05-08-2018 04:25 AM - edited 03-17-2019 12:46 PM
Could anyone help me please? We work as developers and just need to use the system for some test calls. I'm trying to make in and outbound calls from my Sipgate IP trunk but it's unable to dial our or in. If I dial in I do see the call but it does not route correctly. My show run config is below.
CMETEST#sh run
Building configuration...
Current configuration : 7325 bytes
! Last configuration change at 15:53:06 CEST Wed Apr 25 2018 by administrator
! NVRAM config last updated at 15:13:28 CEST Tue Apr 24 2018 by administrator
version 15.5
service config
service udp-small-servers
no service dhcp
no platform punt-keepalive disable-kernel-core
hostname CMETEST
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 51200 warnings
enable secret 5 $1$G9Kd$hFOu6Z552hzpT8Oa7t9hb0
aaa new-model
aaa session-id common
clock timezone CEST 2 0
clock calendar-valid
ip host local-host 10.1.146.1
ip domain name imagicle.com
ip dhcp pool voice
network 10.1.0.0 255.255.0.0
option 150 ip 10.1.146.1
default-router 10.1.146.1
ip dhcp pool voice network 10.1.146.0 255.255.0.0
subscriber templating
crypto pki trustpoint TP-self-signed-498901928
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-498901928
revocation-check none
rsakeypair TP-self-signed-498901928
crypto pki certificate chain TP-self-signed-498901928
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34393839 30313932 38301E17 0D313830 32303931 31323431
365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3439 38393031
39323830 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
AFCD8EF1 AD037EA1 CB064440 0F463D92 C6D23F08 FF4E1E65 FB49F1D9 C5E85FE3
111FA3A8 51224BEE B21D94AC B551B6BA 4D9CDE47 21252A4D 7B91FF24 E9134C92
DE230EA2 31046DDF E0196B54 046F024A A94CFCCB C5B019DD EB50E088 AC2C4512
5A70C79E 91654450 503E181A 54B53F24 C7416FE5 3744C137 27EBAD3D 31E40545
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 16801401 03AB1E47 7405F7D4 0259FD2C 5A1F8319 69E25230 1D060355
1D0E0416 04140103 AB1E4774 05F7D402 59FD2C5A 1F831969 E252300D 06092A86
4886F70D 01010505 00038181 0073DE9C 45509142 59C8CCDA 1F1F2115 65BE6AE3
4CFC997D E20E992D A0275C85 C1304682 8C41DA23 D562B45E 3870C53C 2FB3CAD3
6C8A44EC 25B24ADF 9CC27BE8 58107B91 1BD7CBC0 08F60E39 1CFE4A6F D17AD38B
7F229B33 C0314EB7 E6F009E1 32E5CE38 0AC1695B D58AC2DD 987483D4 1539BC84
0F2CC44D C048AB3E 1983265F C2
quit
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
ipv4 192.168.150.0 255.255.255.0
ipv4 192.168.200.0 255.255.255.0
ipv4 192.168.100.0 255.255.255.0
ipv4 192.168.4.0 255.255.255.0
ipv4 192.168.201.0 255.255.255.0
ipv4 192.168.204.0 255.255.255.0
ipv4 192.168.1.0 255.255.255.0
ipv4 10.1.0.0 255.255.0.0
ipv4 10.0.0.0 255.255.0.0
gcid
callmonitor
cti message device-id suppress-conversion
cti csta mode basic
no cti shutdown
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
sip-profiles 1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class sip-profiles 1
request ANY sip-header From modify "(<.*:)(.*@)" "<SIP-ID>@"
request REGISTER sip-header To modify "(<.*:)(.*@)" "<SIP-ID>@"
voice register global
mode cme
source-address 10.1.146.1 port 5060
max-dn 20
max-pool 10
http client cache memory pool 100000
http client cache memory file 10000
http client connection timeout 10
http client connection idle timeout 200
http client response timeout 300
license udi pid *******/K9 sn **********
username admin privilege 15 password 0 ********0
username cisco password 0 ******
username Appadmin privilege 15 ***** 5 $1$katj$G7MIIzgzUm6Ve4rQwaKy50
username administrator privilege 15 ***** 5 $1$HFsL$A3O07cF6tq5KSyV4sBEJc/
username enzo password 0 ****
username imagi privilege 15 password 0 imagi
redundancy
mode none
vlan internal allocation policy ascending
class-map type control match-any remote-manage
class-map type access-control match-any remote-manage
interface GigabitEthernet0/0/0
description Ethernet
ip address 10.1.146.1 255.255.0.0
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
vrf forwarding Mgmt-intf
no ip address
ip nat inside
negotiation auto
interface Vlan1
no ip address
shutdown
ip default-gateway 10.1.0.2
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http max-connections 1000
