Dear Colleagues,
Could you assist me to resolve this issue on my Cisco call Manager 7800.
The rerror message is bellow.
/common contains a file system with errors, check forced /common Inodes that were part of a corrupted orphan link list found. /common: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY (i.e. without -a or -p options)
/grub: clean, 26/66520 files, 16820/265072 blocks /partB: clean, 11/3515680 files, 118535/7018396 blocks [FAILED] *** An error occured during the file system check. *** Dropping you to a shell; the system will reboot *** when you leave the shell. Give root password for maintenance (or type Control-D to continue):
