12-10-2013 02:46 PM - edited 03-16-2019 08:48 PM
Hello Cisco Team
I am planning to install 20 ip phones 7942 and 5 ip Communicators but I got some doubts in licensing,
First
What is the difference between FL-CME-SRST-25 and SW-CCME-UL-7942, do I have to buy both?
Can I take 5 licenses from FL-CME-SRST-25 to install 5 ip communicators?
Hope you can help me
12-10-2013 06:56 PM
Hi Hugo,
SW-CCME-UL-7942 is the IP phone CME license for 7942 model while FL-CME-SRST-25 is feature license of SRST and is for 25 seats.
for IP Communicator , u need to have separate licenses.Part Code would be SW-CCME-UL-IPCOMM= [you can get the same checked by Cisco AM]
All licenses are paper based.
you can refer the discussion
https://supportforums.cisco.com/thread/2075659
regds,
aman
12-10-2013 11:11 PM
If you are using isr2 routers then you need to activate the licensce on the gateway to run voice commands.
Ajay