ip http timeout-policy idle 600 life 86400 requests 86400
ip tftp source-interface GigabitEthernet0/0/0
ip default-network 10.1.0.0
ip route 0.0.0.0 0.0.0.0 10.1.0.2
ip route 10.0.0.0 255.255.0.0 10.1.0.2
ip route 10.100.0.0 255.255.0.0 10.1.0.2
ip ssh time-out 60
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
conference transfer-pattern
max-ephones 10
max-dn 10
ip source-address 10.1.146.1 port 2000
cnf-file location flash:
cnf-file perphone
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer voice 9000 voip
description Outgoing calls
destination-pattern 0T
session protocol sipv2
session target dns:sipgate.co.uk
voice-class sip profiles 1
dtmf-relay sip-notify
codec g711alaw
no vad
sip-ua
credentials username 3807888e0 password 7 097469313F26254123 realm sipgate.co.uk
authentication username 3807888e0 password 7 1221222F34283E5702 realm sipgate.co.uk
registrar dns:sipgate.co.uk:5060 expires 3600
sip-server dns:sipgate.co.uk:5060
ephone-dn 1
number 200
description IPC Test
name Test Phone
cti notify
cti watch
ephone-dn 2
number 201
description IPC Test2
name Test Phone 2
cti notify
cti watch
ephone-dn 3
number 202
description IPC Test3
name Test Phone 3
cti notify
cti watch
ephone-dn 4
number 203
description IPC Test4
name Test Phone 4
cti notify
cti watch
ephone 1
mac-address A000.B000.000B
username "test" password test
type CIPC
button 1:1
ephone 2
description IPC Test 2
mac-address 000D.28C2.0ECB
username "test2" password test2
type 7940
button 1:2
ephone 3
mac-address 000C.3070.86A5
username "test3" password test3
type 7940
button 1:3
ephone 4
mac-address 0000.0000.000B
type CIPC
button 1:4
ephone 5
mac-address 0000.0000.000C
type 7940
ephone 6
mac-address 0000.000D.000A
ephone 8
banner motd ^CC^C
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 0 0
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
end
05-08-2018 07:57 AM
05-09-2018 06:43 AM
Thanks for the reply. If you can help the traces are below? Thanks
Outbound call
May 9 13:43:47.647: //8704/CE8A37FA8276/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Username in From Field required
Via: SIP/2.0/UDP 10.1.146.1:5060;branch=z9hG4bK27B81A71;rport=6916;received=194.168.11.182
From: "Test Phone 3" <sip:202@sipgate.co.uk>;tag=85BBA50A-16B6
To: <sip:0800500005@sipgate.co.uk>;tag=ade4fa2b884c8263d9114cf9f0febf3f.b879
Call-ID: D5576528-52C511E8-827BEFC5-A22B771E@10.1.146.1
CSeq: 101 INVITE
Content-Length: 0
May 9 13:43:47.649: //8704/CE8A37FA8276/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0800500005@sipgate.co.uk:5060 SIP/2.0
Date: Wed, 09 May 2018 15:43:47 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
Inbound Call --
Record-Route: <sip:217.10.79.23;lr;ftag=as14788da0>
Record-Route: <sip:172.20.40.8;lr>
Record-Route: <sip:217.10.68.137;lr;ftag=as14788da0>
Via: SIP/2.0/UDP 217.10.79.23;branch=z9hG4bKa20a.1ea5fd971c071e41a5742f1b0c482965.0
Via: SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKa20a.cc29b1f0396473acb9e99cb06a02b502.0
Via: SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKa20a.ea2e344cbcf67773d8b4f7c6bbbba790.0
Via: SIP/2.0/UDP 217.10.77.57:5060;branch=z9hG4bK0a47daf6
Max-Forwards: 67
From: "01733667800" <sip:01733667800@sipgate.co.uk>;tag=as14788da0
To: <sip:00441733807888@sipgate.co.uk>
Contact: <sip:01733667800@217.10.77.57:5060>
Call-ID: 40e359664d5435e76f02734a218a2ada@sipgate.co.uk
CSeq: 103 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces
Content-Type: application/sdp
Content-Length: 441
v=0
o=root 684692663 684692664 IN IP4 217.10.77.57
s=sipgate VoIP GW
c=IN IP4 217.10.77.241
t=0 0
m=audio 27202 RTP/AVP 8 0 3 97 18 112 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:112 G726-32/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
a=rtcp:27203
May 9 09:57:52.145: //8669/45A6D32F825A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 217.10.79.23;branch=z9hG4bKa20a.1ea5fd971c071e41a5742f1b0c482965.0,SIP/2.0/UDP 172.20.40.8;branch=z9hG4bKa20a.cc29b1f0396473acb9e99cb06a02b502.0,SIP/2.0/UDP 217.10.68.137;branch=z9hG4bKa20a.ea2e344cbcf67773d8b4f7c6bbbba790.0,SIP/2.0/UDP 217.10.77.57:5060;branch=z9hG4bK0a47daf6
Date: Wed, 09 May 2018 11:57:52 GMT
