09-04-2012 04:13 AM - edited 03-16-2019 01:01 PM
Good Day,I have Head office Router,where I connect cisco CME with 4 IP Phones,all ip phones can talk to each other as well before It was support outgoing and incoming pstn call through 4 fxo port.
right now I am not able to make a call outside as well i can't receive a call,it is giving the busy tone when ever you are making a call outside.
I have the following configuration,please anybody can help me.
Building configuration...
Current configuration : 4370 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname CME-HQ
boot-start-marker
boot-end-marker
enable secret 5 $1$96Am$W2cevvuvT7CxcU64YWPgL.
no aaa new-model
clock timezone GMT3 3 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.1.1.250 10.1.1.254
ip dhcp excluded-address 10.10.1.250 10.10.1.254
ip dhcp excluded-address 10.1.1.1 10.1.1.30
ip dhcp excluded-address 10.10.1.1 10.10.1.30
ip dhcp pool Voice
network 10.10.1.0 255.255.255.0
option 150 ip 10.10.1.252
default-router 10.10.1.252
ip dhcp pool DATA
network 10.1.1.0 255.255.255.0
option 150 ip 10.1.1.252
default-router 10.1.1.252
voice-card 0
voice translation-rule 1
rule 1 /^063391996/ /6/
voice translation-rule 2
rule 1 /^6/ /063391996/
voice-card 0
voice translation-profile pstn-in
translate called 1
voice translation-profile pstn-out
translate calling 2
license udi pid CISCO2921/K9 sn FCZ1539201L
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 password 7 00071A150754525F56
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.252 255.255.255.0
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 10.10.1.252 255.255.255.0
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.497
encapsulation dot1Q 497
ip address 172.16.245.110 255.255.255.252
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1/0
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface Vlan1
no ip address
router bgp 65272
bgp log-neighbor-changes
network 10.1.1.0 mask 255.255.255.0
network 10.10.1.0 mask 255.255.255.0
neighbor 172.16.245.109 remote-as 65000
neighbor 172.16.245.109 ebgp-multihop 2
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source static 10.1.1.3 84.235.84.5
ip route 0.0.0.0 0.0.0.0 84.235.84.6
control-plane
voice-port 0/0/0
translation-profile incoming pstn-in
translation-profile outgoing pstn-out
signal groundStart
connection plar opx 6003
caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
dial-peer voice 1 pots
destination-pattern 9T
no digit-strip
port 0/0/0
dial-peer voice 2 pots
destination-pattern ^0.........
no digit-strip
port 0/0/0
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 70
max-dn 120
ip source-address 10.1.1.252 port 2000
system message Serbal Trading Co Ltd
time-zone 31
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn 1 dual-line
number 6001
ephone-dn 2 dual-line
number 6002
ephone-dn 3 dual-line
number 6003
ephone-dn 4
number 6004
name Naseer Khan
ephone 1
mac-address 0008.308B.8DF7
button 1:1
ephone 2
mac-address 24B6.57B1.F240
button 1:2
ephone 3
mac-address 24B6.57B1.F340
button 1:3
ephone 4
mac-address D0C2.82D0.EFBB
button 1:4
line con 0
password 7 01100F1758045F5678
logging synchronous
login
line aux 0
password 7 121A0C041104555D73
login
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
password 7 05080F1C2243175040
logging synchronous
login
transport input all
scheduler allocate 20000 1000
end
CME-HQ-#
CME-HQ-#
CME-HQ-#
09-04-2012 05:12 AM
Can you directly connect Analog Phone and try making inbound/Outbound call if you are getting line busy This might be the problem from PSTN.
09-04-2012 05:40 AM
Thanks for your reply,I already tried through POTS directly it is working fine,when connect through FXO not working.
Before It was worked fine almost one month.
09-04-2012 05:46 AM
Remove the following from voice-port 0/0/0 and make a test call
09-04-2012 07:00 AM
Yes I removed and tried still same problem.
09-04-2012 07:13 AM
Can you run Debug dial peer command
09-04-2012 07:20 AM
Add the following commands under Voice Port 0/0/0 and make a test call
compand-type a-law
timeouts interdigit 4
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
09-04-2012 05:29 AM
Your Dial-peer configuration shows "no digit-strip " command which means that you are send 9 along with rest of the dialing number
09-04-2012 10:24 AM
debug voip ccapi inout
debug vpm signal
debug voip vtsp all
show voice port summary
make a out-bound call. let me know the results.
Kevin Monteiro
09-05-2012 04:14 AM
Hi everybody
It is working now,without doing any modifications,What I done is just shutdown the CME,remanove the fx0 interface from one socket and put it into another socket,It was before on voice-port 0/0/0 after changing that it becames 0/1/0.
Thanks for all your efforts to support.
Best Regards
Shanawaz
04-18-2013 07:04 AM
Hi Meer,
thanx for your post it is very helpful. the same issue was here as well but i am still not able to dial an international calls it is fine with national calls can any one help in this regard.
CME_Router#
translate called 1
translate calling 2
oice-port 1/1/0
signal groundStart
connection plar opx 5555
caller-id enable
no digit-strip
port 1/1/0
no digit-strip
port 1/1/0
thanks
