05-17-2013 06:14 AM - edited 03-16-2019 05:22 PM
I have a Cisco Cius on a table and ... as you probably know ... it sucks. So I have a question - was anyone successful to hack it and install standard Android 4+ (or any linux) on it? I would use it for Android development then ... and I suppose that the Cisco Jabber for Android will be better experience then the cius from the box.
Anyone?
Thank you for help.
Jiri
Solved! Go to Solution.
05-17-2013 06:18 AM
Well, it is obviously not supported, but since the product is dead and essentially a brick it does not hurt to try :-)
Chris
05-17-2013 06:18 AM
Chris
05-17-2013 02:08 PM
Yes, but I hope there were some pioneers already who can advise me to not to "bricked" it immediatelly.
Jiří
05-19-2013 03:47 PM
Hi Jiri,
Looking for a answer to the quetsion, I have found your post on another forum:
http://www.tabwatch.com/cisco-cius-android-42217763-cisco-support-community/
I have a Cius so would like to updrate to Android 4+
