05-16-2018 01:36 AM - edited 03-17-2019 12:49 PM
Hi All,
Good Day. I'm experiencing unusual behavior of CUCM CDR, I see a call record with 0 Duration but the time difference is more than a minuet than the default setting on CUCM (with call forwarding). I attached the actual CDR report we gathered. I just want to know if this is a normal or discrepancy of the system.
Cisco Call Manager Version: 10.5.2.10000-5
Thank you
05-16-2018 04:39 AM
This could be issues with Post Dialing Delay (PDD)
Considered as the time from the INVITE sent by an origination to the RINGING message from the termination.
05-16-2018 12:01 PM
Hi there
I think you are hitting this bug - CSCvh61524
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh61524
Symptom:
In Cdr data, duration is populated as zero though call established and were in call for couple of minutes.
Conditions:
Phone A calls to HP_1 and reacheds the Agent-1, Agent-1 does blind transfer to HP_2 then reaches agent_2. Now A got connected to Agent_2.
Now if A does the redirection to some DN, then we will see this issue in the duration field.
Workaround:
N/A
If you are having the same above calling scenario you might be hitting the same bug as I can see your CUCM version 10.5.2.10000-5 is listed. Try upgrading to the fixed version.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
