 4 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1D
*Mar 1 02:55:06.378: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:06.378: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:06.378: Copy for instance 2, page
Switch#0, 58 bytes
*Mar 1 02:55:06.378: REM TX Message : 7E 2 3E 10 CE
*Mar 1 02:55:06.387: POE_GET_EVENTS sent to ESent on 0 frame 78003F8
*Mar 1 02:55:07.117: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:55:07.117: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:07.117: PoE message received E from E , valid : 64 length :
Switch#58
*Mar 1 02:55:07.167: Port 0 Enabled:0 Port 1 Enabled:0
*Mar 1 02:55:07.167: Port 0 Active :0 Port 1 Active :0
*Mar 1 02:55:07.167: Successful return from hdm_poll_device_n_stackport_status
*Mar 1 02:55:07.175: REM TX Message : 77 81 1 F9
*Mar 1 02:55:08.073: Receiving message : 67 82 0 0 E9
*Mar 1 02:55:08.073: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:55:08.073: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:55:08.073: REM TX Messag
Switch#e : 3F 1 3 43
*Mar 1 02:55:08.073: REM TX Message : 70 82 3E 0 30Fibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened
*Mar 1 02:55:08.081: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:0 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:55:08.081: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000003
*Mar 1 02:55:08.081: Successful return from hrm_mod_cpuq_di
*Mar 1 02:55:08.081: Throttled: ARP throttle Adj(DI=0x15F,CMI=0x0)
Switch# DHCP_SNOOPING: checking expired snoop binding entries
*Mar 1 02:55:08.845: Receiving message : 60 BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 3 40 F 4 4 4 5 5 5 3 6 6 6 6 11 5 10 8 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 68
*Mar 1 02:55:08.845: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:55:08.929: REM TX Message : 7E 81 1 0
*Mar 1 02:55:09.801: Receiving message : 6E 82 0 0 F0
*Mar 1 02:55:09.801: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:09.801: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:55:09.801: REM TX Message : 77 2 3E 0 B7
*Mar 1 02:55:09.801: STP sync: Send ALL port data to all other switches...
*Mar 1 02:55:09.801: STP sync: NULL sync_data -- nothing to send
*Mar 1 02:55:09.826: Receiving message : 67 3A 0 0 11 11 11 31 11 11 11 11 0 0 0 0 0 0 0 0 5 B B B C C C 12 D D D D C C C C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9
*Mar 1 02:55:09.826: RE message received from sub 7, length:58 (No interrup
Switch#t)
*Mar 1 02:55:09.826: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:55:09.826: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:55:09.826: REM TX Message : 77 82 3E 10 47Sent on 0 frame 78003F8
*Mar 1 02:55:10.472: Receiving message : 67 BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1F
*Mar 1 02:55:10.472: RE message received from sub 7, length:58 (No int
Switch#errupt)
*Mar 1 02:55:10.472: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:55:10.531: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:55:10.531: Successful return from hrm_mod_cpuq_di
*Mar 1 02:55:10.531: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:55:10.531: REM TX Message : 30 93 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 E2
*Mar 1 02:55:10.531: REM TX Message : 37 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69
Switch#TX Message : 3E 13 21 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 70
*Mar 1 02:55:10.539: REM TX Message : 3E 7 28 0 FF 0 0 0 0 6C
*Mar 1 02:55:10.539: REM TX Message : 77 1 1F 97
*Mar 1 02:55:11.428: Receiving message : 67 2 2E 0 97
*Mar 1 02:55:11.437: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:55:12.150: Receiving message : 67 8A DD D4 B0 84 9E 7E 69 4F 0 0 AA
*Mar 1 02:55:12.158: RE message received f
Switch#rom sub 7, length:10 (No interrupt)
*Mar 1 02:55:12.158: sys vol 0 : 221,
