11-15-2016 03:20 AM - edited 03-18-2019 12:09 PM
Hi Community,
We have Cisco CME version 10.5.
We are trying to configure paging but we cannot make it work!
We are using SIP phones 7821, 7841, 9971, 9951 and SCCP phone 7965G.
Here is the CME configuration:
ephone-dn 99
number 999
paging ip 239.0.1.20 port 2000
paging group 99
ephone 1
paging-dn 99
voice register pool 36
paging-dn 99
voice register pool 47
paging-dn 99
CME-Router-2921#sh ephone-dn paging
Paging Configuration
ephone-dn 99 (ACTIVE)
number 999
ephone-1[0] paging-dn 99 (ON )
voice reg pool 36 paging-dn 99 (ON )
voice reg pool 47 paging-dn 99 (ON )
paging group 99
ephone-1[0] pagingGrp 99 (ON )
voice reg pool 36 pagingGrp 99 (ON )
voice reg pool 47 pagingGrp 99 (ON )
Paging Control Info
skinnyPC[0] ephone-paging-dn 99 (ACTIVE) count 1
phone ip address next hop port
ephone#[phone] 1[0] 239.0.1.20 239.0.1.20 2000
sccp(ephone#[phone]): 1[0](mcast)
group 99 (ephone#[phone]): 1[0](mcast)
sip (pool[peer tag]): 36[40006](mcast) 47[40017](mcast)
group 99 (pool[peer tag]): 36[40006](mcast) 47[40017](mcast)
When I dial the paging number 999, the call is answered but the idle phones doesn't receive any broadcast message and stays idle.
What is needed to be checked?
Thank you for your support.
11-16-2016 06:43 PM
Is IP multicast routing enabled? Have you checked on the switch phones are connected to see if you see anyone attempting to join the igmp snooping groups? What is the results of a show ip mroute?
Have you tried the unicast method?
07-25-2017 12:46 PM
I had the same issue with 8841 phones on CME 11.6
I found the Port number for paging SIP phones must be different but did not find in the documentation. It could only be found on the help on the command using the "?"
ROUTER(config)#ephone-dn 30
ROUTER(config-ephone-dn)# number 777
ROUTER(config-ephone-dn)# name Paging
ROUTER(config-ephone-dn)# paging ip 239.1.1.1 port ?
<2000-65535> Specify the port: 2000 - 65535 (even num from 20480 to
32768 for SIP line)
