Cisco Collaboration Queries.
Hi Guys
Will be most grateful for your assistance on the following:
Have checked online and noted that 3905 does not support Corporate Directory. Is it possible to upgrade firmware and then it may work. Any ideas please.
Does CUCM support dial by PIN Numbers. Example an staff would dial 0, followed by 4 or 6 digits PIN and then dial the Inter-State Numbers or International Numbers.
Does CUCM support Manager-Assistant on the 7811 and 7821 phones. It will be on the hard phones instead of the Secretary screen calls from the web interface.
For Remote workers who need Audio, Video and Web Conference access, should CUBE or Expressway be recommended. We may have the Cisco Meeting Server as the Conference solution.
Is Expressway the Session Border Controller.
What training and certification is recommended for the Cisco Meeting Server.
Adrian
Jaime Valencia
A: That phone is EOS/EOL, the last FW for it is back from 2018
A: If you mean short dial, yes, that's simply translation patterns. Otherwise, it might be FAC or CMC, not exactly sure of the behavior you want. Search for FAC and CMC.
A: IPMA, can't recall if those models are supported but you can review the guides for that.
A: You need MRA for access, as explained in the other post, video conferencing are provided by CMS.
A: NO
A: Google: Cisco CMS training
java
if this helps, please rate