*Mar 1 02:55:12.158: sys vol 1 : 212,
*Mar 1 02:55:12.158: sys vol 2 : 176,
*Mar 1 02:55:12.158: sys vol 3 : 132,
*Mar 1 02:55:12.158: sys vol 4 : 158,
*Mar 1 02:55:12.158: sys vol 5 : 126,
*Mar 1 02:55:12.158: sys vol 6 : 105,
*Mar 1 02:55:12.158: sys vol 7 : 79,
*Mar 1 02:55:12.158: REM TX Message : 70 81 1 F2
*Mar 1 02:55:12.200: Prev: Asic 2, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
RFP = 0x2,
Switch#WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:55:12.200: Curr: Asic 2, Port 9, RP = 0x17C0, WP = 0x17C0, SRP = 0x17C0
*Mar 1 02:55:12.200: Asic-Num 2, Port-Num 9, Is Port-Empty ? 1, W1 0x17C017C0, W2 0x22217C0
*Mar 1 02:55:12.200: Asic-Num 2, Port-Num 9, MatchCount 0
*Mar 1 02:55:12.208: Prev: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:55:12.208: Curr: Asic 2, Port 21, RP = 0x12C0, WP = 0x12C0, SRP = 0x12C0
*Mar 1 02:55:12.208: Asic-Num 2, Port-Num 21, Is Port-Empty ? 1, W1 0x12C012C0, W2 0x22212C0
*Mar 1 02:55:12.208: Asic-Num 2, Port-Num 21, MatchCount 0
*Mar 1 02:55:12.2
Switch#08: Prev: Asic 2, Port 22, RP = 0x1540, WP = 0x1540, SRP = 0x1540
*Mar 1 02:55:12.208: Curr: Asic 2, Port 22, RP = 0x1540, WP = 0x1540, SRP = 0x1540
*Mar 1 02:55:12.208: Asic-Num 2, Port-Num 22, Is Port-Empty ? 1, W1 0x15401540, W2 0x2221540
*Mar 1 02:55:12.208: Asic-Num 2, Port-Num 22, MatchCount 0
Switch#Mar 1 02:55:12.208:
*Mar 1 02:55:13.131: MAD available:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:55:13.131: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:55:13.131: ERD available:1
*Mar 1 02:55:13.131: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:55:13.131: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:55:13.844: considering next-hops to resolve
*Mar 1 02:55:13.844: rok_thermal_processi
Switch#
Switch#ng : 2
*Mar 1 02:55:13.844: Receiving message : 6E BA 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26
*Mar 1 02:55:15.665: Prev: Asic 2, Port 2, RP = 0x640, WP = 0x640, SRP = 0x640
*Mar 1 02:55:17.275: %SYS-3-LOGGER_DROPPED: System dropped 1534 console debug messages.
*Mar 1 02:55:17.284: RetVal:0, MAD error:0, Stn error:0, Pro
Switch#
Switch#
Switch#gChanged:0
*Mar 1 02:55:17.284: ERD available:1
*Mar 1 02:55:17.284: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:55:17.284: Fibs-ATMFail # of Covering fibs 0.Fib delete not happenedSent on 0 frame 78003F8
*Mar 1 02:55:18.114: Receiving message : 6E 2 0 0 70
*Mar 1 02:55:18.114: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:18.114
Switch#
Switch#
Switch#: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:55:18.114: REM TX Message : 70 81 1 F2
*Mar 1 02:55:18.181: obfl_io_flush_process: write lock released for 'obfl0::env_hist'
*Mar 1 02:55:18.181: obfl_io_flush_process: write lock acquired for 'obfl0::env_cont'
*Mar 1 02:55:18.181: obfl_io_flush_process: write lock released for 'obfl0::env_cont'
*Mar 1 02:55:18.181: obfl_io_flush_process: write lock acquired for 'obfl0::temp_cont'
Switch#
Switch#no
Switch#no s: write lock released for 'obfl0::temp_cont'
*Mar 1 02:55:18.970: Receiving message : 67 82 0 0 E9
*Mar 1 02:55:18.970: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:55:18.970: RE_SYS : Interrupts pending for sub 7, apps 0
*Mar 1 02:55:18.995: hrpc_recv_message: recvd req msg, src_box: 1 dest_box_bits: 0x0001, seq_num: 0x00000837, flags: 0x0002, num_frags: 0x001B, frag_num: 0x0007, size: 0x05B8
*Mar 1 02:55:18.995: SNMP: HC Timer 3ADDB8C fired
*Mar 1 02:55:18.995: SNMP: HC Timer 3ADDB8C rearmed, delay = 5000
*Mar 1 02:55:18.995: Receiving message : 6E 82 0 0 F0
*Mar 1 02:55:18.995: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:18.995: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:55:18.995: REM TX Message : 77 2 3E 0 B7
*Mar 1 02:55:19.716: Receiving message : 67 3A 0 0 31 33 11 11 11 11 11 11 0 0 0 0 0 0 0 0 1 5 4 3 9 9 9 11 4 4 4 4 3 3 3 3 0 0 0 0 0
