05-31-2017 11:20 PM - edited 03-17-2019 10:28 AM
Hi everyone,
I am facing a issue with a Cisco CP7821 to register on a VG running Call Manager with SIP protocol.
The phone is tryng to use a IP 192.168.10.3 but this ip is not in our range and not configured on VG to deliver this config through CDP.
<String name="UnifiedCMIPAddress">192.168.10.3</String>
<String name="LocalPort">50015</String>
<String name="TimeStamp">1483958827601</String>
<Enum name="ReasonForOutOfService">22</Enum>
Anyone had the same issue?
05-31-2017 11:42 PM
ReasonForOutOfService=22 -- TCPclosedUcmInitiatedReset - The device closed the TCP connection due to a reset command from the Cisco Unified CM
What CUCm version are you running
Is the issue with one phone or more
Do you have other 7821 working?
JB
06-01-2017 03:47 AM
Hi Bhndari,
CME Version 10.5
Only one phone is facing this issue, I have more 7821 working. I just installed 10 but 1 got that. We did factory reset many times but it did not worked.
06-01-2017 04:03 AM
Can you please post the output of status messages of IP Phone.
Also verify if the IP phone is receiving an invalid TFTP address from the DHCP server.
A test you can do, is to manually configure the IPV4 section on the IP phone, defining the correct tftp server address.
Please let me know
Carlo
05-31-2017 11:57 PM
Try to remove itl file from phone or factory reset it once to check.
Suresh
09-28-2018 08:15 AM
I'm having the exact same issue but with 7841's. All brand new phones. Some phones will register and some will get rejected. When I view the phone logs of the rejected phones I noticed the following: UnifiedCMIPAddress">192.168.20.3 (we use the class A private range 10.X.X.X)
ReasonForOutOfService">24
Is this Cisco's Test CUCM IP and the flash on these phones have not been properly erased? Could someone please confirm as I have over 1400 phones and this will be a nightmare to erase ITL file manually. Thanks.