CSeq: 103 INVITE
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
Sent:
SIP/2.0 484 Address Incomplete
To: <sip:00441733807888@sipgate.co.uk>;tag=84ECCDFC-1BDA
CSeq: 103 INVITE
Reason: Q.850;cause=28
Content-Length: 0
May 9 09:57:52.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3807888e0@10.1.146.1:5060 SIP/2.0
Max-Forwards: 67
CSeq: 103 ACK
Content-Length: 0
X-hint: rr-enforced
05-09-2018 06:57 AM
05-09-2018 07:15 AM
Thanks again.
I can't seem to enable ccapi messages? is it debug ccapi ? It's not correct?
Second outbound call
May 9 14:14:45.892: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
May 9 14:15:00.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
May 9 14:15:07.222: //8712/2EDF543C8282/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0800500005@sipgate.co.uk:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.146.1:5060;branch=z9hG4bK27C24CD
Remote-Party-ID: "Test Phone 3" <sip:202@10.1.146.1>;party=calling;screen=no;privacy=off
From: "Test Phone 3" <sip:202@sipgate.co.uk>;tag=85D85341-1DAD
Date: Wed, 09 May 2018 16:15:07 GMT
Call-ID: 35ACAA2D-52CA11E8-8287EFC5-A22B771E@10.1.146.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0786388028-1388974568-2189619141-2720757534
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1525875307
Contact: <sip:202@10.1.146.1:5060>
Call-Info: <sip:10.1.146.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Cisco-Gcid: 2EDF543C-52CA-11E8-8282-EFC5A22B771E
Content-Disposition: session;handling=required
Content-Length: 184
v=0
o=CiscoSystemsSIP-GW-UserAgent 7969 2246 IN IP4 10.1.146.1
s=SIP Call
c=IN IP4 10.1.146.1
t=0 0
m=audio 8192 RTP/AVP 8
c=IN IP4 10.1.146.1
a=ptime:20
May 9 14:15:07.257: //8712/2EDF543C8282/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.1.146.1:5060;branch=z9hG4bK27C24CD;rport=6916;received=194.168.11.182
To: <sip:0800500005@sipgate.co.uk>;tag=ade4fa2b884c8263d9114cf9f0febf3f.ee94
CSeq: 101 INVITE
Content-Length: 0
May 9 14:15:07.259: //8712/2EDF543C8282/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
May 9 14:15:14.393: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
05-09-2018 07:17 AM
05-09-2018 07:25 AM
Inbound Call CCAPI test
CMETEST#
May 9 14:25:41.927: //-1/AFFD6A4D828E/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=01733667800
----- ccCallInfo IE subfields -----
cisco-ani=01733667800
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=3807888e0
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
May 9 14:25:41.928: //-1/AFFD6A4D828E/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7FA878128E88, Call Info(
Calling Number=01733667800,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=3807888e0(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=9000, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8717
May 9 14:25:41.928: //-1/AFFD6A4D828E/CCAPI/ccCheckClipClir:
In: Calling Number=01733667800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=01733667800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May 9 14:25:41.928: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 9 14:25:41.928: :cc_get_feature_vsa malloc success
May 9 14:25:41.928: cc_get_feature_vsa count is 1
May 9 14:25:41.928: :FEATURE_VSA attributes are: feature_name:0,feature_time:140361778598420,feature_id:171
May 9 14:25:41.928: //8717/AFFD6A4D828E/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=01733667800(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=3807888e0(TON=Unknown, NPI=Unknown))
May 9 14:25:41.928: //8717/AFFD6A4D828E/CCAPI/cc_process_call_setup_ind:
Event=0x7FA885F63D70
May 9 14:25:41.928: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 3807888e0
May 9 14:25:41.928: //8717/AFFD6A4D828E/CCAPI/ccCallSetContext:
Context=0x7FA88A7C95C8
>>>>CCAPI handed cid 8717 with tag 9000 to app "_ManagedAppProcess_Default"
May 9 14:25:41.929: //8717/AFFD6A4D828E/CCAPI/ccCallProceeding:
May 9 14:25:41.929: //8717/AFFD6A4D828E/CCAPI/ccCallDisconnect:
Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
May 9 14:25:41.961: //8717/AFFD6A4D828E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FA878128E88, Tag=0x0, Call Id=8717,
Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