*Mar 1 02:55:19.792: Successful return from hrm_get_well_known_di_with_mvid
de
Switch#no debug *Mar 1 02:55:19.792: soutput: Vl1 lt:7 vlan:1 desc: F00001B8_00008001_004D004A=00000156_1997F001_00000000 da: ffff.ffff.ffff sa: 001f.ca74.0cc0 IP_SA:192.168.1.1 IP_DA:255.255.255.255 IP_Proto:17
Sent on 1 frame 7D5F4DE
*Mar 1 02:55:20.354: Receiving message : 6E 2 0 0 70
*Mar 1 02:55:20.362: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:20.362: PoE message received F from E , valid : 64 length : 2
*Mar 1 02:55:20.362: REM TX Message : 77 1 1F 97
*Mar 1 02:55:20.362al
Switch#no debug all : Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:55:20.362: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:55:20.362: Entering hrm_get_cpuq_cmi cpu=6
*Mar 1 02:55:20.362: Successful return from hrm_get_cpuq_cmi
*Mar 1 02:55:20.362: Entering hrm_mod_cpuq_di cmi=7 di=15F
*Mar 1 02:55:20.362: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:55:20.362: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x0000004
Switch#3
*Mar 1 02:55:20.362: Successful return from hrm_mod_cpuq_di
*Mar 1 02:55:20.362: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)Sent on 0 frame 78003F8
*Mar 1 02:55:21.142: FIBbg: Restarting timer 'FIB checkers: IPv4 scan-ios-rib scanner' with delay 60000Sent on 0 frame 78003F8
Received: pak 3B99374 datagramstart 7BD1E76
*Mar 1 02:55:21.713: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 2 6 6 6 A A A 1 5 5 5 5 4 4 4 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7
*Mar 1 02:55:21.721: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:21.721: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:21.721: Copy for instance 2, page 0, 58 bytesFibs-AdjFail Retry Q depth 0.Fib delete not happened, Adj not Vlan not modification happened
*Mar 1 02:55:21.721: MAD available:1, Stn available:1, Src:hcef_adj_update_hw_resources_availability_status:2287
*Mar 1 02:55:21.721: RetVal:0, MAD error:0, Stn error:0, ProgChanged:0
*Mar 1 02:55:21.721: ERD available:1
*Mar 1 02:55:21.721: RtVal:0, ERD error:0, Delete:0, MvidChg:0, AclFullStChg:0
*Mar 1 02:55:21.721: Fibs-ATMFail # of Covering fibs 0.Fib delete not happened
*Mar 1 02:55:21.721: REM TX Message : 7E 2 3E 10 CE
*Mar 1 02:55:21.864: Receiving message : 6E 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A6
*Mar 1 02:55:21.872: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:21.872: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:21.872: Copy for instance 2, page 1, 58 bytes
*Mar 1 02:55:21.872: REM TX Message : 70 1 1 72
*Mar 1 02:55:22.778: Receiving message : 60 2 0 0 62
*Mar 1 02:55:22.778: RE message received from sub 0, length:2 (No interrupt)
*Mar 1 02:55:22.778: RE_SYS : Interrupts pending for sub 0, apps 0
*Mar 1 02:55:22.778: REM TX Message : 77 1 1 79
*Mar 1 02:55:22.837: IP: s=192.168.1.1 (local), d=255.255.255.255, len 56, local feature, Clustering(7), rtype 0, forus FALSE, sendself FALSE, mtu 0
*Mar 1 02:55:22.837: Entering hrm_get_well_known_di_with_mvid wkt 34, vlan 0
*Mar 1 02:55:22.837: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:55:22.837: soutput: Vl1 lt:7 vlan:1 desc: F00001B8_00008001_004D004A=00000156_1997F001_00000000 da: ffff.ffff.ffff sa: 001f.ca74.0cc0 IP_SA:192.168.1.1 IP_DA:255.255.255.255 IP_Proto:17
Sent on 1 frame 7D57EFE
*Mar 1 02:55:23.349: Receiving message : 6E 82 0 0 F0
*Mar 1 02:55:23.349: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:23.349: RE_SYS : Interrupts pending for sub 14, apps 0
*Mar 1 02:55:23.349: REM TX Message : 70 82 3E 0 30
*Mar 1 02:55:23.491: Receiving message : 60 BA 0 0 11 11 33 13 11 11 13 11 0 0 0 0 0 0 3 40 11 10 10 10 E D C 2 F F F F 3 E 8 11 0 0 0 0 0 0 0 10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 EB
*Mar 1 02:55:23.500: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:55:23.500: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:55:23.500: Copy for instance 0, page 0, 58 bytes
