Cisco Callmanager + ISDN Calls
jan.ifkovitz
Hi all,
some month ago i set up a Cisco 2811 with CME 8.6 IOS is c2800nm-adventerprisek9-mz.151-4.M4.bin. Inventory is VIC2-2BRI-NT/TE and PVDM2-16.
My Problem is That ISDN Calls IN and OUT have no function. When i dial out after seconds the status ist "unknown Number" (in the Phonedisplay).
The BRI an Voice-Port cfg:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn tei-negotiation preserve
isdn point-to-point-setup
isdn incoming-voice voice
end
voice-port 0/2/0
compand-type a-law
cptone DE
Other Voive cfg:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice translation-rule 10
rule 1 /^894xxxx0$/ /1001/
rule 2 /^894xxxx9$/ /1002/
voice translation-rule 20
rule 1 /^0/ //
voice translation-rule 30
rule 1 /^1001$/ /89xxxx0/
rule 2 /^1002$/ /89xxxx9/
voice translation-rule 110
rule 1 /^2426180$/ /5000/
rule 2 /^.*/ /5000/
voice translation-rule 120
rule 1 /^9/ //
voice translation-rule 130
rule 1 /^/ /9/ type unknown unknown
rule 2 /^/ /90/ type national national
rule 3 /^/ /900/ type international international
voice translation-rule 200
rule 1 /^/ /0/ type unknown unknown
rule 2 /^/ /00/ type national national
rule 3 /^/ /000/ type international international
voice translation-profile ISDN-in
translate calling 200
translate called 10
voice translation-profile ISDN-out
translate calling 30
translate called 20
voice translation-profile SIP-in
translate calling 130
translate called 110
voice translation-profile SIP-out
translate called 120
voice-card 0
Debug ISDN Q931:
RO-Ker-01-AC-UGK#debug isdn q931
debug isdn q931 is              ON.
RO-Ker-01-AC-UGK#
000108: Aug 30 11:45:36.790 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 89xxxx0
000109: Aug 30 11:45:36.794 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 017xxxxx061
RO-Ker-01-AC-UGK#
000110: Aug 30 11:45:42.794 MEZ: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000111: Aug 30 11:45:42.798 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 4405593DF1BE11E18007EA9D9BCFC2D0, SetupTime 11:45:42.798 MEZ Thu Aug 30 2012, PeerAddress 017xxxxxx61, PeerSubAddress , DisconnectCause 29  , DisconnectText temporary failure (41), ConnectTime 11:45:42.798 MEZ Thu Aug 30 2012, DisconnectTime 11:45:42.798 MEZ Thu Aug 30 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000112: Aug 30 11:45:42.798 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 11:45:36.774,cgn:89xxxx0,cdn:017xxxxxx61,frs:0,fid:2,fcid:4405593DF1BE11E18007EA9D9BCFC2D0,legID:2E,bguid:4405593DF1BE11E18007EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
000113: Aug 30 11:45:47.666 MEZ: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 4405593DF1BE11E18007EA9D9BCFC2D0, SetupTime 11:45:28.526 MEZ Thu Aug 30 2012, PeerAddress 1001, PeerSubAddress , DisconnectCause 29  , DisconnectText temporary failure (41), ConnectTime 11:45:47.666 MEZ Thu Aug 30 2012, DisconnectTime 11:45:47.666 MEZ Thu Aug 30 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
RO-Ker-01-AC-UGK#
000114: Aug 30 11:45:47.666 MEZ: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/30/2012 11:45:28.526,cgn:1001,cdn:,frs:0,fid:1,fcid:4405593DF1BE11E18007EA9D9BCFC2D0,legID:2D,bguid:4405593DF1BE11E18007EA9D9BCFC2D0
RO-Ker-01-AC-UGK#
Anyone an idea ? What is my problem ?
THX @ll
22 Replies 22
What ist if the Layer 2 Status is wrong... it seams that the negotiation of the tei is corrupted....
What I saw from the debug isdn q921, showed that layer two frames are been sent and received. In most cases that should be good enough. When you make a test call, does "show isdn status"   shows "multiple frame established". The ISDN should come up when a call is attempted.
I am not sure if layer two frames are corrupted or not, because I dont know how to verify that.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
This Evening i want to check the cable and put the other Telefone out of the ISDN Bus... i will report tomorrow
when i place the call the status becomes an other:
RO-Ker-01-AC-UGK(config-if)#do sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/2/0 interface
        dsl 8, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 8 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/2/1 interface
        dsl 9, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 9 CCBs = 0
    Total Allocated ISDN CCBs = 0
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 255, Ces = 1, SAPI = 0, State = ESTABLISH_AWAITING_TEI
    Layer 3 Status:
        CCB:callid=8015, sapi=0, ces=1, B-chan=1, calltype=VOICE
    Active dsl 8 CCBs = 1
    The Free Channel Mask:  0x80000002
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Total Allocated ISDN CCBs = 1
Try
interface bri 0/2/0
isdn static-tei 0
now =) i  put the other Telefone out of the NTBA....make a reboot and the result is:
RO-Ker-01-AC-UGK#sh isdn status
    Layer 1 Status:
       ACTIVE
    Layer 2 Status:
        TEI = 81, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
RO-Ker-01-AC-UGK#
000210: Sep  4 18:41:54.689 MEZ: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 89491700
000211: Sep  4 18:41:54.689 MEZ: ISDN BR0/2/0 Q931: Sending SETUP  callref = 0x0003 callID = 0x8005 switch = basic-net3 interface = User
000212: Sep  4 18:41:54.689 MEZ: ISDN BR0/2/0 Q921: User TX -> INFO sapi=0 tei=81, ns=5 nr=3
000213: Sep  4 18:41:54.689 MEZ: ISDN BR0/2/0 Q931: SETUP pd = 8  callref = 0x03
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '89xxxx00'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0017xxxxx61'
000214: Sep  4 18:41:54.725 MEZ: ISDN BR0/2/0 Q921: User RX <- RR sapi=0 tei=81 nr=6
000215: Sep  4 18:41:54.789 MEZ: ISDN BR0/2/0 Q921: User RX <- INFO sapi=0 tei=81, ns=3 nr=6
so now it looks good... but calls are still not coming in or going out... can you help me by this problem again ?
THX for the Support
Now you need the dial-peer configuration, translations, etc.
All things that are explained in the manual or often discusses in the forum.
Please remember to rate useful posts clicking on the stars below.
I know... if you look in my first post you ca see that i already have done this =)
But then for some reason is incorrect and need to be fixed.
Do not take offense, but unless you have the necessary certifications or equivalente experience, the best choice is having someone that does, to configure and maintain your system.