May 9 14:25:41.961: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 9 14:25:41.961: :cc_free_feature_vsa freeing 7FA885F41208
May 9 14:25:41.961: vsacount in free is 0
Outbound Call CCAPI
CMETEST#debug voice ccapi inout
voip ccapi inout debugging is on
CMETEST#
CMETEST#
CMETEST#
May 9 14:23:58.342: //-1/723FC17F8288/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=202
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
May 9 14:23:58.343: //-1/723FC17F8288/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7FA889F20D00, Call Info(
Calling Number=202,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20003, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
May 9 14:23:58.343: //-1/723FC17F8288/CCAPI/ccCheckClipClir:
In: Calling Number=202(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=202(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
May 9 14:23:58.343: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 9 14:23:58.343: :cc_get_feature_vsa malloc success
May 9 14:23:58.343: cc_get_feature_vsa count is 1
May 9 14:23:58.343: :FEATURE_VSA attributes are: feature_name:0,feature_time:140361778598420,feature_id:169
May 9 14:23:58.343: //8714/723FC17F8288/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=202(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
May 9 14:23:58.343: //8714/723FC17F8288/CCAPI/cc_process_call_setup_ind:
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/ccCallSetContext:
Context=0x7FA88A7CAC70
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 8714 with tag 20003 to app "_ManagedAppProcess_Default"
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/ccCallSetupAck:
Call Id=8714
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=8714
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/ccCallReportDigits:
(callID=0x220A, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=8714
May 9 14:23:58.344: //8714/723FC17F8288/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7FA889F20D00, callID=0x220A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x7FA889F20D00, Call Id=8714
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
May 9 14:23:58.851: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=8714, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x129FD28, Rtp Expiration=0x0
May 9 14:23:58.852: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
Source Call Id=8714, Digit=0, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
May 9 14:23:58.952: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Source Call Id=8714, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x12A7A28, Rtp Expiration=0x0
May 9 14:23:58.952: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
Source Call Id=8714, Digit=8, Duration=100,
May 9 14:23:59.051: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12AF728, Rtp Expiration=0x0
May 9 14:23:59.052: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.151: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12B7428, Rtp Expiration=0x0
May 9 14:23:59.152: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.252: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Source Call Id=8714, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x12BF128, Rtp Expiration=0x0
May 9 14:23:59.252: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
Source Call Id=8714, Digit=5, Duration=100,
May 9 14:23:59.351: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12C6E28, Rtp Expiration=0x0
May 9 14:23:59.352: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.452: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12CEB28, Rtp Expiration=0x0
May 9 14:23:59.452: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.552: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12D6828, Rtp Expiration=0x0
May 9 14:23:59.552: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.651: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12DE528, Rtp Expiration=0x0
May 9 14:23:59.652: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:23:59.751: //8714/723FC17F8288/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x12E6228, Rtp Expiration=0x0
May 9 14:23:59.752: //8714/723FC17F8288/CCAPI/cc_api_call_digit_end:
May 9 14:24:09.752: //8714/723FC17F8288/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
May 9 14:24:09.752: //8714/723FC17F8288/CCAPI/ccCallReportDigits:
(callID=0x220A, digit_event=0x0, enable=FALSE, consume=FALSE)
May 9 14:24:09.752: //8714/723FC17F8288/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x7FA889F20D00, callID=0x220A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
May 9 14:24:09.753: //8714/723FC17F8288/CCAPI/ccCallProceeding:
May 9 14:24:09.753: //8714/723FC17F8288/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=9000, Params=0x7FA88A7C5250, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
May 9 14:24:09.753: //8714/723FC17F8288/CCAPI/ccCheckClipClir:
Destination Pattern=0T, Called Number=0800500005, Digit Strip=FALSE
Called Number=0800500005(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Test Phone 3
Account Number=, Final Destination Flag=FALSE,
Guid=723FC17F-52CB-11E8-8288-EFC5A22B771E, Outgoing Dial-peer=9000
May 9 14:24:09.753: //8714/723FC17F8288/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=202
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=0800500005
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
May 9 14:24:09.753: //8714/723FC17F8288/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7FA878128E88, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=202,(Calling Name=Test Phone 3)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=All owed),
Called Number=0800500005(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=9000, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
May 9 14:24:09.753: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 9 14:24:09.753: :cc_get_feature_vsa malloc success
May 9 14:24:09.753: cc_get_feature_vsa count is 2
May 9 14:24:09.754: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 9 14:24:09.754: :FEATURE_VSA attributes are: feature_name:0,feature_time:140361778598196,feature_id:170
May 9 14:24:09.754: //8715/723FC17F8288/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
May 9 14:24:09.754: //8715/723FC17F8288/CCAPI/ccCallSetContext:
Context=0x7FA88A7C51D0
May 9 14:24:09.754: //8714/723FC17F8288/CCAPI/ccSaveDialpeerTag:
May 9 14:24:09.755: //8715/723FC17F8288/CCAPI/cc_api_call_proceeding:
Interface=0x7FA878128E88, Progress Indication=NULL(0)
May 9 14:24:09.758: //8715/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 9 14:24:09.758: cc_api_get_xcode_stream : 4983
May 9 14:24:09.794: //8715/723FC17F8288/CCAPI/cc_api_call_disconnected:
Cause Value=57, Interface=0x7FA878128E88, Call Id=8715
Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
May 9 14:24:09.794: //8714/723FC17F8288/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
May 9 14:24:09.794: //8715/723FC17F8288/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=8715
May 9 14:24:09.794: //8715/723FC17F8288/CCAPI/ccCallDisconnect:
Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=57)
Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
May 9 14:24:09.795: //8715/723FC17F8288/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FA878128E88, Tag=0x0, Call Id=8715,
Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
May 9 14:24:09.795: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 9 14:24:09.795: :cc_free_feature_vsa freeing 7FA885F41128
May 9 14:24:09.795: vsacount in free is 1
May 9 14:24:09.795: //8714/723FC17F8288/CCAPI/ccCallDisconnect:
Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
May 9 14:24:09.795: //8714/723FC17F8288/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
May 9 14:24:14.473: //8714/723FC17F8288/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FA889F20D00, Tag=0x0, Call Id=8714,
May 9 14:24:14.473: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 9 14:24:14.473: :cc_free_feature_vsa freeing 7FA885F41208
May 9 14:24:14.473: vsacount in free is 0
05-09-2018 07:48 AM
05-10-2018 01:33 AM
Thank you again. I will check the information for the outbound calls. The e in the 3807888e0 is the Sipgate registration name they don't just use numbers, I have seen some other information on this.
05-10-2018 01:55 AM
05-10-2018 02:03 AM
Ok, I did see some information on the Sipgate blog for this. I will give this a try.