*Mar 1 02:55:23.500: REM TX Message : 70 2 3E 10 C0
*Mar 1 02:55:23.525: Receiving message : 60 3A 0 0 FF FF 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9B
*Mar 1 02:55:23.525: RE message received from sub 0, length:58 (No interrupt)
*Mar 1 02:55:23.525: PoE message received E from 0 , valid : 64 length : 58
*Mar 1 02:55:23.525: Copy for instance 0, page 1, 58 bytes
*Mar 1 02:55:23.525: REM TX Message : 7E 2 3F 0 BFSent on 0 frame 78003F8
*Mar 1 02:55:24.305: rok_thermal_processing : 2
*Mar 1 02:55:24.305: Receiving message : 6E 2 0 0 70
*Mar 1 02:55:24.305: RE message received from sub E, length:2 (No interrupt)
*Mar 1 02:55:24.389: Copy for instance 1, page 0, 58 bytes
*Mar 1 02:55:24.389: REM TX Message : 77 2 3E 10 C7Sent on 0 frame 78003F8
*Mar 1 02:55:25.068: Receiving message : 67 3A 0 0 FF FF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9F
*Mar 1 02:55:25.077: RE message received from sub 7, length:58 (No interrupt)
*Mar 1 02:55:25.077: PoE message received E from 7 , valid : 64 length : 58
*Mar 1 02:55:25.077: Copy for instance 1, page 1, 58 bytes
*Mar 1 02:55:25.077: REM TX Message : 70 81 1 F2
*Mar 1 02:55:25.077: Entering hrm_get_well_known_di_with_mvid wkt 43, vlan 0
*Mar 1 02:55:25.077: Successful return from hrm_get_well_known_di_with_mvid
*Mar 1 02:55:25.077: Entering hrm_get_cpuq_cmi cpu=6
*Mar 1 02:55:25.077: Successful return from hrm_get_cpuq_cmi
*Mar 1 02:55:25.077: Entering hrm_mod_cpuq_di cmi=7 di=15F
*Mar 1 02:55:25.077: sf_asic_set_destmap: sfASIC:0 PortASIC:3 DI:351 CMI:7 DestMap:0x34CEA74 RingMap:0x3C3F190
*Mar 1 02:55:25.077: madmax_asic_set_ring_map: Address: 0x5001057C Val: 0x00000043
*Mar 1 02:55:25.077: Successful return from hrm_mod_cpuq_di
*Mar 1 02:55:25.077: Unthrottled: ARP throttle Adj(DI=0x15F,CMI=0x7)
*Mar 1 02:55:26.016: RE message received from sub 7, length:2 (No interrupt)
*Mar 1 02:55:26.016: REM TX Message : 77 1 1D 95timed out
*Mar 1 02:55:26.016: Released port 57479 in Transport Port Agent for IP type 1Sent on 0 frame 78003F8
*Mar 1 02:55:26.696: Receiving message : 67 A DD D4 B0 84 9E 7E 69 4F 0 0 2A
*Mar 1 02:55:26.696: RE message received from sub 7, length:10 (No interrupt)
*Mar 1 02:55:26.696: sys vol 0 : 221,
*Mar 1 02:55:26.696: sys vol 1 : 212,
*Mar 1 02:55:26.696: sys vol 2 : 176,
*Mar 1 02:55:26.696: sys vol 3 : 132,
*Mar 1 02:55:26.696: sys vol 4 : 158,
*Mar 1 02:55:26.696: sys vol 5 : 126,
*Mar 1 02:55:26.704: Invoking hrpc handler: 8BEAD0, src 1, req 37, size 38128 bytesHQM: hqm_request_handler
*Mar 1 02:55:27.526: Receiving message : 6E BA 0 0 11 11 11 11 11 11 11 11 0 0 0 0 0 0 0 0 4 D D D A A A 6 2 2 2 2 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 B
*Mar 1 02:55:27.526: RE message received from sub E, length:58 (No interrupt)
*Mar 1 02:55:27.526: PoE message received E from E , valid : 64 length : 58
*Mar 1 02:55:27.526: Copy for instance 2, page 0, 58 bytes
*Mar 1 02:55:27.534: REM TX Message : 7E 2 3E 10 CE
*Mar 1 02:55:27.551: Prev: Asic 1, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
RFP = 0x2, WFP = 0x2, SRFP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:55:27.551: Curr: Asic 1, Port 1, RP = 0x3C0, WP = 0x3C0, SRP = 0x3C0
RFP = 0x2, WFP = 0x2, SRP = 0x2, PktFull = 0x0, FifoFull = 0x0,
*Mar 1 02:55:27.551: Asic-Num 1, Port-Num 1, Is Port-Empty ? 1, W1 0x3C003C0, W2 0x22203C0
*Mar 1 02:55:27.551: Asic-Num 1, Port-Num 1, MatchCount 0
*Mar 1 02:55:27.551: Prev: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:55:27.551: Curr: Asic 1, Port 5, RP = 0xDC0, WP = 0xDC0, SRP = 0xDC0
*Mar 1 02:55:27.551: Asic-Num 1, Port-Num 5, Is Port-Empty ? 1, W1 0xDC00DC0, W2 0x2220DC0
*Mar 1 02:55:27.551: Asic-Num 1, Port-Num 5, MatchCount 0
*Mar 1 02:55:30.798: %SYS-3-LOGGER_DROPPED: System dropped 813 console debug messages.
