Cisco CP-8855 Ip phone
Creatif86
Please is there anyway by receiving incoming call through usb modem (dongle) from ext. mobile service provider with Cisco ip phone?
phone type is Cisco ip phone CP-8855
2 Accepted Solutions
No Those ports are not designed for the purpose you mentioned.
You need to connect this trough a Lan or WIFI(if support)
There is no 8855 phone model  from Cisco.
Response Signature
Creatif86
Hi Nithin,
Model correction: (is cisco CP 8865).. thanks for the useful support.
Anyway please what are the functions of the two usb ports on the phone?
As beginners, would like to know more about such ports and its functions. Thank you
5 Replies 5
Not clear what does that mean by receiving incoming call using USB modem
If you have cloud service and for phone to register with the Cloud, phones  need a network connectivity to the cloud service. You can use any technology to connect with the cloud.  you can use with 3g,4g,5g, Fiber  anything...
Response Signature
Hi Nithin,
Thanks for the support, to get everything clear here. I bought Cisco Cp-8855 ip phone that has two usb ports, one under the phone as input and the other at the side as output. If i plug usb internet modem with sim support. Is it possible i can receive external call with the help of the usb modem with sim?
Response Signature
Creatif86
Hi Nithin,
●  Two USB ports enhance the usability of call handling by enabling wired or wireless headsets, in addition to providing charging capability to mobile devices such as smartphones or tablets
◦   A side USB port provides up to 500mA power output at 5V or 2.5W
◦   A back USB (in yellow) port provides 500mA power output and is upgradable to support up to 2.1A power output at 5V or 10.5W
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-734731.html
Response Signature
