Cisco CME intergration with Panasonic
Ali Bahnam
Dears,
I have a cisco CME version 8.5 installed on cisco 2901 Router, and a panasonic PBX, my question is can I integrated the panasonic with my CME where as I know in case I have two CME I will go to configure Dial peers but now what should I do for this integration??
Appreciate your support
Hi Ali,
the above dialpeers are correct. I think you need to add "incoming called-number ." under the voip dialpeers so you can receive calls from panasonic.
Anas
please rate if it is helpful
8 Replies 8
Anas Abueideh
Level 9
Level 9
if you have FXO card installed on your router, you can use it to integration with panasonic.
at this integration you need to create pots dialpeers. the dial-peer destination numbers should match the dial plan of panasonic.
Anas
Thank you Anas,
The Panasonic have an IP and connected to the internal network, I'm looking to configure dial peers VOIP not pots but do you have any idea how this will be configured on panasonic side.
Anas Abueideh
Level 9
Level 9
Hi Ali,
what is the supported voip protocol in panasonic, h323 or SIP ?
you need to configure voip dialpeer pointing to panasonic with proper destination pattern.
Anas
Hi Anas,
If the panasonic prtocol is H323 will be no problem the CME dial peer will configure as below:-
dial-peer voice 121 voip
translation-profile outgoing prefix
destination-pattern x..
session target ipv4:192.x.x.x
dtmf-relay h245-alphanumeric h245-signal
but if the panasonic protocol is SIP the configuration on CME will be as below:-
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 250 min 200
  no call service stop
dial-peer voice 2000 voip
destination-pattern y...
session protocol sipv2
session target ipv4:172.x.x.x
dtmf-relay sip-notify
codec g711ulaw
no vad
So please can you advise for the above if the two options are right or not??
Hi Ali,
Anas
Thank you
Hello Anas,
What if you have the Panasonic PBX on one location and the CME on another location, but have an E1 connection between both locations?
How would this work?
Peter.
Tagir Temirgaliyev
it depends what cards are in your panasonic pbx.
we have e1 pri in 2911 connected to e1 pri in panasonic