Switch#
Switch#
Switch#
Switch#
***** DEVICE IS RESTARTED
Using driver version 1 for media type 2
Base ethernet MAC Address: 00:1f:ca:74:0c:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 12 files, 1 directories
mifs[2]: Total bytes : 1835008
mifs[2]: Bytes used : 757248
mifs[2]: Bytes available : 1077760
mifs[2]: mifs fsck took 0 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 3932160
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 3931136
mifs[3]: mifs fsck took 0 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 262144
mifs[4]: Bytes used : 9216
mifs[4]: Bytes available : 252928
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 262144
mifs[5]: Bytes used : 9216
mifs[5]: Bytes available : 252928
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 456 files, 6 directories
mifs[6]: Total bytes : 57409536
mifs[6]: Bytes used : 14973440
mifs[6]: Bytes available : 42436096
mifs[6]: mifs fsck took 10 seconds.
...done Initializing Flash.
done.
Loading "flash:c3560e-universal-mz.122-35.SE5/c3560e-universal-mz.122-35.SE5.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Error loading "flash:c3560e-universal-mz.122-35.SE5/c3560e-universal-mz.122-35.SE5.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c3560e-universalk9-mz.122-46.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3560e-universalk9-mz.122-46.SE.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:09 by nachen
Image text-base: 0x00003000, data-base: 0x02000000
Initializing flashfs...
mifs[3]: 12 files, 1 directories
mifs[3]: Total bytes : 1835008
mifs[3]: Bytes used : 757248
mifs[3]: Bytes available : 1077760
mifs[3]: Initialization complete.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes : 3932160
mifs[4]: Bytes used : 1024
mifs[4]: Bytes available : 3931136
mifs[4]: Initialization complete.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes : 262144
mifs[6]: Bytes used : 9216
mifs[6]: Bytes available : 252928
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 456 files, 6 directories
mifs[7]: Total bytes : 57409536
mifs[7]: Bytes used : 14973440
mifs[7]: Bytes available : 42436096
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
...done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
balaji.bandi
While you doing debug, is the switch rebooted automatically, you have 2 boot variables, also suggest to use Latest stable version of IOS.
can you post show boot ?
BB
I did this reboot manually as currently my IOS version is c3560e-universalk9-mz.122-46.SE.bin, so I download a new suggested version for C3560E Switch from Cisco Platform and copied it in the switch you can see in the attached file as well, I have shared you with show boot, but on upgrading the new IOS: c3560e-universalk9-mz.152-4.E10.bin, the switch sound changed to increase level and the switch start rebooting again and again with this new IOS so I unplugged the power cable and from ROMMON Mode I rebooted it with c3560e-universalk9-mz.122-46.SE.bin again and then it came back to CLI. But the issue is still same PoE is still not working on the same ports.
I am worried about it.
Going from 12.2(46)SE to 15.2(4)E10 is a major upgrade.  The sound of the fans going full power is because the switch is doing a ROMMON upgrade.  This is to be expected.
Ok, I understand what I can do now to check as I have powered up this switch since 16 hours, 42 minutes but its still same need a diagnose report that what is actually the issue. Resolution is after this come. Do you find anything strange from "debug all" logs?
I am not troubleshooting anything running on that old firmware.
I have found the issue in the power capacitors. That are not working or faulty for this reason they were not working.
Thanks you all for the support.
